[XPAND] Ecore Metamodel containing EEnum [message #501549] |
Wed, 02 December 2009 13:18  |
I am trying to enhance the existing EMF code generator by generating some supplementary classes for existing .ecore models.
As it is a rather simple class to generate, I load the .ecore file with the Reader and pass it directly to an XPand template.
Everything works fine, except when the .ecore model contains enums, or, to be more specific, EEnumLiterals. In this case, I get a very weird error message:
EvaluationException : No Definition 'Dump for model::PrimitiveTypes' found!
where model::PrimitiveTypes is an enum defined by the EEnumLiteral, i.e. XPand seems to mix up the real type of the object (ecore::EEnumLiteral) with its content.
Here is a small test XPand to demonstrate the problem and which produces the above error message:
«IMPORT ecore»
«DEFINE Dump FOR EPackage»
«FILE "EcoreDump.txt"»
Package: «name»
«EXPAND Dump FOREACH eClassifiers»
«ENDFILE»
«ENDDEFINE»
«DEFINE Dump FOR EClassifier»
Classifier: «name»
«ENDDEFINE»
«DEFINE Dump FOR EEnum»
Enum: «name»
«EXPAND Dump FOREACH this.eLiterals»
«ENDDEFINE»
«DEFINE Dump FOR EEnumLiteral»
Literal:
«ENDDEFINE»
Any ideas on how to overcome this? I guess it is a bug in the EmfMetamodel implementation.
Alex
[Updated on: Wed, 02 December 2009 13:39] by Moderator
Re: [XPAND] Ecore Metamodel containing EEnum [message #501803 is a reply to message #501626] |
Thu, 03 December 2009 15:16  |
Hi Karsten,
thanks for your answer.
Unfortunately, I don't understand why this should be the intended behavior of the EMF typesystem.
Please be aware, that in my scenario Ecore is both the Meta-Metamodel (M3) and the Metamodel (M2) and the contents of the . ecore file is used as model data (M1) in the same you would usually use an .xmi file for.
In a typical (i.e not my presented) EMF model, Ecore is the Meta-Metamodel (M3) and one defines an own Metamodel in an .ecore file (M2). For such an EMF model you then have some data, e.g. in a .XMI file (M1) that you process and transform to text via XPand.
The types used in the XPand template come from M2 and are based on M3. Typically, the EEnumLiteral is an Ecore (M3) Meta-type and the real literal (M2) is the one you want to use in XPand. Everything in M1 is the processed data and definitely not a type used in XPand.
In my example, as said, Ecore is both M3 and M2, as Ecore is defined in itself. In other words, Ecore is also an EMF model.
The EEnumLiteral I was talking about is the one from M2 and its M3 Ecore Meta-type is EClass. The error/bug is now, that an M2 type with M3 EClass, that just "happens" to be called EEnumLiteral as well, is wrongly interpreted as the M1 type and the tempalte expects to find a DEFINE for the M1 type, which can't be correct. By the way, this only happens during runtime; the static typechecking is correct.
Summarizing, I can't agree to your statement that this makes sense in most cases. Instead, I'd say that the current behavior is correct if the EEnumLiteral is Meta-Metamodel (M3) and it is wrong if the EEnumLiteral is Metamodel (M2), because in this case its M3 type is EClass.
br
Alex
FUDForum. Page generated in 0.05038 seconds
