Home » Modeling » EMF » Issue with persisting and loading of EMF Enum entities(Issue with Enum persistence and loading)
Issue with persisting and loading of EMF Enum entities [message #501686] Thu, 03 December 2009 08:20 Go to next message
I am struggling with a problem which initially looked trivial but aparently is not the case:
My Ecore model contains an EMF enum called Cardinality:
<eClassifiers xsi:type="ecore:EEnum" name="Cardinality">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Cardinality"/>
</eAnnotations>
<eLiterals name="_01" literal="0..1"/>
<eLiterals name="_0N" value="1" literal="0..n"/>
</eClassifiers>
I am using WST Translator to persist and load EMF entities. When I persist the same, it gets persisted by its literal and not name:
<... cardinality="0..1">
Which is the desired way of persisting.
However, when I try to load it, it tries to match the dom attribute value of cardinality "0..1" to the name of the cardinality "_0N" and hence throws the following exception:
aused by: org.eclipse.wst.common.internal.emf.utilities.FeatureValueCo nversionException: IWAE0014E Failed to convert 0..1 to Enumeration.
at org.eclipse.wst.common.internal.emf.utilities.DefaultFeature ValueConverter.failedToConvert(DefaultFeatureValueConverter. java:352)
at org.eclipse.wst.common.internal.emf.utilities.DefaultFeature ValueConverter.convertToEnum(DefaultFeatureValueConverter.ja va:112)
at org.eclipse.wst.common.internal.emf.utilities.DefaultFeature ValueConverter.convertValue(DefaultFeatureValueConverter.jav a:228)
at org.eclipse.wst.common.internal.emf.utilities.DefaultFeature ValueConverter.convertValue(DefaultFeatureValueConverter.jav a:307)
at org.eclipse.wst.common.internal.emf.resource.Translator.conv ertStringToValue(Translator.java:520)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.primUpdateMOFFeature(EMF2DOMAdapterImpl.java:1376)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.updateMOFFeature(EMF2DOMAdapterImpl.java:1775)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.primUpdateMOF(EMF2DOMAdapterImpl.java:935)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.updateMOF(EMF2DOMAdapterImpl.java:915)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.primUpdateMOFMultiFeature(EMF2DOMAdapterImpl.java:464)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.primUpdateMOFMultiFeature(EMF2DOMAdapterImpl.java:1488)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.updateMOFMultiFeature(EMF2DOMAdapterImpl.java:1702)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.updateMOFFeature(EMF2DOMAdapterImpl.java:1757)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.updateMOFRootFeature(EMF2DOMAdapterImpl.java:956)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMAdapterI mpl.primUpdateMOF(EMF2DOMAdapterImpl.java:931)
at org.eclipse.wst.common.internal.emf.resource.EMF2DOMRenderer .doLoad(EMF2DOMRenderer.java:64)
at org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceImpl.basicDoLoad(TranslatorResourceImpl.java:144)
at org.eclipse.wst.common.internal.emf.resource.CompatibilityXM IResourceImpl.doLoad(CompatibilityXMIResourceImpl.java:175)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1282)
at org.eclipse.wst.common.internal.emf.resource.CompatibilityXM IResourceImpl.load(CompatibilityXMIResourceImpl.java:261)
at org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceImpl.load(TranslatorResourceImpl.java:389)
... 44 more
Can anyone please help me how to fix this issue. I tried replacing the name for the Cardinality enum to "0..n", however, the genmodel gives an error.
Also I dont want to change the generated Java Class for the cardinality.
Thanks a lot,
Best Regards,
Nidhi
[Updated on: Wed, 09 December 2009 00:52] by Moderator
Re: Issue with persisting and loading of EMF Enum entities [message #501694 is a reply to message #501686] Thu, 03 December 2009 09:04 Go to previous messageGo to next message
Nidhi,
I see you posted the same question to the WTP newsgroup. That's the
place to ask about WST...
Nidhi wrote:
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> aused by:
> ceImpl.java:1494)
> ceImpl.java:1282)
> at com.sap.ide.phoenix.metamodel.library.util.LibraryResourceIm
> pl.load(LibraryResourceImpl.java:88)
> at com.sap.ide.phoenix.services.mm.PhoenixMetamodelCache.loadRe
> source(PhoenixMetamodelCache.java:123)
> ... 44 more
> an error.
> Thanks a lot,
> Best Regards,
> Nidhi
Re: Issue with persisting and loading of EMF Enum entities [message #501715 is a reply to message #501694] Thu, 03 December 2009 10:15 Go to previous message
Hi Ed,
I realized my mistake immediately after posting this topic
that it's not really an issue with the way EMF serializes but might be an issue with the way Translator loads the serialized Enum.
Since I am new in this forum, I dont really if it's possbile to delete a post?
Thanks anyways for pointing to the right group.
Nidhi
Previous Topic:How to select particular elements, based on current state of element in edit part
Next Topic:Prevent EMF "Generate model code" from screwing up classpath
Current Time: Sat Jul 26 00:36:52 EDT 2025
Powered by FUDForum. Page generated in 0.02644 seconds
