Home » Modeling » GMF (Graphical Modeling Framework) » How can I use a custom GridLayer in the Editor?
How can I use a custom GridLayer in the Editor? [message #502505] Tue, 08 December 2009 10:17 Go to next message
I'm using Compartments in my model which have a GridLayout. To visualize
the grid of my layout manager, I would like to draw some horizontal and
vertical lines.
Probably the best practice would be to override the GridLayer of the
Editor whith a custom implementation.
So how can I replace the default GridLayerEx whith a custom
GridLayer-Implementation? On which location can I integrate my own
GridLayer into the generated Editor-Code?
Thank you very much for your answer.
Marco
Re: How can I use a custom GridLayer in the Editor? [message #502753 is a reply to message #502505] Wed, 09 December 2009 10:16 Go to previous messageGo to next message
Don't know if there is a better way, but this is how I did:
Add an edit part provider to provide the root edit part of the diagram.
See the extension point org.eclipse.gmf.runtime.diagram.ui.editpartProviders
My RootEditPart extends the standard gmf
org.eclipse.gmf.runtime.diagram.ui.render.editparts.Rendered DiagramRootEditPart
Override the two createGridLayer() methods to provide your own GridLayer.
I think a few times in the code the GridLayer is cast to
org.eclipse.gmf.runtime.diagram.ui.internal.editparts.GridLa yerEx
without a check, so I suggest your GridLayer class extends it.
Daniel
Marco wrote:
> Hello,
> vertical lines.
> Regards,
> Marco
Re: How can I use a custom GridLayer in the Editor? [message #502947 is a reply to message #502753] Thu, 10 December 2009 07:06 Go to previous messageGo to next message
Hello Daniel,
thank you for your reply!
I have created my own edit part provider and contributed it over the
extension point "org.eclipse.gmf.runtime.diagram.ui.editpartProviders"
But my "createRootEditPart"-method (where I return my custom
RootEditPart) is never invoked.
Which methods did you override in your edit part provider to get access
to the root edit part of the diagram?
Could you provide me some example-code, please? Thank you very much!
Marco
Daniel Beland schrieb:
> Cheers,
> Daniel
> Marco wrote:
>> Hello,
>> visualize the grid of my layout manager, I would like to draw some
>> horizontal and vertical lines.
>> Regards,
>> Marco
Re: How can I use a custom GridLayer in the Editor? [message #503036 is a reply to message #502947] Thu, 10 December 2009 10:38 Go to previous messageGo to next message
Hi Marco,
You need to configure the edit part provider correctly.
Set a higher priority than the current one (I've put highest).
In the context you must specify it provides the root edit part.
<extension point="org.eclipse.gmf.runtime.diagram.ui.editpartProviders "
id="my-ep-provider">
<editpartProvider class="a.b.RootPartProvider">
<Priority name="Highest">
</Priority>
<context providesRootEditPart="true">
</context>
</editpartProvider>
</extension>
Then the createRootEditPart method will be called.
public RootEditPart createRootEditPart(Diagram diagram) {
return new MyDiagramRootEditPart(diagram.getMeasurementUnit());
Daniel
Marco wrote:
> Hello Daniel,
> Regards,
> Marco
>> Hi,
>> Cheers,
>> Daniel
>> Marco wrote:
>>> Hello,
>>> Regards,
>>> Marco
Re: How can I use a custom GridLayer in the Editor? [message #503252 is a reply to message #503036] Fri, 11 December 2009 10:37 Go to previous message
Thank you, Daniel. I got it working this way.
> Hi Marco,
> </Priority>
> </context>
> </editpartProvider>
> </extension>
> Cheers,
> Daniel
> Marco wrote:
>> Hello Daniel,
>> access to the root edit part of the diagram?
>> Regards,
>> Marco
>>> Hi,
>>> GridLayer.
>>> Cheers,
>>> Daniel
>>> Marco wrote:
>>>> Hello,
>>>> Regards,
>>>> Marco
Previous Topic:ErrorMessage when Export As SVG
Next Topic:execute template
Current Time: Sun Jul 27 07:49:53 EDT 2025
Powered by FUDForum. Page generated in 0.03584 seconds
