Home » Eclipse Projects » Buckminster dev » [buckminster-dev] my Hello XML World Buck example stopped working
[buckminster-dev] my Hello XML World Buck example stopped working [message #503404] |
Sat, 12 December 2009 14:56  |
You know yesterday the Bucky example Hello XML World worked fine for
me but today I get this error
ERROR [0001] : CSpec se.tada/tada-sax has no action, group, or
local artifact named java.binary.archives
CSpec se.tada/tada-sax has no action, group, or local artifact named
TAG-ID 0001 = Query for org.demo.hello.xml.world:osgi.bundle
There does not appear to have been a change to the svn repo, so this
must be somthing on my end, but I am clearly baffled.
I really haven't changed anything ... in fact, there's hardly anything
to change. I use the rmap from
http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap and the
cquery copied from page 129 of the Bucky book. Only the project
org.demo.worlds is created, not the other two.
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="http://www.eclipse.org/buckminster/samples/rmaps/demo.rmap">
<cq:rootRequest name="org.demo.hello.xml.world"
componentType="osgi.bundle"/>
</cq:componentQuery>
Each time I try it, I delete the org.demo.worlds project that was made.
I'm using Eclipse 3.6M3.
-Ted
Re: [buckminster-dev] my Hello XML World Buck example stopped working [message #503407 is a reply to message #503404] |
Sat, 12 December 2009 19:02   |
Hi Ted,
What version of Buckminster are you using? From where do yo download it? If you are using the 3.6 platform, then there
might well be fluctuations as we're trying to keep up with the platform milestones. The current milestone is 3.6M4.
Thomas Hallgren
Re: [buckminster-dev] my Hello XML World Buck example stopped working [message #503408 is a reply to message #503407] |
Sun, 13 December 2009 00:47  |
Just tested the demo application using the latest Buckminster for 3.6, the resolution and subsequent build completed
without problems.
- thomas
On 2009-12-13 06:00, Thomas Hallgren wrote:
> Hi Ted,
> If you are using the 3.6 platform, then there might well be fluctuations
> milestone is 3.6M4.
> Regards,
> Thomas Hallgren
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cq:componentQuery
Current Time: Sun Jul 27 09:16:45 EDT 2025
Powered by FUDForum. Page generated in 0.05057 seconds
