Home » Modeling » EMF » eIsSet and multiple inheritance
eIsSet and multiple inheritance [message #501488] Wed, 02 December 2009 09:40 Go to next message
I have a multiple inheritance with a class A extending Element, and a class B extending A and PackageElement.
After code generation, in BImpl, all the attributes are created correctly, but eIsSet, eUnset, eSet, eGet does not delegate to PackageElementImpl for the features from PackageElement.
Example: visibilty. The setter/getter are correctly created (getVisibility(), setVisibility), but there is no reference to it from eIsSet/eUnset/eGet/eSet and there are problems when you try to acces the information directly as element.eGet(...VISIBILITY).
Is this a known problem, or did I forget something ?
Thank you in advance,
Sorin.
[Updated on: Wed, 02 December 2009 09:54] by Moderator
Re: eIsSet and multiple inheritance [message #501498 is a reply to message #501488] Wed, 02 December 2009 09:51 Go to previous messageGo to next message
Sorin,
Comments below.
Sorin Fagateanu wrote:
Java only support single class inheritance so it's not possible for
BImpl to extend both AImpl and PackageElementImpl. BImpl just
re-implement PackageElement from scratch.
Re: eIsSet and multiple inheritance [message #501506 is a reply to message #501498] Wed, 02 December 2009 10:30 Go to previous messageGo to next message
I am sorry i didn't give more details (I edited the original question so it may become clearer).
It is true that the methods from PackageElement are reimplemented in BImpl (ex: getVisibility(), setVisibility()), but the eIsGet/eUnset/eSet/eGet which are also generated, do not contain any reference to this methods, and when we try to access this information directly (as in
element.eGet(UMLPackage.eINSTANCE.getNamedElement_Visibility().getFeatureID())
), we get an error.
Sorin.
Re: eIsSet and multiple inheritance [message #501525 is a reply to message #501506] Wed, 02 December 2009 11:11 Go to previous messageGo to next message
--------------080306040500060505070604
Sorin,
That sounds bad but I have my doubts given how extensively UML itself
uses multiple inheritance...
> directly (as in
> element.eGet(UMLPackage.eINSTANCE.getNamedElement_Visibility ().getFeatureID())
> ), we get an error.
This isn't a valid approach and I would expect it to fail in general.
You have to be *very careful* when using feature IDs because the correct
one is relative to the actual class and is computed by this method on
EClass.
* <!-- begin-user-doc -->
* Returns the ID of the feature relative to this class, or -1 if
the feature is not in this class.
* @return the ID of the feature relative to this class, or -1 if
* <!-- end-user-doc -->
* @model
* @generated
int getFeatureID(EStructuralFeature feature);
I'd expect you to use
element.eGet(UMLPackage.eINSTANCE.getNamedElement_Visibility ()) and for
that to work...
> Sorin.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Sorin,<br>
<br>
uses multiple inheritance...<br>
<br>
<blockquote cite="mid:hf616h$36h$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
directly (as in
), we get an error.
<br>
</blockquote>
You have to be <b>very careful</b> when using feature IDs because the
correct one is relative to the actual class and is computed by this
method on EClass.<br>
<blockquote><small>  /**</small><br>
<small>   * &lt;!-- begin-user-doc --&gt;</small><br>
<small>   * Returns the ID of the feature relative to this class, or
-1 if the feature is not in this class.</small><br>
<small>   * @return the ID of the feature relative to this class, or
<small>   * &lt;!-- end-user-doc --&gt;</small><br>
<small>   * @model</small><br>
<small>   * @generated</small><br>
<small>   */</small><br>
<small>  int getFeatureID(EStructuralFeature feature);</small><br>
</blockquote>
that to work...<br>
<blockquote cite="mid:hf616h$36h$1@build.eclipse.org" type="cite">Thank
you in advance,
<br>
<br>
Sorin.
<br>
</blockquote>
</body>
</html>
--------------080306040500060505070604--
Re: eIsSet and multiple inheritance [message #502425 is a reply to message #501525] Tue, 08 December 2009 02:55 Go to previous messageGo to next message
Dear Ed,
I am facing a similar problem regarding the use of multiple inheritance (on a metamodel that extends the UML2 metamodel).
I have a class Base that extends Element.
I have a class PackageableBase that extends Base and PackageableElement (in this order).
The generated PackageableBaseImpl extends BaseImpl. Because of the multiple inheritance, EMF generates inside my PackageableBaseImpl class:
* fields (and getters + setters) that are specific to PackageableElement: name, visibility, clientDependencies, etc. Until now everything is OK.
* eBaseStructuralFeatureID() that converts featureIDs from superclasses to featureIDs
Until now, everything is OK.
The only problem comes from the VISIBILITY field. In fact, the eGet, eSet ... family doesn't contain a proper CASE in its SWITCH (it does from all the other fields such as NAME, CLIENT_DEPENDENCY, etc). Because of this, when one of this methods is invoked with the VISIBILITY field (during COPY, or SAVE), the call is not properly managed, ending up with a NullPointerException.
I see in uml.ecore that PackageableElement has a "duplicates" annotation containing the "visibility" field, and perhaps this is related to my problem.
Perhaps there is an option during the UML-EMF conversion, or something else that could be specified to enforce the "correct" generation (as I wouldn't like to suppress the generated tag and modify the above methods (eSet, eIsSet, etc)).
Cristi.
Re: eIsSet and multiple inheritance [message #502431 is a reply to message #502425] Tue, 08 December 2009 03:15 Go to previous messageGo to next message
I see that if my Base class extends from NamedElement instead of Element, I have no more problems.
But I cannot understand exactly why. Is it because the "visibility" field declared in PackageableElement "redefines" the "visibility" field declared in NamedElement, so when a class extends PackageableElement it should extend NamedElement as well?
Cristi.
[Updated on: Tue, 08 December 2009 03:16] by Moderator
Re: eIsSet and multiple inheritance [message #502487 is a reply to message #502431] Tue, 08 December 2009 09:14 Go to previous messageGo to next message
Cristian,
UML is generated with an extended GenModel that has different behavior
than EMF base GenModel. Things like refinement are supported only in
UML's extended GenModel so best to ask about it on the UML newsgroup.
Probably if you extend UML you'd need to use their extended GenModel too.
> PackageableElement it should extend as well NamedElement?
> Best regards,
> Cristi.
Re: eIsSet and multiple inheritance [message #502492 is a reply to message #502487] Tue, 08 December 2009 09:26 Go to previous message
Thanks for the tip.
I have put the question in the UML2 forum:
http://www.eclipse.org/forums/index.php?t=msg&th=159092& amp;start=0&S=dfd67368d78811939c1443cb3f41f641
Previous Topic:dynamic_package loading metamodels
Next Topic:Ecore and ecore_diagram
Current Time: Wed Jul 23 20:23:28 EDT 2025
Powered by FUDForum. Page generated in 0.25171 seconds
