Home » Eclipse Projects » Rich Client Platform (RCP) » How to trim down application size?
How to trim down application size? [message #504052] Wed, 16 December 2009 17:55 Go to next message
Today I deployed for the first time my application.
It is far from complete, even though is not exactly trivial.
The size of the resulting directory (*excluding* the repository subdir) is well above 27MB.
It seems a bit steep for an application with one Perspective, two EditParts and one handful of ViewParts.
Am I linking in the whole universe or these numbers are normal?
How can I reduce (if possible at all) the size of this beast?
The heavyweights are, as expected, in the plugins subdir:
$ ls -lS
total 27521
-rw-r--r-- 1 mauro Administrators 5787493 Dec 16 22:15 com.ibm.icu_4.0.1.v20090822.jar
-rw-r--r-- 1 mauro Administrators 4070677 Dec 16 22:15 org.eclipse.ui.workbench_3.5.1.M20090826-0800a.jar
-rw-r--r-- 1 mauro Administrators 3003725 Dec 16 22:15 ag.ion.noa_2.2.1.jar
-rw-r--r-- 1 mauro Administrators 2256700 Dec 16 22:15 org.eclipse.swt.win32.win32.x86_3.5.1.v3555a.jar
-rw-r--r-- 1 mauro Administrators 2068344 Dec 16 22:15 org.eclipse.ui.ide_3.5.1.M20090826-0800.jar
-rw-r--r-- 1 mauro Administrators 1438886 Dec 16 22:15 it.condarelli.rcp.yw_1.0.0.200912162314.jar
-rw-r--r-- 1 mauro Administrators 1300581 Dec 16 22:15 org.apache.xerces_2.9.0.v200909240008.jar
-rw-r--r-- 1 mauro Administrators 1125860 Dec 16 22:15 org.eclipse.osgi_3.5.1.R35x_v20090827.jar
-rw-r--r-- 1 mauro Administrators 1057998 Dec 16 22:15 org.eclipse.jface_3.5.1.M20090826-0800.jar
-rw-r--r-- 1 mauro Administrators  970384 Dec 16 22:15 org.eclipse.jface.text_3.5.1.r351_v20090708-0800.jar
-rw-r--r-- 1 mauro Administrators  296330 Dec 16 22:15 org.eclipse.ui.forms_3.4.1.v20090714_35x.jar
-rw-r--r-- 1 mauro Administrators  292012 Dec 16 22:15 org.apache.xml.serializer_2.7.1.v200902170519.jar
-rw-r--r-- 1 mauro Administrators  283349 Dec 16 22:15 org.eclipse.core.databinding.observable_1.2.0.M20090902-0800.jar
-rw-r--r-- 1 mauro Administrators  263837 Dec 16 22:15 org.eclipse.jface.databinding_1.3.1.M20090826-0800.jar
-rw-r--r-- 1 mauro Administrators  245732 Dec 16 22:15 org.eclipse.text_3.5.0.v20090513-2000.jar
-rw-r--r-- 1 mauro Administrators  236808 Dec 16 22:15 javax.xml_1.3.4.v200902170245.jar
-rw-r--r-- 1 mauro Administrators  218339 Dec 16 22:15 org.eclipse.help_3.4.1.v20090805_35x.jar
-rw-r--r-- 1 mauro Administrators  203095 Dec 16 22:15 org.eclipse.core.databinding_1.2.0.M20090819-0800.jar
-rw-r--r-- 1 mauro Administrators  176643 Dec 16 22:15 org.eclipse.core.databinding.property_1.2.0.M20090819-0800.jar
My application is "it.condarelli.rcp.yw".
I tried searching, but I didn't find anything relevant.
OTOH several applications advertised as based on eclipse RCP have a much smaller footprint, so I suspect I'm doing something not quite right.
In particular the topmost item suggests I might be pulling in even Klingon and Sindarin codepages.
Thanks in Advance
Mauro
Re: How to trim down application size? [message #505910 is a reply to message #504052] Tue, 05 January 2010 09:53 Go to previous messageGo to next message
Are you using org.eclipse.ui.ide? If not, get rid of it (it contains
mostly code to work with core.resources, which you haven't included).
Are you using org.eclipse.help? And org.eclipse.text, that's the text
editor support.
As for com.ibm.icu, if you don't need the i18n support you can replace
it with com.ibm.icu.base (a plugin listed on the
http://download.eclipse.org/eclipse/downloads/drops/R-3.5.1- 200909170800/index.php
page, for example).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to trim down application size? [message #539799 is a reply to message #505910] Sun, 13 June 2010 08:44 Go to previous messageGo to next message
> editor support.
> page, for example).
> PW
I have an EMF model. Does it count as Resource?
I do *not* have a workspace, just I just open a model file in the filesystem.
I tried getting rid of help, but I got the error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Writer Application 1.0.0 (it.condarelli.writer 1.0.0)
Missing requirement: Workbench 3.5.2.M20100113-0800 (org.eclipse.ui.workbench 3.5.2.M20100113-0800) requires 'bundle org.eclipse.help [3.2.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: Writer Application 1.0.0 (it.condarelli.writer 1.0.0)
To: org.eclipse.ui.workbench [3.5.2.M20100113-0800]
Is there an "approved Way" to find out what can be deleted from dependencies?
The automated Writer.product->Dependencies->Add Required Plug-ins pulls in a lot of things obviously not needed.
Is there something better available?
TiA
Mauro
Re: How to trim down application size? [message #540102 is a reply to message #539799] Mon, 14 June 2010 18:03 Go to previous messageGo to next message
No, I'm just curious why you have org.eclipse.ui.ide in there. Remove
it if you can, it's for providing workbench services that deal with
IResources (the org.eclipse.core.resources plugin). That's for
workspaces, which you don't have.
A quick glance through the original list and it looks like the only
other thing you can do is to replace com.ibm.icu with com.ibm.icu.base
(so it is significantly smaller).
You might be right, as long as you use org.eclipse.ui.workbench you
can't get rid of help.
Later,
PW
Paul Webster
Re: How to trim down application size? [message #540159 is a reply to message #540102] Tue, 15 June 2010 03:48 Go to previous messageGo to next message
>> filesystem.
> No, I'm just curious why you have org.eclipse.ui.ide in there. Remove it
The culprit was usage of FileStoreEditorInput which is in
org.eclipse.ui.ide. (why????)
I wrote my own LocalEditorInput/LocalEditorInputFactory and I managed to
get rid of ide (almost).
My current dependencies for my plugin is:
it.condarelli.writer.model,
org.eclipse.core.runtime,
org.eclipse.ui,
org.eclipse.jface.databinding,
org.eclipse.emf.databinding,
org.eclipse.ui.forms,
org.eclipse.core.filesystem,
org.eclipse.core.databinding.property,
org.eclipse.jface.text,
org.eclipse.ui.editors,
org.eclipse.nebula.widgets.ganttchart
Unfortunately the dependencies for the whole product (trimmed down by
hand, the automated dependency generator produces a *much* larger set) is:
<plugin id="com.ibm.icu"/>
<plugin id="it.condarelli.writer.model"/>
<plugin id="org.eclipse.compare"/>
<plugin id="org.eclipse.compare.core"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filebuffers"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.compatibility" fragment="true"/>
<plugin id="org.eclipse.core.resources.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"
fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.ecf"/>
<plugin id="org.eclipse.ecf.filetransfer"/>
<plugin id="org.eclipse.ecf.identity"/>
<plugin id="org.eclipse.ecf.provider.filetransfer"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.ssl" fragment="true"/>
<plugin id="org.eclipse.ecf.ssl" fragment="true"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.databinding"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.p2.artifact.repository"/>
<plugin id="org.eclipse.equinox.p2.core"/>
<plugin id="org.eclipse.equinox.p2.engine"/>
<plugin id="org.eclipse.equinox.p2.jarprocessor"/>
<plugin id="org.eclipse.equinox.p2.metadata"/>
<plugin id="org.eclipse.equinox.p2.metadata.repository"/>
<plugin id="org.eclipse.equinox.p2.repository"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.security"/>
<plugin id="org.eclipse.equinox.security.win32.x86" fragment="true"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.nebula.widgets.ganttchart"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.editors"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.ide"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.win32" fragment="true"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.ui.workbench.texteditor"/>
<plugin id="Writer"/>
where org.eclipse.ui.ide is back with some strange friends
(org.eclipse.ecf.*).
Two questions:
Is there any way to trim down this beast? It seems to me a refactoring
of some classes (e.g.: FileStoreEditorInput) would be beneficial for all
of us wanting to use RCP "just" as an Application Framework.
You said I should "replace com.ibm.icu with com.ibm.icu.base", but I
didn't find a way to do that. Can You tell me how to achieve that?
Many Thanks.
Mauro
> Later,
> PW
Re: How to trim down application size? [message #540223 is a reply to message #540159] Tue, 15 June 2010 08:34 Go to previous message
The com.ibm.icu replacement, com.ibm.icu.base, is on the Eclipse SDK
download pages, like
http://download.eclipse.org/eclipse/downloads/drops/R-3.5.2- 201002111343/
As long as you depend on org.eclipse.ui.ide, you will get all of
core.resources, p2, and p2 pulls in ecf.
> Two questions:
Get rid of org.eclipse.ui.ide dependencies. That's the only way. If
you've copied out the LocalEditorInput/LocalEditorInputFactory code,
what else do you depend on?
Later,
PW
Paul Webster
Previous Topic:Menu contribution to a nested editor
Next Topic:One Handler, multiple WorkbenchWindows
Current Time: Sat Jul 26 08:11:03 EDT 2025
Powered by FUDForum. Page generated in 0.04321 seconds
