Home » Archived » Visual Editor (VE) » [ANN] XWT Designer
[ANN] XWT Designer [message #494849] Mon, 02 November 2009 17:22 Go to next message
Hi all,
I have posted a message in my blog about our XWT Designer contribution:
http://dev.eclipse.org/blogs/yvesyang/2009/11/02/xwt-designe r/
Please note tt is available for download from
http://www.xwtdesigner.org/update and feel free to test it. Any feedback is
welcome.
Soyatec has planned to contribute it as a sub project of VE. It is second
important contribution, but not last.
Best regards
Yves YANG
Re: [ANN] XWT Designer [message #496443 is a reply to message #494849] Tue, 10 November 2009 01:49 Go to previous messageGo to next message
Yves YANG 写道:
> Hi all,
> welcome.
> Best regards
> Yves YANG
Thank you very much!
I'm going to test it.
Re: [ANN] XWT Designer [message #496468 is a reply to message #494849] Tue, 10 November 2009 03:34 Go to previous messageGo to next message
Many thanks for your contrib!
Mik
----- Original Message -----
Newsgroups: eclipse.tools.ve
Sent: Monday, November 02, 2009 11:22 PM
Subject: [ANN] XWT Designer
> Hi all,
> is welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #496549 is a reply to message #494849] Tue, 10 November 2009 09:00 Go to previous messageGo to next message
Hi Yves Yang,
I've tried the XWT Designer,but failed:
I'm using the "eclipse-e4-SDK-incubation-1.0M1-win32" and install the
XWT Designer successful;
Then I create the "XWT UI Presentation", and there is no problem to open
the xwt file with "xwt Editor", but when I open it by with "XWT
Designer", the following error occurs. If I miss some steps?
java.lang.NoClassDefFoundError: org/eclipse/e4/xwt/internal/utils/UserData
at
com.soyatec.xwt.tools.ui.designer.loader.ResourceVisitor.loa dCLR(ResourceVisitor.java:970)
at
com.soyatec.xwt.tools.ui.designer.loader.ResourceVisitor.doC reate(ResourceVisitor.java:400)
at
com.soyatec.xwt.tools.ui.designer.loader.ResourceVisitor.cre ateCLRElement(ResourceVisitor.java:271)
at com.soyatec.xwt.tools.ui.designer.loader.XWTProxy.load(XWTPr oxy.java:71)
at com.soyatec.xwt.tools.ui.designer.loader.XWTProxy.load(XWTPr oxy.java:100)
at
com.soyatec.xwt.tools.ui.designer.editor.render.XWTVisualsRe nder.createVisuals(XWTVisualsRender.java:344)
at
org.soyatec.tools.designer.editor.Designer.setupGraphicalVie wer(Designer.java:316)
at
com.soyatec.xwt.tools.ui.designer.editor.XWTDesigner.setupGr aphicalViewer(XWTDesigner.java:173)
at
org.soyatec.tools.designer.editor.Designer$3.runInUIThread(D esigner.java:287)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:95)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3860)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3481)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2818)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2782)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:26 34)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:562)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:555)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:367)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 610)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:565)
at org.eclipse.equinox.launcher.Main.run(Main.java:1362)
Thanks!
Yves YANG 写道:
> Hi all,
> welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #496730 is a reply to message #496549] Wed, 11 November 2009 03:21 Go to previous messageGo to next message
OK, I've fixed that by the following steps:
1, down the "eclipse-e4-SDK-incubation-1.0M1-win32"
2, install the latest "XWT" from
" http://download.eclipse.org/e4/downloads/drops/I20091105-210 0/repository"
3, install the "XWT Designer"
Then it works!
Jack Liao 写道:
> Hi Yves Yang,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Thanks!
> Yves YANG 写道:
>> Hi all,
>> welcome.
>> Best regards
>> Yves YANG
Re: [ANN] XWT Designer [message #496777 is a reply to message #496730] Wed, 11 November 2009 06:05 Go to previous messageGo to next message
Hi Jack,
Thanks for your feedback.
I'm sorry I forget mention the last build.
Best regards
Yves YANG
Soyatec
"Jack Liao" <liaoqiancheng@cjitec.com> wrote in message
news:hdds7b$dne$1@build.eclipse.org...
> Then it works!
> Jack Liao д
Re: [ANN] XWT Designer [message #496778 is a reply to message #494849] Wed, 11 November 2009 06:09 Go to previous messageGo to next message
Finally, we decide to incubate XWT Designer in e4, We believe having it
closer to XWT would benefit both XWT and XWT Designer. We can imagine moving
XWT Designer under VE when it is no longer in incubation. This editor can be
extended to support e4 Modeled workbench to have a complete VE for e4.
Best regards
Yves YANG
"Yves YANG" <yves.yang@soyatec.com> wrote in message
news:hcnm3c$j21$1@build.eclipse.org...
> Hi all,
> is welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #498875 is a reply to message #494849] Wed, 18 November 2009 17:15 Go to previous messageGo to next message
Is the source available anywhere or will it only be available when this becomes an Eclipse project?
I was able to get the XWT editor working on OpenSolaris X86 by modifying org.eclipse.e4.xwt.vex to include a solaris libswt-gtk-print.so, similar to my success with VE on OpenSolaris.
I'd like to do the same with org.soyatec.tools.imagecapture which includes the equivalent native libraries for XWT designer.
Re: [ANN] XWT Designer [message #499602 is a reply to message #496778] Mon, 23 November 2009 08:49 Go to previous messageGo to next message
I found there is a litter bug with the editor, it's about the hot key
"delete".
After created several controls in the editor, I chose all of them and
click "delete" key on the keyboard, just as to delete them, but failed,
only one of them was deleted.
Then the "undo", "redo" couldn't work as normal.
Yves YANG 写道:
> Best regards
> Yves YANG
>> Hi all,
>> is welcome.
>> Best regards
>> Yves YANG
Re: [ANN] XWT Designer [message #499603 is a reply to message #499602] Mon, 23 November 2009 09:09 Go to previous messageGo to next message
Hi, all
The disable of "undo","redo" was because I clicked "Ctrl+S" to save the
file.
It seems that when a xwt file be saved, the command stack was cleaned?
Jack Liao 写道:
> "delete".
> Yves YANG 写道:
>> Best regards
>> Yves YANG
>>> Hi all,
>>> is welcome.
>>> Best regards
>>> Yves YANG
Re: [ANN] XWT Designer [message #499725 is a reply to message #499602] Mon, 23 November 2009 15:47 Go to previous messageGo to next message
We'll look at it. Thanks
yves
"Jack Liao" <jack.liao1983@gmail.com> wrote in message
news:hee3t7$lqk$1@build.eclipse.org...
> "delete".
> Yves YANG д
Re: [ANN] XWT Designer [message #502405 is a reply to message #498875] Mon, 07 December 2009 21:36 Go to previous messageGo to next message
It is a version for solaris compiled for Solaris or you have used one for
Linux? Where do you copy?
yves
"Porter" <rodneyh@bigpond.net.au> wrote in message
news:he1rms$ae6$1@build.eclipse.org...
Re: [ANN] XWT Designer [message #502406 is a reply to message #498875] Mon, 07 December 2009 21:37 Go to previous messageGo to next message
yves
Re: [ANN] XWT Designer - solaris update and linux/solaris design rendering [message #502463 is a reply to message #502406] Tue, 08 December 2009 06:58 Go to previous messageGo to next message
Yves
Yes I compiled libswt-gtk-print.so for solaris x86. Please see my recent thread on this forum regarding VE on opensolaris. The native library source code and makefile is available on the VE 1.4 CVS in the same plugin that includes the native libraries for linux, windows and mac osx.
Now, I noticed that the latest incubation release of E4 includes the source code for XWT designer as well as the earlier XWT editor (the 2009.1204 version). So I modified the following plugins to include my opensolaris native lib, just like I did for VE.
org.eclipse.e4.xwt.tools.ui.imagecapture_0.9.1.v20091204-083 0 and
org.eclipse.e4.xwt.vex_0.9.1.v20091203-1000
I tested these modifed versions on Opensolaris X86 (Dev release 127) and I also tested unmodified versions on Centos 5.4 x86 (both 32 bit). Both are running gnome/gtk. Both XWT editor and designer run on opensolaris with these mods.
I noticed on both systems that the visual rendering of the UI elements/widgets being designed is much better in the XWT editor than in the XWT designer. With XWT editor the UI appears exactly as it should, in XWT designer it is basically just a flat frame, and widgets can only be seen in outline (like a wire frame outline). On linux the ui element/widget is basically a grey featureless box with swt elements in black outline. Opensolaris is giving a similar result but black on white.
I ran a debug workbench on both Centos and Solaris and set a breakpoint in the unix ImageCapture class, on the method getImage (package org.eclipse.ve.internal.swt.targetvm.unix in plugin org.eclipse.e4.xwt.tools.ui.imagecapture). I was surprised to see this method breakpoint hit when opening in the XWT editor but never when using the XWT designer. Perhaps this is related as it seems that under GTK, XWT designer isn't picking up the image (or the relevant part) that XWT editor picks up. This is leading to the incorrect rendering under gtk linux/unix. It looked better on my wife's windows vista machine. I realise the opensolaris test is non-standard but I now have both VE and XWT working on solaris at least as well as on linux.
Wish I could attach screen shots but the file attachments feature doesn't seem to work from firefox or opera.
Porter
[Updated on: Tue, 08 December 2009 07:41] by Moderator
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #502464 is a reply to message #494849] Tue, 08 December 2009 07:12 Go to previous messageGo to next message
Are these on the radar at all for XWT editor/designer or only if the community steps up?
What about view and edit parts or are these less relevant with E4?
[Updated on: Tue, 08 December 2009 07:50] by Moderator
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #502591 is a reply to message #502464] Tue, 08 December 2009 07:16 Go to previous messageGo to next message
Sorry, What do you mean ?
yves
news:hflfsf$adl$1@build.eclipse.org...
> community steps up?
Re: [ANN] XWT Designer - solaris update and linux/solaris design rendering [message #502594 is a reply to message #502463] Tue, 08 December 2009 07:26 Go to previous messageGo to next message
I appreciate your contribution. You mean you have committed in CVS of VE in
eclipse ?
I'm surpised. I'm not sure you are the commiter of VE. How could you commit
in VE CVS? and I didn't find it either in CVS of eclipse.
yves
news:hflf1o$v58$1@build.eclipse.org...
> Yves
> these mods.
> Porter
Re: [ANN] XWT Designer - solaris update and linux/solaris design rendering [message #502599 is a reply to message #502463] Tue, 08 December 2009 09:28 Go to previous messageGo to next message
We'll check it out.
yves
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #502652 is a reply to message #502591] Wed, 09 December 2009 05:03 Go to previous messageGo to next message
yves
"Porter"wrote in message
> community steps up?
--> I mean is there any planned support for eclipse forms, nebula widgets, and creating view parts and edit parts, using XWT designer or XWT editor? Or would this support only happen if a contribution comes from the eclipse community?
We'll check it out.
----> Thanks for checking it out look forward to hearing the result.
eclipse ?
---> No, I'm not a committer of VE. I simply mean that by downloading the source code and make file for the native library (unix version) from eclipse CVS here:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.ve/plug ins/org.eclipse.ve.swt/native-src/swt-gtk-print-src.zip?root =Tools_Project&view=co
then I was able to compile libswt-gtk-print for solaris and get VE and XWT editor/designer working on my local solaris system by rebuilding the relevant VE and XWT plugins to include this lib. I needed to slightly change the makefile. I would be happy to contribute back if there is a way. This would require a little further work on the makefile so it works for both linux and solaris and obviously some integration into the VE build process. Does the VE build process include rebuilding the native libs from source or only including their binaries?
[Updated on: Wed, 09 December 2009 05:04] by Moderator
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #502692 is a reply to message #502652] Wed, 09 December 2009 08:11 Go to previous messageGo to next message
PS Yves Would you mind removing my email address from your posts above? I set the control panel to not show email address but it came up in your replies. Worried about spam.
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #502708 is a reply to message #502692] Wed, 09 December 2009 09:04 Go to previous messageGo to next message
Hmmm... beware that your e-mail address appears in the "From" field of
all of your posts ;-)
Mauro.
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #503362 is a reply to message #502652] Fri, 11 December 2009 22:37 Go to previous message
news:hfnsku$r2c$1@build.eclipse.org...
> yves
> "Porter"wrote in message news:hflfsf$adl$mailto:1@build.eclipse.org...
>> community steps up?
> community?
XWT supports already eclipse forms in 1.0M2. As for Nebula, it is supported
directly. But we haven't time to work on XWT designer. We have more
important work to do. such as e4 Designer.Any contributions are welcome.
> We'll check it out.
It will be fixed in 1.0M3.
> in eclipse ?
> commit in VE CVS? and I didn't find it either in CVS of eclipse.
> ---> No, I'm not a committer of VE. I simply mean that my downloading the
> eclipse CVS here:
Could you provide the binary? We can integrate in VE. For doing this, you
need to open a bug in bugzilla and attach all your files.
Best regards
Yves YANG
Re: [ANN] XWT Designer [message #617447 is a reply to message #494849] Tue, 10 November 2009 01:49 Go to previous message
Yves YANG 写道:
> Hi all,
> welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #617449 is a reply to message #494849] Tue, 10 November 2009 03:34 Go to previous message
Mik
> Hi all,
> is welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #617450 is a reply to message #494849] Tue, 10 November 2009 09:00 Go to previous message
Hi Yves Yang,
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Thanks!
Yves YANG 写道:
> Hi all,
> welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #617462 is a reply to message #496549] Wed, 11 November 2009 03:21 Go to previous message
Then it works!
Jack Liao 写道:
> Hi Yves Yang,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks!
> Yves YANG 写道:
>> Hi all,
>> welcome.
>> Best regards
>> Yves YANG
Re: [ANN] XWT Designer [message #617466 is a reply to message #496730] Wed, 11 November 2009 06:05 Go to previous message
Hi Jack,
Best regards
Yves YANG
Soyatec
> Then it works!
> Jack Liao д
Re: [ANN] XWT Designer [message #617469 is a reply to message #494849] Wed, 11 November 2009 06:09 Go to previous message
Best regards
Yves YANG
> Hi all,
> is welcome.
> Best regards
> Yves YANG
Re: [ANN] XWT Designer [message #617488 is a reply to message #494849] Wed, 18 November 2009 17:15 Go to previous message
Re: [ANN] XWT Designer [message #617520 is a reply to message #496778] Mon, 23 November 2009 08:49 Go to previous message
"delete".
Yves YANG 写道:
> Best regards
> Yves YANG
>> Hi all,
>> is welcome.
>> Best regards
>> Yves YANG
Re: [ANN] XWT Designer [message #617521 is a reply to message #499602] Mon, 23 November 2009 09:09 Go to previous message
Hi, all
file.
Jack Liao 写道:
> "delete".
> Yves YANG 写道:
>> Best regards
>> Yves YANG
>>> Hi all,
>>> is welcome.
>>> Best regards
>>> Yves YANG
Re: [ANN] XWT Designer [message #617523 is a reply to message #499602] Mon, 23 November 2009 15:47 Go to previous message
yves
> "delete".
> Yves YANG д
Re: [ANN] XWT Designer [message #617551 is a reply to message #498875] Mon, 07 December 2009 21:36 Go to previous message
yves
Re: [ANN] XWT Designer [message #617553 is a reply to message #498875] Mon, 07 December 2009 21:37 Go to previous message
yves
Re: [ANN] XWT Designer - solaris update and linux/solaris design rendering [message #617555 is a reply to message #502406] Tue, 08 December 2009 06:58 Go to previous message
Yves
Porter
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #617557 is a reply to message #494849] Tue, 08 December 2009 07:13 Go to previous message
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #617559 is a reply to message #617557] Tue, 08 December 2009 07:16 Go to previous message
yves
> community steps up?
Re: [ANN] XWT Designer - solaris update and linux/solaris design rendering [message #617562 is a reply to message #617555] Tue, 08 December 2009 07:26 Go to previous message
eclipse ?
yves
> Yves
> these mods.
> Porter
Re: [ANN] XWT Designer - solaris update and linux/solaris design rendering [message #617563 is a reply to message #617555] Tue, 08 December 2009 09:28 Go to previous message
We'll check it out.
yves
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #617565 is a reply to message #502591] Wed, 09 December 2009 05:03 Go to previous message
yves
> community steps up?
We'll check it out.
eclipse ?
---> No, I'm not a committer of VE. I simply mean that my downloading the source code and make file for the native library (unix version) from eclipse CVS here:
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #617568 is a reply to message #617565] Wed, 09 December 2009 08:11 Go to previous message
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #617572 is a reply to message #617568] Wed, 09 December 2009 09:04 Go to previous message
Mauro.
Re: [ANN] XWT Designer - Eclipse Forms, Nebula [message #617574 is a reply to message #617565] Fri, 11 December 2009 22:37 Go to previous message
> yves
>> community steps up?
> community?
> We'll check it out.
> in eclipse ?
> eclipse CVS here:
Best regards
Yves YANG
Previous Topic:No more visual class after importing project
Next Topic:How can I view the visual components from a class that extends from an abstract class?
Current Time: Tue Jul 22 21:31:31 EDT 2025
Powered by FUDForum. Page generated in 0.08482 seconds
