Custum editor: reserved words [message #503472] |
Mon, 14 December 2009 06:33  |
I created, via a plugin in eclipse 3.5, a custom (multipage)editor for an exotic programming language.
I can't figure out how to create reservedwords that are highligted in my editor. Does anybody know how to do this ?
Thx.
Re: Custum editor: reserved words [message #503656 is a reply to message #503536] |
Tue, 15 December 2009 03:45   |
Kitesurfer a écrit :
> I'd like to do it without an addtional framework. Do you perhaps have a
> working example of a WordRule in a RuleBasedScanner ?
Hi Kitesurfer,
Here is an example of what I have done in my plugin. You'll have to
adapt it a little to make it work in your project. I hope this can help you.
1- In your xxxTextEditor class (that extends TextEditor), initialize the
source viewer configuration, like this :
protected void initializeEditor()
super.initializeEditor();
setSourceViewerConfiguration(new XxxSourceViewerConfiguration(this));
2- add xxxSourceViewerConfiguration class that extends
SourceViewerConfiguration to your project.
3- in xxxSourceViewerConfiguration, override getPresentationReconciler
method, and initialize your code scanner in it :
public IPresentationReconciler getPresentationReconciler(ISourceViewer
sourceViewer)
PresentationReconciler reconciler = new PresentationReconciler();
XxxCodeScanner codescanner = new XxxCodeScanner();
DefaultDamagerRepairer dr = new DefaultDamagerRepairer(codescanner);
reconciler.setDamager(dr, IDocument.DEFAULT_CONTENT_TYPE);
reconciler.setRepairer(dr, IDocument.DEFAULT_CONTENT_TYPE);
4- add xxxCodeScanner class that extends RuleBasedScanner to your project
5- in xxxCodeScanner, initialize WordRule, like this :
public xxxCodeScanner()
ArrayList<IRule> rules = new ArrayList<IRule>();
rules.add(new WhitespaceRule(new IWhitespaceDetector()
public boolean isWhitespace(char c)
return (c == ' ' || c == '\t' || c == '\n' || c == '\r');
WordRule wordRule = new WordRule(new IWordDetector()
public boolean isWordPart(char c)
return (Character.isLetterOrDigit(c) || c == '_');
public boolean isWordStart(char c)
return (Character.isLetter(c) || c == '_');
Token instructionToken = new Token(...);
for (String keyword : AllYourKeywords)
wordRule.addWord(keyword, instructionToken);
rules.add(wordRule);
setRules(rules.toArray(new IRule[] {}));
David
Re: Custum editor: reserved words [message #505777 is a reply to message #505448] |
Mon, 04 January 2010 16:59  |
Michael Golovanov wrote on Wed, 30 December 2009 13:57 | OK, you are right, this sample has error
I dont debug this sample yet, but find workarond.
In runned sample create new Generic Project and import your *.xxx file to this project. In my case this help - editor opened without critical errors.
PS Can you write more about exotic programming language syntax from first post?
Your workaround to "activate" the plugin works ... thanks. Strange that the plugin on an extension only works within a project (import an xxx-file, or link to an xxx-file) and doesn't work when just opening an xxx-file outside a project. Is this normal behaviour in Eclipse ?
The exotic programming language is the "Transaction Application Langauge" on an HP-system. It's looks a bit like C but has somewhat other syntax and definitly other keywords.
FUDForum. Page generated in 0.10853 seconds
