SWT fullscreen [message #503799] |
Tue, 15 December 2009 15:09  |
I am writing an application that is supposed to open a window in fullscreen. It works fine if I run it on the primary display. But if I open it on any of the other displays the window does'nt turn fullscreen. I run it on Mac OS 10.6 with SWT-cocoa64.
Does anyone know how to solve this?
package testApp;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.events.KeyAdapter;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.KeyListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
public class Main
Display display = new Display();
Shell shell = new Shell(display);
Button buttonOpen = new Button(shell, SWT.NONE);
Button buttonClose = new Button(shell, SWT.NONE);
Shell shellFS;
public static void main(String[] args)
new Main();
Main()
shell.setBounds(150, 50, 800, 400);
buttonOpen.setText("Open");
buttonOpen.setLocation(40, 150);
buttonOpen.pack();
buttonOpen.addSelectionListener(openListener);
buttonClose.setText("Close");
buttonClose.setLocation(240, 150);
buttonClose.pack();
buttonClose.addSelectionListener(closeListener);
shell.addKeyListener(closeFSWithQ);
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
SelectionListener openListener = new SelectionListener()
public void widgetSelected(SelectionEvent event)
open();
public void widgetDefaultSelected(SelectionEvent event)
SelectionListener closeListener = new SelectionListener()
shell.close();
KeyListener closeFSWithQ = new KeyAdapter()
public void keyPressed(KeyEvent e)
if (e.keyCode == 113)
close();
void close()
shellFS.setFullScreen(false);
shellFS.close();
void open()
shellFS = new Shell(display);
shellFS.addKeyListener(closeFSWithQ);
shellFS.setFullScreen(true);
shellFS.open();
Re: SWT fullscreen [message #503942 is a reply to message #503799] |
Wed, 16 December 2009 05:08   |
I assume when you say "display" that you mean "monitor", as there's only one
Display ever used in your snippet. I don't currently have access to a Mac
with multiple monitors, but it sounds like a bug in swt, so I would suggest
logging a report at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT .
The only workaround I can think of in the meantime is to create a Shell with
no trim and set its size to the monitor's size.
Grant
"larsk" <larsk7@gmail.com> wrote in message
news:hg8qdt$7fs$1@build.eclipse.org...
> package testApp;
> import org.eclipse.swt.widgets.Display;
> public class Main
> Shell shellFS;
> new Main();
> Main()
> buttonOpen.pack();
> buttonClose.pack();
> shell.open();
> display.sleep();
> @Override
> open();
> @Override
> @Override
> shell.close();
> @Override
> @Override
> close();
> void close()
> shellFS.close();
> void open()
> shellFS.open();
Re: SWT fullscreen [message #504560 is a reply to message #504441] |
Mon, 21 December 2009 09:25   |
Yes, the trim is the top bar, resize handles, etc. Do this by creating the
Shell with style SWT.NO_TRIM or SWT.ON_TOP.
Grant
news:hgiatb$b63$1@build.eclipse.org...
> Thanks for your answer!
> Yes, I mean monitor.
> What do you mean with "no trim"? Is that so the "bar" in the top
disappears? I that case how do I make this happen?
> Thanks!
> Grant Gayed wrote on Wed, 16 December 2009 11:08
> > Hi,
one
Mac
suggest
> > logging a report at
&component=SWT .
with
> > Grant
Re: SWT fullscreen [message #504824 is a reply to message #504560] |
Tue, 22 December 2009 15:27  |
Thanks! It seems to work perfectly this way.
Grant Gayed wrote on Mon, 21 December 2009 15:25 | Yes, the trim is the top bar, resize handles, etc. Do this by creating the
Grant
FUDForum. Page generated in 0.05246 seconds
