How to revert changes? [message #502404] |
Mon, 07 December 2009 21:13  |
Good day
Sorry for this noob question but I have no idea how to revert changes with the EGit plugin.
For example I added a line in index.php for debugging purposes and want to revert it.
Thank you for your advice.
Michael H.
Re: How to revert changes? [message #502731 is a reply to message #502664] |
Wed, 09 December 2009 09:36  |
"Michael Heuberger" <michael.heuberger@binarykitchen.com> wrote in message
news:hfnv69$8oj$1@build.eclipse.org...
> One last question:
> What does the sign ">" means in Zend Studio? Each time I modify a file, it
> appears? Does this mean that it has changed? By the way, I reverted these
> files with the previous content but the sign ">" is still there. How can I
> remove it?
the ">" means the file in the working tree is dirty (has some changes which
are not yet staged in the index),
see "Preferences / Team / Git / Label Decorations"
If ">" remains after reverting to previous content this maybe a refresh
problem (then refresh should help) or maybe you still have
some content changes e.g. in whitespace, encoding or line endings.
Matthias
Re: How to revert changes? [message #576419 is a reply to message #502592] |
Wed, 09 December 2009 04:13  |
to make one thing clear: I also think a button in the context menu of the File saying "Team->Revert" would be helpful. It is just missing (or we two haven't found it yet ;))
But this button would not do more then, now I citate you, "just coping the content". There is not more to do to revert a file which is not added to the index than to "just copy old content". Since you haven't "checked-out" the file explicitly there is also no explicit revert"
And specifically git will not "increment the version" as you assumed. Git stores content and two times the same content is the same version for git. You can easily try that out with native git.
Get a project and add a line to the file. Call "git status" and you see the file. Now edit the file again and remove that line. Call "git status" again and you see that no file is touched. This works even together with the index: add a file with one additional line to the index with "git add". Call "git status" to see this file beeing in the index. Then add the file again but now without this additional line. Afterwards "git status" will tell you there are no changes in the index!
Ciao
Chris
Re: How to revert changes? [message #576442 is a reply to message #576419] |
Wed, 09 December 2009 05:46  |
Very interesting, thank you for your good explanations!
I experimented myself and that's true. Git compares by contents.
Anyway, a Team->Revert function would be a nice shortcut, yes.
One last question:
What does the sign ">" means in Zend Studio? Each time I modify a file, it appears? Does this mean that it has changed? By the way, I reverted these files with the previous content but the sign ">" is still there. How can I remove it?
Re: How to revert changes? [message #576471 is a reply to message #576442] |
> One last question:
> remove it?
Matthias
FUDForum. Page generated in 1.10632 seconds
