Home » Modeling » EMF » eIsSet and multiple inheritance
eIsSet and multiple inheritance [message #501488] |
Wed, 02 December 2009 09:40  |
I have a multiple inheritance with a class A extending Element, and a class B extending A and PackageElement.
After code generation, in BImpl, all the attributes are created correctly, but eIsSet, eUnset, eSet, eGet does not delegate to PackageElementImpl for the features from PackageElement.
Example: visibilty. The setter/getter are correctly created (getVisibility(), setVisibility), but there is no reference to it from eIsSet/eUnset/eGet/eSet and there are problems when you try to acces the information directly as element.eGet(...VISIBILITY).
Is this a known problem, or did I forget something ?
Thank you in advance,
Sorin.
[Updated on: Wed, 02 December 2009 09:54] by Moderator
Re: eIsSet and multiple inheritance [message #501498 is a reply to message #501488] |
Wed, 02 December 2009 09:51   |
Sorin,
Comments below.
Sorin Fagateanu wrote:
Java only support single class inheritance so it's not possible for
BImpl to extend both AImpl and PackageElementImpl. BImpl just
re-implement PackageElement from scratch.
Re: eIsSet and multiple inheritance [message #501525 is a reply to message #501506] |
Wed, 02 December 2009 11:11   |
--------------080306040500060505070604
Sorin,
That sounds bad but I have my doubts given how extensively UML itself
uses multiple inheritance...
> I am sorry i didn't give more details (I edited the original question
> so it may become clearer).
> It is true that the methods from PackageElement are reimplemented in
> BImpl (ex: getVisibility(), setVisibility()), but the
> eIsGet/eUnset/eSet/eGet which are also generated, do not contain any
> reference to this methods, and when we try to access this information
> directly (as in
> element.eGet(UMLPackage.eINSTANCE.getNamedElement_Visibility ().getFeatureID())
> ), we get an error.
This isn't a valid approach and I would expect it to fail in general.
You have to be *very careful* when using feature IDs because the correct
one is relative to the actual class and is computed by this method on
EClass.
* <!-- begin-user-doc -->
* Returns the ID of the feature relative to this class, or -1 if
the feature is not in this class.
* @return the ID of the feature relative to this class, or -1 if
* <!-- end-user-doc -->
* @model
* @generated
int getFeatureID(EStructuralFeature feature);
I'd expect you to use
element.eGet(UMLPackage.eINSTANCE.getNamedElement_Visibility ()) and for
that to work...
> Sorin.
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Sorin,<br>
<br>
uses multiple inheritance...<br>
<br>
<blockquote cite="mid:hf616h$36h$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
directly (as in
), we get an error.
<br>
</blockquote>
You have to be <b>very careful</b> when using feature IDs because the
correct one is relative to the actual class and is computed by this
method on EClass.<br>
<blockquote><small> /**</small><br>
<small> * <!-- begin-user-doc --></small><br>
<small> * Returns the ID of the feature relative to this class, or
-1 if the feature is not in this class.</small><br>
<small> * @return the ID of the feature relative to this class, or
<small> * <!-- end-user-doc --></small><br>
<small> * @model</small><br>
<small> * @generated</small><br>
<small> */</small><br>
<small> int getFeatureID(EStructuralFeature feature);</small><br>
</blockquote>
that to work...<br>
<blockquote cite="mid:hf616h$36h$1@build.eclipse.org" type="cite">Thank
you in advance,
<br>
<br>
Sorin.
<br>
</blockquote>
</body>
</html>
--------------080306040500060505070604--
Re: eIsSet and multiple inheritance [message #502425 is a reply to message #501525] |
Tue, 08 December 2009 02:55   |
Dear Ed,
I am facing a similar problem regarding the use of multiple inheritance (on a metamodel that extends the UML2 metamodel).
I have a class Base that extends Element.
I have a class PackageableBase that extends Base and PackageableElement (in this order).
The generated PackageableBaseImpl extends BaseImpl. Because of the multiple inheritance, EMF generates inside my PackageableBaseImpl class:
* fields (and getters + setters) that are specific to PackageableElement: name, visibility, clientDependencies, etc. Until now everything is OK.
* eBaseStructuralFeatureID() that converts featureIDs from superclasses to featureIDs
Until now, everything is OK.
The only problem comes from the VISIBILITY field. In fact, the eGet, eSet ... family doesn't contain a proper CASE in its SWITCH (it does from all the other fields such as NAME, CLIENT_DEPENDENCY, etc). Because of this, when one of this methods is invoked with the VISIBILITY field (during COPY, or SAVE), the call is not properly managed, ending up with a NullPointerException.
I see in uml.ecore that PackageableElement has a "duplicates" annotation containing the "visibility" field, and perhaps this is related to my problem.
Perhaps there is an option during the UML-EMF conversion, or something else that could be specified to enforce the "correct" generation (as I wouldn't like to suppress the generated tag and modify the above methods (eSet, eIsSet, etc)).
Cristi.
Current Time: Wed Jul 23 20:21:14 EDT 2025
Powered by FUDForum. Page generated in 0.06034 seconds
