DataBinding and Validation Problems [message #503339] |
Fri, 11 December 2009 18:36  |
I have a problem with my validator and the databinding process,
i have the following problem:
I have a text widget who i want to bind to my model, the model have the property Integer, who should save the entered data about the text-widget ... so far, the databinding without validators works, now i want use a simpel validator.
The validator should only check, is the entered data a number and the range of the number, not more. But this does not work, as soon as the validator fails the first time, it checks not the rest of the entered data, e.g. the entered data: 123 ---> validator say Ok
123d --> say false
123ddddd --> validator do nothing, say nothing
The problem is in my opinion the property "Integer" in my model, if i change it to String, then all works perfect ... can someone help me ??
I use any converter.
Re: DataBinding and Validation Problems [message #503440 is a reply to message #503339] |
Mon, 14 December 2009 03:21  |
Thanks Matthew, i have solve my problem:
package de.achmetow.databinding.validator;
import java.beans.PropertyChangeListener;
import java.beans.PropertyChangeSupport;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.UpdateValueStrategy;
import org.eclipse.core.databinding.beans.BeansObservables;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.value.IObservableValue;
import org.eclipse.core.databinding.validation.IValidator;
import org.eclipse.core.databinding.validation.ValidationStatus;
import org.eclipse.core.runtime.IStatus;
import org.eclipse.core.runtime.Status;
import org.eclipse.jface.databinding.swt.ISWTObservableValue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class ValidationProblem
public static final String NAME_PROPERTY = "name_property";
public static void main(String[] args)
Display display = new Display();
final ViewModel viewModel = new ViewModel();
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable()
public void run()
final Shell shell = new View(viewModel).createShell();
// The SWT event loop
Display display = Display.getCurrent();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
// Minimal JavaBeans support
public static abstract class AbstractModelObject
private final PropertyChangeSupport propertyChangeSupport = new PropertyChangeSupport(
this);
public void addPropertyChangeListener(PropertyChangeListener listener)
propertyChangeSupport.addPropertyChangeListener(listener);
public void addPropertyChangeListener(String propertyName,
propertyChangeSupport.addPropertyChangeListener(propertyName, listener);
public void removePropertyChangeListener(PropertyChangeListener listener)
propertyChangeSupport.removePropertyChangeListener(listener);
public void removePropertyChangeListener(String propertyName,
.removePropertyChangeListener(propertyName, listener);
protected void firePropertyChange(String propertyName, Object oldValue,
Object newValue)
.firePropertyChange(propertyName, oldValue, newValue);
public static class Person extends AbstractModelObject
// A property...
private Integer duration;
public Integer getDuration()
return duration;
public void setDuration(Integer duration)
firePropertyChange("duration", this.duration, this.duration = duration);
System.out.println("Model: " + duration);
static class ViewModel
// The model to bind
private final Person person = new Person();
public Person getPerson()
return person;
static class MyValidator implements IValidator
public IStatus validate(Object value)
System.out.println("\nValidator works");
Integer val = null;
try
val = Integer.valueOf((String) value);
catch (NumberFormatException e)
System.out.println("convert failed");
if (val instanceof Integer)
if (val >= 0 && val <= 65000)
System.out.println("correct value: " + val.toString());
return Status.OK_STATUS;
else
System.out.println("Validator failed !");
return ValidationStatus.error("Error ...!!");
else throw new RuntimeException("value is not an Integer!");
// The GUI view
static class View
private final ViewModel viewModel;
private Text name;
public View(ViewModel viewModel)
this.viewModel = viewModel;
public Shell createShell()
// Build a UI
Display display = Display.getDefault();
Shell shell = new Shell(display);
shell.setLayout(new GridLayout(2, false));
name = new Text(shell, SWT.BORDER);
name.setLayoutData(new GridData(GridData.FILL_BOTH));
Button b1 = new Button(shell, SWT.PUSH);
b1.setText("Print Model");
b1.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
System.out.println("\nModelattribut: "
+ viewModel.getPerson().getDuration());
// Bind it
DataBindingContext bindingContext = new DataBindingContext();
Person person = viewModel.getPerson();
ISWTObservableValue widget = SWTObservables.observeText(name, SWT.Modify);
IObservableValue model = BeansObservables
.observeValue(person, "duration");
UpdateValueStrategy strategy = new UpdateValueStrategy();
strategy.setAfterGetValidator(new MyValidator());
bindingContext.bindValue(widget, model, strategy, null);
// Open and return the Shell
shell.pack();
shell.open();
return shell;
FUDForum. Page generated in 0.03935 seconds
