Home » Eclipse Projects » Rich Client Platform (RCP) » Eclipse product export missing executable binary
Eclipse product export missing executable binary [message #503535] Mon, 14 December 2009 06:00 Go to next message
Greetings,
I have a problem exporting a small plugin based RCP application using Eclipse 3.5SR2 or 3.6M4. The corresponding delta pack is added to the default target platform and the launcher artifacts are added as a dependency.
When exporting everything seems fine, no error message appears. Unfortunately the exported product is missing its executable.
In the target directories "linux.gtk.x86_64/appname" and "win32.win32.x86_64/appname" are only a single file named "artifacts.xml" and two directories "p2" and "plugins". There is no executable binary and the "plugins" directories are missing the launcher artifacts.
Parallel to them is a directory "repositories/plugins" which does contain the launcher artifacts.
I already exported the application successfully using Eclipse 3.4. some month ago but I can't find the missing point in the current configuration.
Any help is appreciated,
M.
Re: Eclipse product export missing executable binary [message #505136 is a reply to message #503535] Sun, 27 December 2009 10:20 Go to previous messageGo to next message
Hi M.
Yes, this sometimes happens to me too. I can never really duplicate the
situation. I always remove the product and rebuild it again. Is your product
plugin listed in the list of plugins?
Best Regards,
Wim Jongman
-- When 900 years old, you reach
Re: Eclipse product export missing executable binary [message #505316 is a reply to message #503535] Tue, 29 December 2009 09:54 Go to previous messageGo to next message
Yes, the product plugin (same as the application plugin) is included in the dependencies.
Do you recreate the default.product file or do you remove and recreate a complete plugin?
Re: Re: Eclipse product export missing executable binary [message #505500 is a reply to message #505316] Thu, 31 December 2009 02:40 Go to previous message
Hi M.
I remove the product file and start over. Also remove all the ...product
extensions in the containing plugin. Why do you call your product "default"?
Best Regards,
Wim Jongman
-- R2-D2, you know better than to trust a strange computer.
C-3PO, Star Wars Episode V: The Empire Strikes Back
dependencies.
complete plugin?
Previous Topic:Javadocs as OSGi Bundle?
Next Topic:Application Menu bar disappears when used OLEControlSite
Current Time: Wed Jul 30 14:56:49 EDT 2025
Powered by FUDForum. Page generated in 0.03881 seconds
