Home » Modeling » M2T (model-to-text transformation) » [Acceleo] 'If' on an Iterate loop(Is it possible?)
[Acceleo] 'If' on an Iterate loop [message #501304] Tue, 01 December 2009 14:31 Go to next message
hi
Is it possible to use an 'if' expression on a iterate loop?
I've saw this expression on OMG OCL documentation (page 145)...
result = self->iterate( elem; acc : Integer = 0 | if elem = object then acc + 1 else acc endif)
... and have tried to used the expression below:
[query hasList(m : MetaComponent) : Boolean =
m.relationship->iterate(item; res : Boolean = false | if item.highCardinalitie <> 1 then true endif ) /]
This expression has this error: 'then unexpected token'.
Is the sintax incorrect? Is there any other way to obtain this result?
Another question: is there any command similar to java 'Break', used to terminate a loop?
thanks
Re: [Acceleo] 'If' on an Iterate loop [message #501413 is a reply to message #501304] Wed, 02 December 2009 04:07 Go to previous message
--------------050204050402050908000106
Andre,
OCL if's need their "else" defined or else are incorrect, though the
error message they return doesn't make it clear.
item.highCardinalitie <> 1 then true else false endif )
would see the if compile, though I don't really understand your need
here. As for a break, there is none in OCL. You should use
m.relationship->any(item | item.highCardinalitie <> 1 )
if you wish to check that at least one element of the list verifies the
condition.
Laurent Goubet
Obeo
Andre wrote:
> hi
> I've saw this expression on OMG OCL documentation (page 145)... result =
> 1 else acc endif)
> terminate a loop?
> thanks
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------050204050402050908000106--
Previous Topic:[Xpand/Xtend] MetaModelContributor for oAW
Next Topic:[MTL] the emtl-file
Current Time: Sat Jul 26 13:23:21 EDT 2025
Powered by FUDForum. Page generated in 0.04159 seconds
