Home » Eclipse Projects » Rich Client Platform (RCP) » command "org.eclipse.ui.views.showView" is always disabled
command "org.eclipse.ui.views.showView" is always disabled [message #503694] Tue, 15 December 2009 06:36 Go to next message
Hello everyone, I'm trying to get the "Show View" dialog to appear by using the following code:
<extension
         point="org.eclipse.ui.menus">
      <menuContribution
            locationURI="menu:org.eclipse.ui.main.menu">
         <menu
               label="Window">
            <command
                  commandId="org.eclipse.ui.views.showView"
                  style="push">
            </command>
         </menu>
      </menuContribution>
   </extension>
But it's always disabled. The same code with the command "org.eclipse.ui.perspectives.showPerspective" works fine (shows the perspective dialog).
What's wrong?
Thanks in advance!
Re: command "org.eclipse.ui.views.showView" is always disabled [message #503695 is a reply to message #503694] Tue, 15 December 2009 01:43 Go to previous messageGo to next message
You have to add a "parameter" to the command with the name of the view which should be shown:
name:
org.eclipse.ui.views.showView.viewId
value:
my.view.id
<command
style="push">
<parameter
name="org.eclipse.ui.views.showView.viewId"
value="my.view.id">
</parameter>
</command>
Greetz
[Updated on: Tue, 15 December 2009 06:46] by Moderator
Re: command "org.eclipse.ui.views.showView" is always disabled [message #503701 is a reply to message #503695] Tue, 15 December 2009 07:08 Go to previous messageGo to next message
I figured it out; I was trying to show views without having set a perspective first. The command works just fine without parameters, but it only shows views who are in your current perspective.
Thanks!
Re: command "org.eclipse.ui.views.showView" is always disabled [message #505135 is a reply to message #503694] Sun, 27 December 2009 10:15 Go to previous message
Hi rmmartins,
Try this in your ApplicationAcationBarAdvisor class
showViewAction = ActionFactory.SHOW_VIEW_MENU.create(window);
register(showViewAction);
Best Regards,
Wim Jongman
-- I think my eyes are getting better. Instead of a big dark blur, I see a
big light blur.
HAN SOLO, Star Wars Episode VI: Return of the Jedi
the following code:
> <extension
> <menuContribution
> <menu
> label="Window">
> <command
> style="push">
> </command>
> </menu>
> </menuContribution>
> </extension>
> What's wrong?
> Thanks in advance!
Previous Topic:RCP and MAC
Next Topic:Always meet bundle missing problem while exporting RCP
Current Time: Sun Aug 31 00:51:10 EDT 2025
Powered by FUDForum. Page generated in 0.03503 seconds
