Home » Modeling » EMF » [CDO] Using 3.0(How to obtain or build the development stream)
[CDO] Using 3.0 [message #503255] Fri, 11 December 2009 10:56 Go to next message
I would like to give CDO 3.0 a try and I have a few questions:
1. Are there built releases available for download yet or do I need to get the source from CVS and build it?
2. What are the dependencies? Can I stay with Eclipse 3.5 or is it dependent on other 3.6 project streams, e.g. EMF?
3. There is a wiki CDO Source Installation That appears to be for setting CDO 2.0 source in a pre-release Eclipse 3.5 environment. Is this article at all applicable to setting up 3.0?
Any advice on getting this together as painlessly as possible would be much appreciated Smile
Joel
Re: [CDO] Using 3.0 [message #503308 is a reply to message #503255] Fri, 11 December 2009 13:07 Go to previous messageGo to next message
Joel,
comments below:
Joel Rosi-Schwartz escribió:
No, releases available yet, sorry.
As far as I know, no Eclipse 3.6 runtime dependencies yet, nor EMF 2.6 :)
> 3. There is a wiki http://wiki.eclipse.org/CDO_Source_Installation
Yes, this document is applicable to setting 3.0. The only thing you
would need to change is the API baseline, but you can skip that step if
you want.
It might be the case that the script misses some source plugins. I case
you find some of those, please report us and we will fix it.
I experienced some problems with HibernateStore sources, but since I
didn't need it, I skipped it. Martin would jump in, in case you are
interested :)
> much appreciated :)
I'm just going to try this tutorial, so I'll probably find problems if any.
We would kindly assist you whenever needed :)
> Cheers,
> Joel
Cheers!
Re: [CDO] Using 3.0 [message #503309 is a reply to message #503255] Fri, 11 December 2009 13:19 Go to previous messageGo to next message
I just checked, and I beleive Eike took the trouble to keep those
updated, so the PSF should work fine :) Let us know if you find any problem.
> much appreciated :)
> Cheers,
> Joel
Re: [CDO] Using 3.0 [message #503311 is a reply to message #503309] Fri, 11 December 2009 13:33 Go to previous messageGo to next message
Victor,
Thanks for both replies. I also ran into a post for nightly builds from Hudson at Project cbi-emf-net4j-cdo-3.0. Would using this be more more straightforward to get an environment set up to test out 3.0?
Joel
Victor Roldan Betancort wrote on Fri, 11 December 2009 18:19
updated, so the PSF should work fine Smile Let us know if you find any problem.
Re: [CDO] Using 3.0 [message #503315 is a reply to message #503311] Fri, 11 December 2009 13:54 Go to previous messageGo to next message
Joel,
> Hudson at
https://build.eclipse.org/hudson/view/Modeling/job/cbi-emf-n et4j-cdo-3.0/
> up to test out 3.0?
I haven't tried out the new build system, so I didn't think of this
alternative, neither I can't confirm how "straigforward" is to deploy
these builds, but I guess it is as easy (or hard :P) as our former build
system.
Hope Eike can jump in for this.
Re: [CDO] Using 3.0 [message #503359 is a reply to message #503315] Fri, 11 December 2009 22:28 Go to previous messageGo to next message
Hi guys,
The "nightly" builsd on Hudson are in fact CI builds and they're fully
tested. They'd differ from I, S or R builds mostly in that they're not
signed or packed.
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> Joel,
> > Hudson at
> > up to test out 3.0?
> build system.
Re: [CDO] Using 3.0 [message #503399 is a reply to message #503359] Sat, 12 December 2009 17:42 Go to previous messageGo to next message
--------------030608070105080203060709
Eike Stepper schrieb:
> Hi guys,
> signed or packed.
I can confirm that the N-Builds work well
I always use the latest "green" Build, download the update-site and use
this as Local Updatesite in IDE or TargetPlatform
you dont have to unzip - simply choose the archive
works using Galileo or Helios
ekke
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Joel,
>> from
>> > Hudson at
>> set
>> > up to test out 3.0?
>> build system.
ekke (ekkehard gentz)
independent software-architect
senior erp-consultant
eclipse | osgi | equinox | mdsd | oaw | emf | uml
max-josefs-platz 30, D-83022 rosenheim, germany
mailto:ekke@ekkes-corner.org
homepage (de): http://gentz-software.de
blog (en): http://ekkes-corner.org
twitter: @ekkescorner
skype: ekkes-corner
Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID: DE189929490
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
<blockquote cite="mid:hfvk4i$j9h$2@build.eclipse.org" type="cite">Hi
guys,
<br>
<br>
signed or packed.
<br>
<br>
</blockquote>
I can confirm that the N-Builds work well<br>
this as Local Updatesite in IDE or TargetPlatform<br>
you dont have to unzip - simply choose the archive<br>
<br>
works using Galileo or Helios<br>
<br>
ekke<br>
<blockquote cite="mid:hfvk4i$j9h$2@build.eclipse.org" type="cite">Cheers
<br>
/Eike
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a>
<br>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Joel,
<br>
<br>
&gt; Thanks for both replies. I also ran into a post for nightly builds
from
<br>
&gt; Hudson at
<br>
&gt;
<a class="moz-txt-link-freetext" href=" https://build.eclipse.org/hudson/view/Modeling/job/cbi-emf-n et4j-cdo-3.0/"> https://build.eclipse.org/hudson/view/Modeling/job/cbi-emf-n et4j-cdo-3.0/</a>.
<br>
&gt; Would using this be more more straightforward to get an
environment set
<br>
&gt; up to test out 3.0?
<br>
<br>
build system.
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
<div class="moz-signature">-- <br>
<p style="margin-bottom: 0cm;"> <font ,="" color="#808080"
face="Verdana, sans-serif"> <font size="4">ekke (ekkehard gentz)<br>
</font> <font size="3"> independent software-architect<br>
senior erp-consultant<br>
</font> <font size="2">eclipse | osgi | equinox | mdsd | oaw | emf |
uml<br>
max-josefs-platz 30, D-83022 rosenheim, germany<br>
<a class="moz-txt-link-freetext" href="mailto:ekke@ekkes-corner.org">mailto:ekke@ekkes-corner.org</a><br>
homepage (de): <a class="moz-txt-link-freetext" href="http://gentz-software.de">http://gentz-software.de</a><br>
blog (en): <a class="moz-txt-link-freetext" href="http://ekkes-corner.org">http://ekkes-corner.org</a><br>
twitter: @ekkescorner<br>
skype: ekkes-corner<br>
</font> <font size="1"> Steuer-Nr: 156/220/30931 FA Rosenheim, UST-ID:
DE189929490<br>
</font> </font> </p>
</div>
</body>
</html>
--------------030608070105080203060709--
Re: [CDO] Using 3.0 [message #503521 is a reply to message #503399] Mon, 14 December 2009 10:22 Go to previous messageGo to next message
Ekke, Eike,
Thank you both the update site works a treat.
Joel
Re: [CDO] Using 3.0 [message #503526 is a reply to message #503309] Mon, 14 December 2009 10:34 Go to previous messageGo to next message
Just in case anyone is interested. As Victor said, CDO 3.0 itself is not dependent on EMF 2.6. However the org.gastro.business sample does seem to be.
Joel
Victor Roldan Betancort wrote on Fri, 11 December 2009 18:07
Joel,
comments below:
As far as I know, no Eclipse 3.6 runtime dependencies yet, nor EMF 2.6 Smile
Re: [CDO] Using 3.0 [message #503558 is a reply to message #503526] Mon, 14 December 2009 11:53 Go to previous messageGo to next message
> seem to be.
Although it's not too important, I'm curious: What exactly in the gastro
example is not compatible with pre-EMF-3.6?
Cheers
/Eike
> Cheers,
> Joel
>> Joel,
>> comments below:
>> it > dependent on other 3.6 project streams, e.g. EMF?
>> 2.6 :)
Re: [CDO] Using 3.0 [message #503561 is a reply to message #503558] Mon, 14 December 2009 12:24 Go to previous messageGo to next message
Three plugins have EMF 2.6 dependencies as below. The balance of the compile problems just seem to be overflows from these 3 not building.
Description	Resource	Path	Location	Type
Unsatisfied version constraint: 'org.eclipse.emf.edit: [2.6.0,3.0.0)'	MANIFEST.MF	/org.gastro.business.edit/META-INF	line 13	Plug-in Problem
Unsatisfied version constraint: 'org.eclipse.emf.ecore: [2.6.0,3.0.0)'	MANIFEST.MF	/org.gastro.inventory/META-INF	line 14	Plug-in Problem
Unsatisfied version constraint: 'org.eclipse.emf.ecore: [2.6.0,3.0.0)'	MANIFEST.MF	/org.gastro.business/META-INF	line 14	Plug-in Problem
Eike Stepper wrote on Mon, 14 December 2009 16:53
> seem to be.
Cheers
/Eike
> Cheers,
> Joel
>> Joel,
>> comments below:
>> 2.6 Smile
Re: [CDO] Using 3.0 [message #503572 is a reply to message #503561] Mon, 14 December 2009 12:52 Go to previous message
Hi Joel,
Thanks for letting me know. I fixed these dependencies to 2.4-3.0.
Cheers
/Eike
> 14 Plug-in Problem
>> > seem to be.
>> Cheers
>> /Eike
>> > Cheers,
>> > Joel
>> >> Joel,
>> >> comments below:
>> >> 2.6 :)
Previous Topic:Modifying properties view (combo box value)
Next Topic:[teneo] delete not the references
Current Time: Thu Jul 24 20:21:40 EDT 2025
Powered by FUDForum. Page generated in 1.06533 seconds
