[QVT] How to process element/package imports to href models/libraries? [message #503620] |
Mon, 14 December 2009 19:26  |
Originally posted by: Nicolas.F.Rouquette.jpl.nasa.gov
In a QVT transformation for UML models, how do I copy from the source model
to the target model an element/package import where the imported
element/package is specified via an href to an external resource?
Below is an example of a model with a package import to an external resource
(the uml primitive types library) and another one where the imported package
is in the model.
<uml:Package xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML"
xmi:id="_HBip8Og2Ed6AGZMjiodrGw" name="M3">
<packageImport xmi:id="_Dxjv0OhKEd6AGZMjiodrGw">
<importedPackage xmi:type="uml:Model"
href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packagedElement xmi:type="uml:Package" xmi:id="_4n_dIOjHEd6Wx9-kamIeQw"
name="P1">
<packagedElement xmi:type="uml:Class" xmi:id="_OJ7B4Og2Ed6AGZMjiodrGw"
name="C1">
<ownedAttribute xmi:id="_OyMBIOhJEd6AGZMjiodrGw" name="size">
<type xmi:type="uml:PrimitiveType"
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</ownedAttribute>
</packagedElement>
</packagedElement>
<packagedElement xmi:type="uml:Package" xmi:id="_6916MOjHEd6Wx9-kamIeQw"
name="P2">
<packageImport xmi:id="_-a-vcOjHEd6Wx9-kamIeQw"
importedPackage="_4n_dIOjHEd6Wx9-kamIeQw"/>
</packagedElement>
</uml:Package>
- Nicolas.
Re: [QVT] How to process element/package imports to href models/libraries? [message #504061 is a reply to message #504045] |
Wed, 16 December 2009 18:05  |
Originally posted by: dvorak.radek.gmail.com
Hi Nicolas,
Seems like I misunderstood your issue.
The modeltype declaration gives you an access, does not solve copying
which you have mentioned in the original post.
The primitive type library is accessible via the model you have posted,
so I only outlined how to copy imported packages from the source
to the target model, thinking your uml model is the input.
/Radek
On Wed, 16 Dec 2009 23:23:52 +0100, Nicolas F Rouquette
<Nicolas.F.Rouquette@jpl.nasa.gov> wrote:
> FYI
> I solved this problem by adding a 'modeltype' declaration for the
> primitive
> types library.
> - Nicolas.
> On 12/14/09 4:26 PM, in article
> C74C17A6.EEC4%Nicolas.F.Rouquette@jpl.nasa.gov, "Rouquette, Nicolas F
>> model
>> resource
>> package
>> is in the model.
>> <?xml version="1.0" encoding="UTF-8"?>
>> </packageImport>
>> name="P1">
>> name="C1">
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> name="P2">
>> </packagedElement>
>> </uml:Package>
>> - Nicolas.
FUDForum. Page generated in 0.06077 seconds
