Home » Modeling » TMF (Xtext) » cross reference on terminals/
cross reference on terminals/ [message #500722] Fri, 27 November 2009 12:54 Go to next message
Hi, I am a newcomer. I'm trying a simple grammar to parse statements like:
class man( name:string, age:integer, father:man)
Here the grammar:
Model:
classes+=Class+;
terminal CLASS_NAME:
('a'..'z') ('a'..'z' | 'A'..'Z' | '_' | '0'..'9')*;
Class :
'class' name= CLASS_NAME
'(' (attributes+=Attribute (',' attributes+=Attribute )* ) ')';
Attribute:
name=CLASS_NAME ':' type=[Type];
Type:
BuiltinType|Class;
BuiltinType:
name='integer'|'string';
On the input:
class place(name:string)
I have the error: "mismatched input 'string' expecting RULE_ID"
also on: class man(father:man)
"mismatched input 'man' expecting RULE_ID"
I'd like to have crossReference working if [Type] is actually a Class and no error if it is actually a terminal as 'integer'.
Also, I was expecting code completion working providing the words 'integer' 'string' when CTRL+Space where a Type is needed.
Any help is appreciate.
[Updated on: Fri, 27 November 2009 12:54] by Moderator
Re: cross reference on terminals/ [message #500737 is a reply to message #500722] Fri, 27 November 2009 15:23 Go to previous messageGo to next message
The terminal rule CLASS_NAME shadows the rule ID.
ID is used for crossreferences by default.
You'll either have to remove the CLASS_NAME rule and use ID instead,
e.g.
Class :
'class' name=ID '(' ...
or you'll have to use CLASS_NAME everywhere where you would have used ID
e.g.
Attribute :
name=CLASS_NAME ':' type=[Type|CLASS_NAME]
Sven
> Here the grammar:
> Model:
> classes+=Class+;
> Class :
> 'class' name= CLASS_NAME '(' (attributes+=Attribute (','
> Attribute:
> Type:
> BuiltinType|Class;
> BuiltinType:
> On the input:
> Thanks
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Re: cross reference on terminals/ [message #500998 is a reply to message #500737] Mon, 30 November 2009 11:18 Go to previous messageGo to next message
Hi Sven and thank you for your help.
I have removed the CLASS_NAME terminal rule and I am using ID.
Now references works on types( e.g. class man(father:man))
but I have the same problem before on the input:
class man(age:integer)
mismatched input 'integer' expecting RULE_ID.
Also code completion does not propose me 'integer' and 'string' but just the type man.
My language is very similar to the tutorial one:
entity Session {
property Title: String
property IsTutorial : Bool
but without type declaration
type String
type Bool
that are considered as primitive (builtin) types.
Of course I don't expect CTRL-click works on these terminals, but code completion I think could work.
Thanks again,
Giovanni
Re: cross reference on terminals/ [message #501041 is a reply to message #500998] Mon, 30 November 2009 13:42 Go to previous messageGo to next message
Since 'integer' (as well as 'string') is a keyword your can't use it as
an identifier. Keywords shadow any terminal rules.
If you want to allow keywords you'll have to declare a datatype rule.
Identifier :
ID |'string'|'integer';
and use it where you've used ID before:
e.g.
Attribute :
name=Identifier ':' type=[Type|Identifier]
> the type man.
> entity Session {
> type String
> type Bool
> Thanks again,
> Giovanni
Re: cross reference on terminals/ [message #501191 is a reply to message #501041] Tue, 01 December 2009 08:36 Go to previous messageGo to next message
Thanks again. Sorry for bother you; I'm sure that I'm missing something, but does still not work.
To be clearer, forget my example and consider the Entities example grammar we get when a new Xtext project is created.
Property:
'property' name=ID ':' type=[Type] (many?='[]')?;
suppose I want allow the type to be a Type (hence declared in the model) or a keyword like 'integer', but without declaring a Type 'integer' in the model
(the same happens between Classes and primitive types in java).
You suggested me to introduce a datatype rule
Identifier :
then property becomes
Property:
'property' name=ID ':' type=[Type|Identifier] (many?='[]')?;
but on the input
entity dummy{
property p:integer
I get the error "couldn't resolve reference to Type integer"... also code completion does not propose (integer,string) but only the entitiy dummy.
Should I work on these changing the validator and the scope provider?
Giovanni
Re: cross reference on terminals/ [message #501556 is a reply to message #501191] Wed, 02 December 2009 14:05 Go to previous messageGo to next message
If you really want to have built-in types, I would introduce a TypeRef
rule, like so :
Property :
'property' name=ID ':' type=TypeRef;
TypeRef :
(BuiltInTypeRef | RealTypeRef) many?='[]'?;
BuiltInTypeRef :
name=('integer'|'string');
RealTypeRef :
type=[Type];
Haven't tested it, though.
You'll typically have multiple places, where you use type references, so
extracting the whole thing in its own rule is a good idea.
In addition, you'll notice that working with the model becomes easier
when you have a type hierarchy for the different kind of type references.
Sven
> Property:
> the model
> Identifier :
> Property:
> but on the input
> entity dummy{
> property p:integer
> dummy.
> Thanks
> Giovanni
Re: cross reference on terminals/ [message #501636 is a reply to message #501556] Thu, 03 December 2009 03:15 Go to previous messageGo to next message
I did something similar:
Type: basic=('int' | 'boolean' | 'String') |
classref=[Class]
Field:
type=Type name=ID ';'
and it works
hope it helps
Lore
> rule, like so :
> Property :
> TypeRef :
> BuiltInTypeRef :
> RealTypeRef :
> type=[Type];
> Cheers,
> Sven
>> Property:
>> Identifier :
>> Property:
>> but on the input
>> entity dummy{
>> property p:integer
>> dummy.
>> Thanks
>> Giovanni
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: cross reference on terminals/ [message #501675 is a reply to message #501556] Thu, 03 December 2009 06:57 Go to previous messageGo to next message
Thanks! Nice solution..now works.
Giovanni
Re: cross reference on terminals/ [message #502085 is a reply to message #501675] Sat, 05 December 2009 06:23 Go to previous messageGo to next message
Works like a charm indeed, Sven. Nice to see that I run into the same issues as other people (so it "isn't me").
Next step is getting the generator right, but that should be peanuts now.
Re: cross reference on terminals/ [message #503718 is a reply to message #501556] Tue, 15 December 2009 03:34 Go to previous message
Hi Sven,
as previously said, your solution works for the proposal, but seems that does not work in template proposal.
Given that template
entity ${entityName} {
property ${propName} : ${type:CrossReference('Property.type')}
the CrossReferenceResolver is unable to resolve the cross reference, (maybe needs to looking at the classes that actually implements TypeRef).
In fact, if I use just
${type:CrossReference('RealTypeRef.type')
works well, but of course the BuiltInTypeRef (integer, string) entries are missing in the drop donw list.
Maybe, would be enough to have a template variable resolver that rely on the proposal provider that actually works well.
Any idea?
Giovanni
Previous Topic:Advanced examples for the declarative Java validator
Next Topic:Enum literals and case sensitivity
Current Time: Mon Jun 16 09:14:34 EDT 2025
Powered by FUDForum. Page generated in 0.43118 seconds
