Re: Display UML 2 class diagram [message #625382 is a reply to message #625331] |
Fri, 04 December 2009 15:59  |
Vlad Varnica wrote on Fri, 04 December 2009 14:03
> You can not take out EclipseUML2 contextual menus if you use the official plugin, but you can for example bundle EclipseUML tools inside your own installer.
> You need to go to the class which controls the class diagram contextual menu and change methods manually. I don't know where is the class and methods in charge of this menu but it should not be difficult to find out in the code.
I can probably figure out the contextual menus but how would I prevent the toolbox to be displayed?
Also my next question is about the UML tools build process - I think I figured out all the plugins involved but I haven't found how and where the code generation happens...
Is this documented somewhere?
Erik.
FUDForum. Page generated in 0.04858 seconds
