Home » Archived » Buckminster » integrate external tool builders
integrate external tool builders [message #501921] Fri, 04 December 2009 08:41 Go to next message
I'm wondering how to integrate the external (ant)builders of my projects
into the buckminster build.
I have configured several pre- and post-build steps in my projects by
defining additional builders. The .project file stores this information
as buildCommand (org.eclipse.ui.externaltools.ExternalToolBuilder)
If I execute the create.product command within my eclipse ide, then the
pre- and post-builders are called corrrectly.
But if I run the buckminster "perform
ch.ivyteam.ivy.designer.feature#create.product" headlessly (using hudson
to du so), then the pre- and post-bulders wont be executed.
Dos anybody knows, why the build is different eighter if I run it within
eclipse ide or headless?
How do I integrate my already defined externalToolBuilders in my
headless build?
Thanks for your answer,
Alain.
Re: integrate external tool builders [message #501946 is a reply to message #501921] Fri, 04 December 2009 09:56 Go to previous messageGo to next message
Hi Alain,
You are using the ExternalToolBuilder that (for some reason) is provided as part of the Eclipse UI. In order to do
things headlessly, we decided to provide the corresponding functionality headlessly. Not sure if this is documented.
You can use the headless builder by changing your .project file to contain entries like:
<buildCommand>
<name>org.eclipse.buckminster.ant.AntBuilder</name>
<arguments>
<dictionary>
<key>given.name</key>
<value>Ant tasks compile</value>
</dictionary>
<dictionary>
<key>script.file</key>
<value>make/build.xml</value>
</dictionary>
</arguments>
</buildCommand>
If you want to call specific targets you can add new dictionary entries for the keys:
auto.kind.target
clean.kind.target
incremental.kind.target
full.kind.target
i.e.
<dictionary>
<key>incremental.kind.target</key>
<value>special.target</value>
</dictionary>
will call the 'special.target' in your ant script when an incremental build is triggered.
You can also tell the builder to mark things that it builds as 'derived' by using
<dictionary>
<key>derived.resource</key>
<value>ant_tasks</value>
</dictionary>
Automatic refresh after the build can be accomplished by:
<dictionary>
<key>refresh.resource</key>
<value>.</value>
</dictionary>
And you can tell the builder to trigger on changes on the delta under a certain folder:
<dictionary>
<key>delta.resource</key>
<value>src/ant_tasks</value>
</dictionary>
HTH:
- thomas
On 2009-12-04 14:41, Alain Helfenstein wrote:
> headless build?
> Alain.
Re: integrate external tool builders [message #501983 is a reply to message #501946] Fri, 04 December 2009 11:06 Go to previous messageGo to next message
Hi Thomas
Thanks a lot for your immediate answer.
It works!
Kind regards, Alain.
Thomas Hallgren schrieb:
> Hi Alain,
> as part of the Eclipse UI. In order to do things headlessly, we decided
> is documented.
> <buildCommand>
> <arguments>
> <dictionary>
> </dictionary>
> <dictionary>
> </dictionary>
> </arguments>
> </buildCommand>
> for the keys:
> auto.kind.target
> clean.kind.target
> full.kind.target
> i.e.
> <dictionary>
> </dictionary>
> build is triggered.
> by using
> <dictionary>
> </dictionary>
> <dictionary>
> <value>.</value>
> </dictionary>
> certain folder:
> <dictionary>
> </dictionary>
> HTH:
> - thomas
>> Hi,
>> headless build?
>> Alain.
Re: integrate external tool builders [message #502090 is a reply to message #501946] Sat, 05 December 2009 09:18 Go to previous messageGo to next message
I don't think this is documented... Please log an issue for documentation.
- henrik
On 12/4/09 3:56 PM, Thomas Hallgren wrote:
> Hi Alain,
> is documented.
> <buildCommand>
> <arguments>
> <dictionary>
> </dictionary>
> <dictionary>
> </dictionary>
> </arguments>
> </buildCommand>
> for the keys:
> auto.kind.target
> clean.kind.target
> full.kind.target
> i.e.
> <dictionary>
> </dictionary>
> build is triggered.
> by using
> <dictionary>
> </dictionary>
> <dictionary>
> <value>.</value>
> </dictionary>
> certain folder:
> <dictionary>
> </dictionary>
> HTH:
> - thomas
>> Hi,
>> headless build?
>> Alain.
Re: integrate external tool builders [message #502114 is a reply to message #502090] Sat, 05 December 2009 16:46 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=296994
Previous Topic:Aggregator: handling of artifacts without feature/update site
Next Topic:lacking features and some small problems.
Current Time: Thu Nov 27 08:30:59 EST 2025
Powered by FUDForum. Page generated in 0.04056 seconds
