Compare with base: edits not detected [message #503209] |
Fri, 11 December 2009 07:00  |
Hi!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=41564
I have the problem described in this bug, but with subversive.
That is:
- edit and save a file
- right click and select Compare With / Base from Working Copy
- in the compare editor, type something in an unchanged part of the file (left pane)
- save (ctrl-s)
Expected result:
- the new difference is marked as such
Actual result:
- the new difference is not marked at all
If I do the same, but select Compare With / Local History..., then it works fine, so it must be something with subversive, I guess.
Eclipse JEE 3.5.1 with subversive and SVNKit (latest versions as of writing, if there is never when you reply, I'll try them...)
David
Re: Compare with base: edits not detected [message #503454 is a reply to message #503209] |
Sun, 13 December 2009 23:58  |
Hello David,
We need to deeper investigate the problem so I created a corresponding bug
on tracker: https://bugs.eclipse.org/bugs/show_bug.cgi?id=297717
Note that you can add yourself to CC to track bug activity.
Thanks.
> Hi!
> That is:
> (left pane)
> - save (ctrl-s)
> Expected result:
> Actual result:
> Regards,
> David
FUDForum. Page generated in 0.04357 seconds
