Home » Eclipse Projects » DTP » Can DTP/ODA be used outside Eclipse
Can DTP/ODA be used outside Eclipse [message #499422] Sun, 22 November 2009 06:10 Go to next message
Hi all,
I was wondering how much the DTP project depends on Eclipse. Or, in essence, can I use it to connect to data sources in a custom Java application?
And what would I (roughly) need to do if I wanted this? Can I reuse some of the wizards provided with ODA and the ODA drivers etc.?
Thanks in advance!
Joos
Re: Can DTP/ODA be used outside Eclipse [message #501311 is a reply to message #499422] Tue, 01 December 2009 15:10 Go to previous message
Hi Joos,
The ODA framework uses Eclipse extension points and the OSGi class loading framework to handle the discovery and loading of ODA driver extensions. So all the dependent Eclipse core bundles would need to be included when used in a custom Java appl.
Linda
Previous Topic:Data Soruce Explorer, No tables, only Schemas visible
Next Topic:Can DTP/ODA be used outside Eclipse
Current Time: Sat Jul 26 20:56:17 EDT 2025
Powered by FUDForum. Page generated in 0.23335 seconds
