Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EEF Can´t display the property view
EEF Can´t display the property view [message #503642] Tue, 15 December 2009 02:17 Go to next message
hi i generated with eef my properties
http://wiki.eclipse.org/EEF_tutorial_:_First_generation
but my propview will not display. i think the problem is the contributor id, but in the tutorial the contributor id of the editor and the plugin.xml is also different.
EEF Generation in EMF treeview editor: MY STEPS
add dependency on my project test.prop.eef
add in this project the extension points of the providers
add in test.prop.eef.diagram the extension points of the tab props
implements in test.prop.eef.editor.myEditor ITabbedProp....
contributorID = "model.properties"
change method getPropertySheetPage()
test.prop.eef.diagram plugin.xml
<!-- Tabbed properties views extension -->
   <extension
         point="org.eclipse.ui.views.properties.tabbed.propertyContributor">
      <propertyContributor
            contributorId="EEFContributorID">
         <propertyCategory
               category="default">
         </propertyCategory>
         <propertyCategory
               category="extended">
         </propertyCategory>
         <propertyCategory
               category="advanced">
         </propertyCategory>
      </propertyContributor>
   </extension>
   <extension
         point="org.eclipse.ui.views.properties.tabbed.propertyTabs">
      <propertyTabs
         <propertyTab
               label="Base"
               category="default"
               id="Base">
         </propertyTab>
      </propertyTabs>
   </extension>
   <extension
         point="org.eclipse.ui.views.properties.tabbed.propertySections">
      <propertySections
         <propertySection
               tab="Base"
               class="org.eclipse.emf.eef.runtime.ui.properties.sections.PropertiesEditionSection"
               id="model.model.section.Diagram">
             <input
                    type="model.Diagram">
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="model.model.section.Element">
             <input
                    type="model.Element">
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="model.model.section.Rectangle">
             <input
                    type="model.Rectangle">
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="model.model.section.Ellipse">
             <input
                    type="model.Ellipse">
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="model.model.section.ElementEvents">
             <input
                    type="model.ElementEvents">
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="model.model.section.Line">
             <input
                    type="model.Line">
             </input>
         </propertySection>
      </propertySections>
   </extension>
I hope this will help.
Re: EEF Can´t display the property view [message #503715 is a reply to message #503642] Tue, 15 December 2009 08:21 Go to previous messageGo to next message
Hi Thomas,
I think that your contributor ID has to be the same in the editor and in
the plugin.xml.
Nathalie.
> <extension
> point="org.eclipse.ui.views.properties.tabbed.propertyContributor ">
> <propertyCategory
> category="default">
> </propertyCategory>
> <propertyCategory
> </propertyCategory>
> <propertyCategory
> </propertyCategory>
> </extension>
> <extension
> point="org.eclipse.ui.views.properties.tabbed.propertyTabs" >
> <propertyTabs
> <propertyTab
> label="Base"
> category="default"
> id="Base">
> </propertyTab>
> </propertyTabs>
> </extension>
> <extension
> point="org.eclipse.ui.views.properties.tabbed.propertySections ">
> <propertySections
> <propertySection
> tab="Base"
> class=" org.eclipse.emf.eef.runtime.ui.properties.sections.Propertie sEditionSection "
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> type="model.Line">
> </input>
> </propertySection>
> </propertySections>
> </extension>
> Thanks
Re: EEF Can´t display the property view [message #503863 is a reply to message #503715] Tue, 15 December 2009 21:23 Go to previous messageGo to next message
i have debugged my code and i come to this section
 String selectionContributorId = newContributor.getContributorId();
// test.prop.eef.diagram equals test.prop.eef.diagram its true
if (selectionContributorId.equals(currentContributorId)) {
			 * selection has the same contributor id as current, so leave
			 * existing registry.
			return;
so my contributorID is the same, but my propertypage will not display.
My problem is, if i want debugg, i cant get access on
XXXPropertiesEditionProvider
XXXPropertiesEditionPolicyProvider
XXXPropertiesEditionPartProvider
classes and my propertypages will not use the createXXXPropertiesEditonProvider();
Are there some more hints?
[Updated on: Tue, 15 December 2009 21:48] by Moderator
Re: EEF Can´t display the property view [message #503882 is a reply to message #503863] Wed, 16 December 2009 03:54 Go to previous messageGo to next message
Have you defined the provider extension points
"org.eclipse.emf.eef.runtime.PropertiesEditionProvider",
"org.eclipse.emf.eef.runtime.PropertiesEditionPolicyProvider " and
"org.eclipse.emf.eef.runtime.PropertiesEditionPartProvider" ?
Nathalie.
> return;
> some more hints?
Re: EEF Can´t display the property view [message #503887 is a reply to message #503882] Wed, 16 December 2009 04:12 Go to previous messageGo to next message
yes in my
test.prop.eef project
<?eclipse version="3.0"?>
 <copyright>
 </copyright>
 $Id$
<plugin>
   <extension point="org.eclipse.emf.ecore.generated_package">
      <package
            uri="http://model/1.0"
            class="model.ModelPackage"
            genModel="model/model.genmodel"/>
   </extension>
   <!-- EEF extensions -->
    <extension
         point="org.eclipse.emf.eef.runtime.PropertiesEditionProvider">
      <PropertiesEditionComponentProvider
            providerClass="model.providers.ModelPackagePropertiesEditionProvider">
      </PropertiesEditionComponentProvider>
   </extension>
   <extension
         point="org.eclipse.emf.eef.runtime.PropertiesEditionPolicyProvider">
      <PropertiesEditionPolicyProvider
            providerClass="model.providers.ModelPackagePropertiesEditionPolicyProvider">
      </PropertiesEditionPolicyProvider>
   </extension>
   <extension
         point="org.eclipse.emf.eef.runtime.PropertiesEditionPartProvider">
      <PropertiesEditionPartProvider
            providerClass="model.providers.ModelPropertiesEditionPartProvider">
      </PropertiesEditionPartProvider>
   </extension>
</plugin>
I only have to add the extension points here, right?
thanks
Re: EEF Can´t display the property view [message #503893 is a reply to message #503887] Wed, 16 December 2009 04:37 Go to previous messageGo to next message
Where do you generate the EEF code ? Maybe this generation is not loaded
or not accessible... Is the project containing the EEF generation loaded ?
Nathalie.
Thomas a écrit :
> yes in my
> <copyright>
> </copyright>
> $Id$
> <plugin>
> <package
> </extension>
> <extension
> point="org.eclipse.emf.eef.runtime.PropertiesEditionProvider ">
> providerClass="model.providers.ModelPackagePropertiesEditionProvider ">
> </extension>
> <extension
> point="org.eclipse.emf.eef.runtime.PropertiesEditionPolicyProvider ">
> providerClass="model.providers.ModelPackagePropertiesEditionPolicyProvider ">
> </extension>
> <extension
> point="org.eclipse.emf.eef.runtime.PropertiesEditionPartProvider ">
> providerClass="model.providers.ModelPropertiesEditionPartProvider ">
> </extension>
> </plugin>
> thanks
Re: EEF Can´t display the property view [message #503899 is a reply to message #503893] Wed, 16 December 2009 00:16 Go to previous messageGo to next message
my project folders
test.prop.eef
+src (src-folder)
+src-gen (src-folder for eef)
How can i check, that my project is loading the eef generation? but i guess that it will be loaded.
I am sorry that i am new, but i want to do my project with eef.
Re: EEF Can´t display the property view [message #503904 is a reply to message #503899] Wed, 16 December 2009 05:44 Go to previous messageGo to next message
No problem for the questions, newsgroup is here for that !
It seems that your project is loaded.
Can you check if the "src-gen" folder for EEF generation is present in
the build.properties of your test.prop.eef project (in the "source" part) ?
Nathalie.
Thomas a écrit :
> my project folders
> test.prop.eef
> +src (src-folder)
> guess that it will be loaded. I am sorry that i am new, but i want to do
> Thanks
Re: EEF Can´t display the property view [message #503908 is a reply to message #503904] Wed, 16 December 2009 01:14 Go to previous messageGo to next message
Oh this was meant, of course it is added.
   <propertySection
               tab="Base"
               [COLOR=orangered]class="org.eclipse.emf.eef.runtime.ui.properties.sections.PropertiesEditionSection"[/COLOR]
               id="base.model.section.Diagram">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="base.model.section.Element">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="base.model.section.Rectangle">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="base.model.section.Ellipse">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="base.model.section.ElementEvents">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
               id="base.model.section.Line">
             <input
                    type="model.Line">
             </input>
         </propertySection>
      </propertySections>
What is about this class. is it a factoryclass to create this propertysections?
In
xxx.diagram.part there is a ModelDiagramEditor.java class, which contains the standart contributor id:
public class ModelDiagramEditor extends DiagramDocumentEditor {
	 * @generated
	public static final String ID = "model.diagram.part.ModelDiagramEditorID"; //$NON-NLS-1$
Do i have to use the same contributor id in eefgen too?
If its better for you, i can write step-by-step instruction, what i do.
[Updated on: Wed, 16 December 2009 06:34] by Moderator
Re: EEF Can´t display the property view [message #503920 is a reply to message #503908] Wed, 16 December 2009 08:04 Go to previous messageGo to next message
My Steps:
create new gmf Project org.eclipse.test.prop
model.ecore
generate genmodel
-> generate All
->Initialize EEF Model
eefgen
->/org.eclipse.test.prop/src (Generation)
->/org.eclipse.test.prop/src-gen (Test-Generation)
gen edition context
-> set basepackage to model
-> description contributorid to org.eclipse.test.prop.model.properties
-> hook gmf specific properties views
gen views repository
->base package model
->GENMODEL
EEF -> Generate EEF Architektur
This was the generation Section
__________________________________________________________
generated model_properties.plugin.xml
 <plugin>
  <extension
            providerClass="model.model.providers.ModelPackagePropertiesEditionProvider">
   </extension>
   <extension
            providerClass="model.model.providers.ModelPackagePropertiesEditionPolicyProvider">
   </extension>
   <extension
            contributorId="org.eclipse.test.prop.model.properties">
         <propertyCategory
               category="default">
         </propertyCategory>
         <propertyCategory
         </propertyCategory>
         <propertyCategory
         </propertyCategory>
   </extension>
   <extension
      <propertyTabs
         <propertyTab
               label="Base"
               category="default"
               id="Base">
         </propertyTab>
      </propertyTabs>
   </extension>
   <extension
      <propertySections
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
                    type="model.Line">
             </input>
         </propertySection>
      </propertySections>
   </extension>
 </plugin>
I add the first two extensions to org.eclipse.test.prop-> plugin.xml
and add a 3rd
   <extension
   </extension>
the other extensions are inserted in org.eclipse.test.prop.diagram -> plugin.xml
i remove the existing 3 prop.tab extension points and add the generated ones. (org.eclipse.ui.vies.propperties.tabbed. ....)
then i move to the project org.eclipse.test.prop.editor
-> implement ITabbedPropertyPage
-> change getPropertySheetPage like in the tutorial
-> change variable
-> set ContribotrId to org.eclipse.test.prop.model.properties
it does compile and run, but it won´t display the property page.
Re: EEF Can´t display the property view [message #503921 is a reply to message #503908] Wed, 16 December 2009 08:04 Go to previous messageGo to next message
You have to add a dependency on "org.eclipse.emf.eef.runtime" to access
to the PropertiesEdtionSection class.
Nathalie.
Thomas a écrit :
> Oh this was meant, of course it is added. i think my problem is, the red
> colored entries of the plugin.xml in .diagram plugin
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> type="model.Line">
> </input>
> </propertySection>
> </propertySections>
> There is a warning at every class Attribute Referenced class
> 'org.eclipse.emf.eef.runtime.ui.properties.sections.Properti
> esEditionSection' in attribute 'class' is not on the plug-in classpath
> propertysections?
> Thanks
Re: EEF Can´t display the property view [message #503922 is a reply to message #503642] Wed, 16 December 2009 08:12 Go to previous messageGo to next message
My Steps:
model.ecore
generate genmodel
-> generate All
eefgen
gen edition context
->GENMODEL
 <plugin>
  <extension
   </extension>
   <extension
   </extension>
   <extension
         <propertyCategory
               category="default">
         </propertyCategory>
         <propertyCategory
         </propertyCategory>
         <propertyCategory
         </propertyCategory>
   </extension>
   <extension
      <propertyTabs
         <propertyTab
               label="Base"
               category="default"
               id="Base">
         </propertyTab>
      </propertyTabs>
   </extension>
   <extension
      <propertySections
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base"
             <input
                    type="model.Line">
             </input>
         </propertySection>
      </propertySections>
   </extension>
 </plugin>
and add a 3rd
   <extension
   </extension>
-> change variable
solved it
i added a filter like the old extension points and it worked, now i have some numberformatexceptions, but i think this will not the problem
<extension
      <propertySections
         <propertySection
               filter="org.eclipse.gmf.runtime.diagram.ui.properties.filters.ShapeEditPartPropertySectionFilter"
               tab="Base">
         </propertySection>
         <propertySection
               tab="Base">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base">
            <input
            </input>
         </propertySection>
         <propertySection
               tab="Base">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base">
             <input
             </input>
         </propertySection>
         <propertySection
               tab="Base">
             <input
                    type="model.Line">
             </input>
         </propertySection>
      </propertySections>
   </extension>
[Updated on: Wed, 16 December 2009 08:59] by Moderator
Re: EEF Can´t display the property view [message #504098 is a reply to message #503922] Wed, 16 December 2009 23:10 Go to previous messageGo to next message
I have some more Questions about the prop page.
I have a List of color attributes and i want to make the attributes editable with eef. how can i make color "Objects?" and is it possible to make an nearly "ColorCellEditor" in eef too?
Re: EEF Can´t display the property view [message #505665 is a reply to message #504098] Mon, 04 January 2010 05:27 Go to previous message
--------------040204020309050607030900
Hi Thomas,
What you ask is new types of widgets ( like text, textarea, ... ).
you can open a new request on bugzilla, or create your own widget.
the last solution is a bit complicated by now, because you have to
creates specific templates for generating your code to link the color
widget to EEF. don't hesitates to ask questions here.
name="stephane_bouchet.vcf"
filename="stephane_bouchet.vcf"
YmVnaW46dmNhcmQNCmZuO3F1b3RlZC1wcmludGFibGU6U3Q9QzM9QTlwaGFu ZSBCb3VjaGV0
DQpuO3F1b3RlZC1wcmludGFibGU6Qm91Y2hldDtTdD1DMz1BOXBoYW5lDQpv cmc6T2Jlbw0K
YWRyO3F1b3RlZC1wcmludGFibGU6Ozs7UmV6PUMzPUE5Ozs0NDQwMDtGcmFu Y2UNCmVtYWls
O2ludGVybmV0OnN0ZXBoYW5lLmJvdWNoZXRAb2Jlby5mcg0KeC1tb3ppbGxh LWh0bWw6RkFM
U0UNCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------040204020309050607030900--
Re: EEF Can´t display the property view [message #621924 is a reply to message #503715] Tue, 15 December 2009 21:23 Go to previous message
return;
some more hints?
Re: EEF Can´t display the property view [message #621926 is a reply to message #621924] Wed, 16 December 2009 03:54 Go to previous message
Nathalie.
> return;
> some more hints?
Re: EEF Can´t display the property view [message #621928 is a reply to message #503882] Wed, 16 December 2009 04:12 Go to previous message
yes in my
<copyright>
</copyright>
$Id$
<plugin>
<package
</extension>
<extension
</extension>
<extension
</extension>
<extension
</extension>
</plugin>
thanks
Re: EEF Can´t display the property view [message #621930 is a reply to message #503887] Wed, 16 December 2009 04:37 Go to previous message
Nathalie.
Thomas a écrit :
> yes in my
> <copyright>
> </copyright>
> $Id$
> <plugin>
> <package
> </extension>
> <extension
> </extension>
> <extension
> </extension>
> <extension
> </extension>
> </plugin>
> thanks
Re: EEF Can´t display the property view [message #621931 is a reply to message #503893] Wed, 16 December 2009 00:16 Go to previous message
my project folders
test.prop.eef
+src (src-folder)
Re: EEF Can´t display the property view [message #621932 is a reply to message #621931] Wed, 16 December 2009 05:44 Go to previous message
Nathalie.
Thomas a écrit :
> my project folders
> test.prop.eef
> +src (src-folder)
> Thanks
Re: EEF Can´t display the property view [message #621933 is a reply to message #503904] Wed, 16 December 2009 01:14 Go to previous message
Oh this was meant, of course it is added. i think my problem is, the red colored entries of the plugin.xml in .diagram plugin
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
type="model.Line">
</input>
</propertySection>
</propertySections>
There is a warning at every class Attribute Referenced class 'org.eclipse.emf.eef.runtime.ui.properties.sections.Properti esEditionSection' in attribute 'class' is not on the plug-in classpath
Re: EEF Can´t display the property view [message #621936 is a reply to message #621933] Wed, 16 December 2009 08:04 Go to previous message
My Steps:
model.ecore
generate genmodel
-> generate All
eefgen
gen edition context
->GENMODEL
<plugin>
<extension
providerClass="model.model.providers.ModelPackagePropertiesEditionProvider ">
</extension>
<extension
providerClass=" model.model.providers.ModelPackagePropertiesEditionPolicyPro vider ">
</extension>
<extension
<propertyCategory
category="default">
</propertyCategory>
<propertyCategory
</propertyCategory>
<propertyCategory
</propertyCategory>
</extension>
<extension
<propertyTabs
<propertyTab
label="Base"
category="default"
id="Base">
</propertyTab>
</propertyTabs>
</extension>
<extension
<propertySections
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
</input>
</propertySection>
<propertySection
tab="Base"
<input
type="model.Line">
</input>
</propertySection>
</propertySections>
</extension>
</plugin>
and add a 3rd
<extension
</extension>
-> change variable
Re: EEF Can´t display the property view [message #621937 is a reply to message #621933] Wed, 16 December 2009 08:04 Go to previous message
Nathalie.
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> </input>
> </propertySection>
> <propertySection
> tab="Base"
> <input
> type="model.Line">
> </input>
> </propertySection>
> </propertySections>
> propertysections?
> Thanks
Re: EEF Can´t display the property view [message #621939 is a reply to message #503922] Wed, 16 December 2009 23:10 Go to previous message
Re: EEF Can´t display the property view [message #621952 is a reply to message #621939] Mon, 04 January 2010 05:27 Go to previous message
Hi Thomas,
Previous Topic:EMFdiff file display
Next Topic:[EEF] StackOverflow while generating code
Current Time: Thu Jul 24 22:59:06 EDT 2025
Powered by FUDForum. Page generated in 0.14060 seconds
