Home » Archived » XML Schema Definition (XSD) » XSDEditor can only create element of string type
XSDEditor can only create element of string type [message #50303] Mon, 16 August 2004 05:57 Go to next message
Originally posted by: daniel_leo.163.com
I am using the XSDItemProvider to construct a TreeView , as XSDEditor
syntax does. But I found that the XSDEditor can only create element of
string type. Even if you select the element of string type and all the
related info are displayed in the PropertyView, the type definition can
not be modifed. But other info can be modified, such as the "Name" and
"Target Namespace". Is it the shortage of XSD itself? Or I use the XSD
incorrectly?
I mean maybe the XSD itself can not support edit type definition of
element in SyntaxView( of XSDEditor ).
Brs/
daniel leo
Re: XSDEditor can only create element of string type [message #50333 is a reply to message #50303] Mon, 16 August 2004 08:00 Go to previous message
--------------040408000403010000050500
Daniel,
It's just not been enabled:
protected void createTypeDefinitionPropertyDescriptor(Object object)
XSDElementDeclaration xsdElementDeclaration =
((XSDElementDeclaration)object);
// This is for the typeDefinition feature.
itemPropertyDescriptors.add
(new DelegatingItemPropertyDescriptor
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(),
XSDEditPlugin.getString("_UI_TypeDefinition_label"),
XSDEditPlugin.getString("_UI_TypeDefinitionOfElement_description "),
xsdPackage.getXSDElementDeclaration_TypeDefinition(),
*false*,
null));
I tried enabling it, and it seems to work okay (but the drop down list
should filter out anonymous types).
daniel leo wrote:
>Hi,
>incorrectly?
>Thanks:)
>Brs/
>daniel leo
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Daniel,<br>
<br>
It's just not been enabled:<br>
<blockquote>
Re: XSDEditor can only create element of string type [message #590198 is a reply to message #50303] Mon, 16 August 2004 08:00 Go to previous message
Daniel,
*false*,
null));
daniel leo wrote:
>Hi,
>incorrectly?
>Thanks:)
>Brs/
>daniel leo
<html>
<head>
<title></title>
</head>
Daniel,<br>
<br>
<blockquote>
Previous Topic:XSDEditor can only create element of string type
Next Topic:What about the future of XSDEdit?
Current Time: Fri Sep 19 10:55:45 EDT 2025
Powered by FUDForum. Page generated in 0.05796 seconds
