Home » Eclipse Projects » Buckminster dev » Coding style
Coding style [message #503170] Thu, 10 December 2009 23:22 Go to next message
Buckminster uses a coding style that differs from the one used by the majority of the projects at Eclipse.org. In
particular, we put the '{' on a new line, i.e.
int size()
return size;
instead of:
int size() {
return size;
For historical reasons (before syntax coloring made the distinction really easy), we also prefix our fields with m_ or
s_, i.e.
private int m_size;
rather than
private int size;
I think it might be time to abandon our own style.
What's your opinion?
Thomas Hallgren
Re: Coding style [message #503211 is a reply to message #503170] Fri, 11 December 2009 07:10 Go to previous messageGo to next message
but unsure of what you are proposing we should do - change everything???
- henrik
On 12/11/09 10:12 AM, Thomas Hallgren wrote:
> majority of the projects at Eclipse.org. In particular, we put the '{'
> on a new line, i.e.
> int size()
> return size;
> instead of:
> int size() {
> return size;
> really easy), we also prefix our fields with m_ or s_, i.e.
> private int m_size;
> rather than
> private int size;
> Regards,
> Thomas Hallgren
Re: Coding style [message #503213 is a reply to message #503211] Fri, 11 December 2009 07:17 Go to previous messageGo to next message
On 2009-12-11 13:10, Henrik Lindberg wrote:
> +1
Yes, we would change the "Buckminster Coding Style" and run a source clean-up on all code.
- thomas
Re: Coding style [message #503433 is a reply to message #503170] Mon, 14 December 2009 01:44 Go to previous messageGo to next message
The aggregator uses generated code, which doesn't follow the buckminster
coding style anyway (field prefixes).
Karel
Thomas Hallgren napsal(a):
> on a new line, i.e.
> int size()
> return size;
> instead of:
> int size() {
> return size;
> private int m_size;
> rather than
> private int size;
> Regards,
> Thomas Hallgren
Re: Coding style [message #503445 is a reply to message #503213] Mon, 14 December 2009 03:49 Go to previous messageGo to next message
We have been talking about this for a few weeks in Pilsen. You were just faster in introducing this topic here :-)
I myself never liked the bucky coding style, so I will appreciate the change very much.
Once we change the coding style rules, we will have to (except the cleanup) refactor the field names manually. I don't think that they will change automatically.
Filip
>> +1
> - thomas
Re: Coding style [message #512811 is a reply to message #503170] Sun, 07 February 2010 17:26 Go to previous messageGo to next message
I just released the cocing style change to the SVN trunk which means that we now have a new revision of all java code.
It will be hard to make history comparisons that span over this revision. Such comparisons will likely need to be split
in two. Prior and after the coding style change.
- thomas
On 12/11/2009 10:12 AM, Thomas Hallgren wrote:
> on a new line, i.e.
> int size()
> return size;
> instead of:
> int size() {
> return size;
> private int m_size;
> rather than
> private int size;
> Regards,
> Thomas Hallgren
Re: Coding style [message #512814 is a reply to message #512811] Sun, 07 February 2010 19:06 Go to previous message
Finally !
(I have always hated the m_, and s_ prefixes...)
- henrik
> that we now have a new revision of all java code. It will be hard to
> will likely need to be split in two. Prior and after the coding style
> change.
> - thomas
>> Hi,
>> on a new line, i.e.
>> int size()
>> return size;
>> instead of:
>> int size() {
>> return size;
>> private int m_size;
>> rather than
>> private int size;
>> Regards,
>> Thomas Hallgren
Previous Topic:[buckminster-dev] Project meta data is out of date for tools.buckminster
Next Topic:[buckminster-dev] Downloading source jars
Current Time: Fri Jul 25 19:49:37 EDT 2025
Powered by FUDForum. Page generated in 0.04619 seconds
