ATF Installation [message #503512] |
Mon, 14 December 2009 09:49  |
Hi all.
Please forgive me...
I get this:
Cannot complete the install because one or more required items could not be found.
Software being installed: AJAX Tools Framework Webtools Integration (Incubation) 0.3.0.v200912041100-15-7zCN2PbcIMFLoO_LLIE (org.eclipse.atf.feature.feature.group 0.3.0.v200912041100-15-7zCN2PbcIMFLoO_LLIE)
Missing requirement: AJAX Tools Framework Webtools Integration (Incubation) 0.3.0.v200912041100-15-7zCN2PbcIMFLoO_LLIE (org.eclipse.atf.feature.feature.group 0.3.0.v200912041100-15-7zCN2PbcIMFLoO_LLIE) requires 'org.eclipse.wst.common_ui.feature.feature.group 3.1.0.v200903021835-7B5FREDhdMNPm7dkmBmpUJxRlMta' but it could not be found
While trying to install ATF from http://wiki.eclipse.org/ATF/Installing
On Ubuntu, Eclipse Galileo (IDE for java developer)
Am I missing something important?
I tried to search for the error, removing the detailed version numbers, but find nothing relevant
Re: ATF Installation [message #503772 is a reply to message #503512] |
Tue, 15 December 2009 12:08  |
the error message says that you're missing
org.eclipse.wst.common_ui.feature - this is part of WebTools.
You actually have two options now:
1. install ATF without WebTools support. Simply uncheck the "AJAX Tools
Framework Webtools Integration (Incubation)" when installing next time.
2. Install WebTools and then install ATF. WebTools might be actually
very useful, because they contain JSDT - e.g. a JavaScript editor with
syntax highlighting.
When installing ATF, did you enabled the "Contact all update sites
during install to find required software" switch? If it was enabled,
Eclipse should have found that missing WebTools feature.
If it was enabled but didn't worked, then you'd have to explicitly
install some of WebTools features. To do that, in Install wizard, choose
Galileo update site and find JSDT (JavaScript Development Tools) -
installing them should be enough to move ATF installation forward.
Let me know if that won't help.
cheers
Jacek
mic.cipi@gmail.com wrote:
> Hi all.
> I get this:
> not be found.
> found
Re: ATF Installation [message #562530 is a reply to message #503512] |
cheers
Jacek
> Hi all.
> I get this:
> not be found.
> found
FUDForum. Page generated in 0.04241 seconds
