Synchronize view not up to date [message #497084] |
Thu, 12 November 2009 08:41  |
Hi!
I see this problem since years (from eclipse v3.3 IIRC).
Now I use v3.5.1 with the latest subversive plugin.
Symptom:
- the view in Synchronize (for example Outgoing mode) is not displaying all items
- going to other mode (Incoming) and back "fixes" it: now everything is displayed as it should
Right now I did this:
- start eclipse
- work for a while (change a few versioned files)
- go to Team Synchronizing perspective
- click Populate (view was in Outgoing mode)
Result:
- one of the projects I worked on and had a few files changed is not displayed at all (other projects with changed files are)
- I click on Incoming mode and again on Outgoing and now the missing project with files is there
Is there an open bug on this?
If you know the problem, then switching mode is an easy workaround, but it is still a bit annoying.
David
Re: Synchronize view not up to date [message #502212 is a reply to message #497084] |
Mon, 07 December 2009 04:22  |
Hello David,
We know that there can be problems in Sync view with Outgoing mode,
unfortunately they're not always reproducible, but they happen on some
specific circumstances. I created bugs for Team component about it
(unfortunately from short inspection I didn't find them), because Sync view
isn't created by Subversive, it's a Team component and they manage modes.
I also saw that you created bugs on Bugzilla, we'll review them.
Thanks.
> Hi!
> Symptom:
> all items
> - start eclipse
> Result:
> Regards,
> David
FUDForum. Page generated in 0.05922 seconds
