Home » Eclipse Projects » Plugin Development Environment (PDE) » IPluginModelBase listener + stale information
IPluginModelBase listener + stale information [message #504261] Thu, 17 December 2009 16:59 Go to next message
I am adding a listener to instances of IPluginModelBase using the
following code:
private void bundleAdded(final IPluginModelBase pluginModel) {
// Create a new bundle to model the one added
pluginModel.addModelChangedListener(new IModelChangedListener() {
public void modelChanged(IModelChangedEvent event) {
System.out.println("** Change event **");
String id = pluginModel.getPluginBase().getId();
String version = pluginModel.getPluginBase().getVersion();
System.out.println("id : " + id);
System.out.println("Version: " + version);
When I change and save the bundle details in the manifest editor, I seem
to be getting stale information. For example, assuming that the bundle
id is "BundleA" and the version is 1.0:
1) Bundle id is changed to "BundleB" the output is correct:
** Change event **
Version: 1.0.0
2) Bundle version is changed to "2.0.0" the event is fired but the
output is stale:
** Change event **
Version: 1.0.0
3) Bundle version is changed to "3.0.0" the output continues to be stale:
** Change event **
Version: 2.0.0
This is similarly the case when monitoring the dependencies and other
features of the model. What am I doing wrong?
James
Re: IPluginModelBase listener + stale information [message #505603 is a reply to message #504261] Sat, 02 January 2010 12:26 Go to previous messageGo to next message
Bounce! I could really do with some input on this one?
James
James Willans wrote:
> Hello,
> following code:
> @Override
> ** Change event **
> Version: 1.0.0
> output is stale:
> ** Change event **
> Version: 1.0.0
> ** Change event **
> Version: 2.0.0
> James
Re: IPluginModelBase listener + stale information [message #603910 is a reply to message #504261] Sat, 02 January 2010 17:23 Go to previous message
James
> Hello,
> following code:
> @Override
> ** Change event **
> Version: 1.0.0
> output is stale:
> ** Change event **
> Version: 1.0.0
> ** Change event **
> Version: 2.0.0
> James
Previous Topic:Class Loader Issue
Next Topic:One command and handler per menu entry?
Current Time: Fri Jul 25 20:40:44 EDT 2025
Powered by FUDForum. Page generated in 0.04942 seconds
