Home » Language IDEs » ServerTools (WTP) » unsupported content file" error
icon5.gif  unsupported content file" error [message #503923] Wed, 16 December 2009 03:20 Go to next message
I've installed aptana plugin in my eclipse for jquery support. it works. but one problem exist.
when i want to open html file by html editor i see the "unsupported content file" error dialog.
what is the problem?
I think installation of aptana cause this inconsistency. Am i right?
Re: unsupported content file" error [message #504382 is a reply to message #503923] Fri, 18 December 2009 10:25 Go to previous messageGo to next message
Most likely. If you bring up the Properties dialog of the file,
does the Resource page still say it's of type "File (HTML)"?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: unsupported content file" error [message #504447 is a reply to message #503923] Sat, 19 December 2009 07:23 Go to previous messageGo to next message
I have checked source file type. it is html.
when i use fresh copy of eclipse i don't have any problem. but when i install aptana plugin i cant open files with traditional eclipse html editor.
this is log file:
!ENTRY org.eclipse.wst.sse.ui 2 2 2009-12-19 15:49:08.703
!MESSAGE StructuredTextEditor being used without StructuredDocument
!ENTRY org.eclipse.wst.sse.ui 2 2 2009-12-19 15:49:08.718
!MESSAGE          Input Name: test.html
!MESSAGE         Unexpected IDocumentProvider implementation: org.eclipse.ui.editors.text.TextFileDocumentProvider
!MESSAGE         Unexpected IDocument implementation: org.eclipse.core.internal.filebuffers.SynchronizableDocument
!ENTRY org.eclipse.ui 4 0 2009-12-19 15:49:08.765
!MESSAGE Unable to create editor ID org.eclipse.jst.pagedesigner.PageDesignerEditor: An unexpected exception was thrown.
!STACK 0
	at org.eclipse.wst.sse.ui.StructuredTextEditor.createModelDependentFields(StructuredTextEditor.java:1305)
	at org.eclipse.wst.sse.ui.StructuredTextEditor.update(StructuredTextEditor.java:2836)
	at org.eclipse.jst.pagedesigner.editors.HTMLEditor.sash_createAndAddDesignSourcePage(HTMLEditor.java:269)
	at org.eclipse.jst.pagedesigner.editors.HTMLEditor.createPages(HTMLEditor.java:430)
	at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
	at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
	at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
	at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
	at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
	at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
	at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
	at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
	at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
	at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
	at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
	at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
	at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
	at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
	at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
	at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:394)
	at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:141)
	at org.eclipse.dltk.internal.ui.actions.OpenActionUtil.open(OpenActionUtil.java:45)
	at org.eclipse.dltk.ui.actions.OpenAction.run(OpenAction.java:256)
	at org.eclipse.dltk.ui.actions.OpenAction.run(OpenAction.java:237)
	at org.eclipse.dltk.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:259)
	at org.eclipse.dltk.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:235)
	at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerActionGroup.handleOpen(ScriptExplorerActionGroup.java:304)
	at org.eclipse.php.internal.ui.explorer.PHPExplorerActionGroup.handleOpen(PHPExplorerActionGroup.java:93)
	at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerPart$4.open(ScriptExplorerPart.java:662)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
	at org.eclipse.core.runtime.Platform.run(Platform.java:888)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
[Updated on: Sat, 19 December 2009 07:25] by Moderator
Re: unsupported content file" error [message #514068 is a reply to message #504447] Fri, 12 February 2010 05:59 Go to previous message
I have the same NullPointerException, I have installed the JBoss Tools and I'm opening xhtml. The content type is ok. After restart it is OK.
Previous Topic:WTP learning curve, documentation and Eclipse WTP-developing Java... mismatch.
Next Topic:Java EE development
Current Time: Thu Jul 24 22:53:58 EDT 2025
Powered by FUDForum. Page generated in 0.29102 seconds
