Home » Archived » COSMOS » Cosmos Demo(Installation Problem)
Cosmos Demo [message #502466] Tue, 08 December 2009 07:18 Go to next message
Hello all,
I'm trying to install the cosmos demo as described in installation guide, but i get an error unzipping birt into Reportviewer
My console output:
C:\cosmos\cosmos-demo\bin>configDemo "C:\cosmosTomcat 5.5" C:\cosmos\cosmos-demo "C:\cosmos\Tomcat 5.5\webapps\birt-runtime-2_3_0.zip" C:\cosmos\axis2-1.3-war\
axis2.war
This program will install the COSMOS web applications into the Tomcat web server. If you are using any other web server, you will need to modify this program or install the demo manually.
Unzipping C:\cosmos\axis2-1.3-war\axis2.war to C:\cosmos\Tomcat 5.5\webapps\axis2...
Installed axis2 on Apache Tomcat server.
Installed web application: COSMOSReportViewer
Installed web application: COSMOSUI
Unzipping C:\cosmos\Tomcat 5.5\webapps\birt-runtime-2_3_0.zip to C:\cosmos\Tomcat 5.5\webapps/COSMOSReportViewer...
Unzipped BIRT to COSMOSReportViewer
Error occurred when unzipping BIRT to COSMOSReportViewer.
Installed web service: Broker
Installed web service: ExampleMdr
Installed web service: LoggingDataManager
Installed web service: ServiceFinder
Installed web service: SMLMDR
Installed web service: StatDataManager
Installed web service: TestFederatingCMDB
Copied axis jar files to COSMOSUI.
Copied axis jar files to COSMOSReportViewer.
Copied axis jar files to cosmos client.
Updated axis2.xml.
Updated services.xml for SML MDR.
Updated services.xml for statistical MDR.
Installed broker database to C:\cosmos\Tomcat 5.5\webapps\axis2\WEB-INF\database
/brokerdb.xml
The COSMOSUI gets loaded but if i try to right click any of the components I get:
Server returned HTTP response code: 500 for URL: http://localhost:8080/COSMOSReportViewer/webcontent/report.j sp?func=list&__ptype=TomcatSet&func=list
and the following stacktrace:
java.io.IOException: Server returned HTTP response code: 500 for URL: http://localhost:8080/COSMOSReportViewer/webcontent/report.j sp?func=list&__ptype=TomcatSet&func=list at sun.net.www.protocol.http.HttpURLConnection.getInputStream(H ttpURLConnection.java:1241) at org.eclipse.cosmos.internal.dr.drs.service.outputter.ReportD eployment.sendRequest(ReportDeployment.java:95) at org.eclipse.cosmos.internal.dr.drs.service.outputter.ReportD eployment.generateReportList(ReportDeployment.java:71) at org.eclipse.cosmos.internal.dr.drs.service.outputter.ReportD eployment.render(ReportDeployment.java:47) at org.eclipse.cosmos.internal.dr.drs.service.handler.common.Ou tputterDelegator.delegateRequest(OutputterDelegator.java:72) at org.eclipse.cosmos.internal.dr.drs.service.handler.common.Ou tputterDelegator.doPost(OutputterDelegator.java:55) at org.eclipse.cosmos.internal.dr.drs.service.handler.common.UR LDelegator.doPost(URLDelegator.java:96) at javax.servlet.http.HttpServlet.service(HttpServlet.java:647) at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) at org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:269) at org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:188) at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213) at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172) at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117) at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:174) at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:873) at org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665) at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528) at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689) at java.lang.Thread.run(Thread.java:619)
any idea how to solve this?
[Updated on: Tue, 08 December 2009 07:19] by Moderator
Re: Cosmos Demo [message #505129 is a reply to message #502466] Sun, 27 December 2009 07:57 Go to previous messageGo to next message
Yannis wrote:
> Hello all,
> My console output:
> axis2.war
Thanks for your post, Yannis. I'm sorry noone has responded sooner - I
think a lot of people are off for the holidays.
Question... why don't you have a backslash between "cosmos" and "Tomcat
5.5" in the first argument, when you do in the 2nd one? Also, even
though I don't think this would be a problem, please try again using a
directory name that does not contain a space, just to eliminate that as
a possible issue.
David
Re: Cosmos Demo [message #508778 is a reply to message #505129] Wed, 20 January 2010 04:58 Go to previous messageGo to next message
Hello again,
The missing backslash is just a typo error. I 've even tried to install in a directory without a space in its name but, I do get the same error.
Re: Cosmos Demo [message #536446 is a reply to message #502466] Fri, 28 May 2010 05:45 Go to previous message
Have you find the solution for this issue ?
I have the same problem on a linux server.
Rachid
Re: Cosmos Demo [message #573562 is a reply to message #505129] Wed, 20 January 2010 04:58 Go to previous message
Hello again,
Previous Topic:COSMOS V1.1 is now available
Next Topic:Cosmos Demo
Current Time: Sat Jul 26 20:57:00 EDT 2025
Powered by FUDForum. Page generated in 0.29323 seconds
