Home » Eclipse Projects » DSDP - Target Management » Permissions Lost [SOLVED](Permissions lost when transferring files over an ssh/sftp connection.)
Permissions Lost [SOLVED] [message #504101] Thu, 17 December 2009 04:23 Go to next message
I have an ssh/sftp remote connection that otherwise seems to work fine. It can launch terminals, browse the folder tree etc etc.
However, if I either drag an executable file into the remote file tree (from the local one) or I set up a "C/C++ Remote Application" which downloads the binary first it will copy the file ok, but fail to set the permission bits (defaults everything back to 644).
If I then log in and manually set the permission bits to 755, it then runs fine.
I don't know if this is also meaningful, but the error message from eclipse when it tries to run this c/c++ remote application is a file upload error (nothing explicit).
Scp/sftp'ing directly from my host to the embedded board doesn't have this problem.
Any ideas how to solve this?
Cheers.
[Updated on: Thu, 17 December 2009 15:22] by Moderator
Re: Permissions Lost [message #504265 is a reply to message #504101] Thu, 17 December 2009 14:13 Go to previous messageGo to next message
Some further digging.
I tried the same when connection to a new connection set up for localhost with ssh only. Same problem - so the issue has nothing to do with the embedded board.
Seems like rse's sftp is setting a umask that is different to what is used when sftp'ing from the command line.
Re: Permissions Lost [message #504269 is a reply to message #504101] Thu, 17 December 2009 20:22 Go to previous message
Ok, barked totally up the wrong tree on this one....
Turned out it was just an incomplete path under the "Remote Absolute File Path for C/C++ Application" box. I supplied the directoriy, not the full pathname to the copied binary.
i.e. /home/yujin needed to be /home/yujin/hello.
Just in case anyone else has this issue.
Previous Topic:"Browse For Folder" Dialog does not work as expected
Next Topic:Permissions Lost
Current Time: Wed Jul 23 12:19:15 EDT 2025
Powered by FUDForum. Page generated in 0.71482 seconds
