Home » Eclipse Projects » Eclipse Platform » Refactoring broken?(Can't refactor location of class attributes to another class)
Refactoring broken? [message #502301] Mon, 07 December 2009 11:04 Go to next message
I have several string class attributes I'd like to move to a different class. However, when I highlight the attribute (in the source file), select Refactor->Move, then select a class in the SAME PACKAGE, Eclipse reports "the selected element cannot be the destination for this operation" (ReorgPolicyFactory_doesnotexist0).
I never had problems refactoring the locations of attributes between classes before (and there is absolutely nothing special about these two).
Is this a bug?
Eclipse Galileo
Windows XP SP3
Java version 1.6.0_07
Re: Refactoring broken? [message #502343 is a reply to message #502301] Mon, 07 December 2009 13:36 Go to previous messageGo to next message
You would probably get a better response to this question if you posted to the
eclipse.tools.jdt newsgroup.
Del
> Is this a bug?
> Eclipse Galileo
> Windows XP SP3
Re: Refactoring broken? [message #502402 is a reply to message #502301] Mon, 07 December 2009 20:34 Go to previous messageGo to next message
> Is this a bug?
> Eclipse Galileo
> Windows XP SP3
Adding 'eclipse.tools.jdt' to newsgroup list, and setting followup-to.
I can reproduce what I think you're seeing.
I create a new Java project;
add a new package p and new classes p.A and p.B;
add a public String x1 to p.A;
and then highlight x1 and select Refactor -> Move.
When I click B.java, I see an error message saying "The selected element cannot
be the destination for this operation."
However, if I expand the B.java item, under it I see sub-items for the package p
and for the class B. If I select the *class* B, I am able to refactor successfully.
Note that B.java can contain multiple top-level declarations, including multiple
class declarations (though only one of them can be "class B"). So in a sense,
what it's saying is true; you can't move a field into the top level of a .java
file, that is, outside the scope of a class.
But in the 95% likely case, where the .java file contains only a single
top-level class, the intent is very clear and I think this is a usability bug.
I didn't see anything about it in Bugzilla, so you might want to enter a
Bugzilla feature request.
I didn't check to see whether this is a regression, i.e., whether it worked
differently in previous releases.
Re: Refactoring broken? [message #502476 is a reply to message #502402] Tue, 08 December 2009 08:16 Go to previous message
Thank you! I didn't even think to try this.
(In previous versions I think the behavior was different?)
Alexx
Previous Topic:Error opening schema via link in PDE
Next Topic:Change presentation dynamically
Current Time: Sun Jul 27 22:29:25 EDT 2025
Powered by FUDForum. Page generated in 0.23963 seconds
