Errors Creating a RTSC Project [message #500807] |
Sat, 28 November 2009 21:16  |
I am trying to create an RTSC CCS4 project and have encountered a few problems. I am following the RTSC Quick Start Guide using a TMS320C28346 . I have a fresh install of CCS Version: 4.0.2.01003 that comes with XDCTools 3.15.04.70
Problem 1: On step number ten of the Quick Start Guide, the RTSC Configuration Settings window does not auto populate dialogs. Only when I type some random text into RTSC Target, does the RTSC Platform dropdown populates.
Problem 2: When I finish and double click the common.cfg, file contents are shown in the text editor, but I receive the first error listed at the bottom. When I upgrade XDCTools to version 3.16.00.18, the error disappears and the graphical DSP/Bios icons show...but then nothing populates in the RTSC Platforms drop down and I get a second error, also listed at the bottom.
FIRST ERROR
Quote: | eclipse.buildId=4.0.2.01003
java.version=1.5.0_14
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Sat Nov 28 19:31:52 CST 2009
org.eclipse.rtsc.xdctools.INTERNAL: Unable to find package common_xconfig
xdc.services.global.XDCException: org.eclipse.rtsc.xdctools.INTERNAL: Unable to find package common_xconfig
at org.eclipse.rtsc.xdctools.ui.ConfigThread.execConfiguro(Conf igThread.java:300)
at org.eclipse.rtsc.xdctools.ui.ConfigThread.run(ConfigThread.j ava:101)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
SECOND ERROR
Error
Sat Nov 28 20:08:34 CST 2009
Invalid module
java.lang.NullPointerException: Invalid module
at org.eclipse.rtsc.xdctools.ui.reflect.Reflect.getModuleConfig (Reflect.java:177)
at org.eclipse.rtsc.xdctools.ui.utils.XDCUtils.getModuleIsa(XDC Utils.java:196)
at org.eclipse.rtsc.xdctools.ui.utils.XDCUtils.getRTSCPlatforms (XDCUtils.java:464)
at org.eclipse.rtsc.xdctools.ui.RTSCUtilsServer2.getRTSCPlatfor ms(RTSCUtilsServer2.java:81)
at org.eclipse.rtsc.xdctools.managedbuild.ui.dialogs.RTSCConfig urationProjectSettingsPage$13.run(RTSCConfigurationProjectSe ttingsPage.java:793)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
I am newcomer to the DSP/Bios 6.0, an my knowledge of version 5.0 was very limited. Thanks for your help.
~Grant
[Updated on: Sat, 28 November 2009 21:40] by Moderator
Re: Errors Creating a RTSC Project [message #500995 is a reply to message #500807] |
Mon, 30 November 2009 10:58   |
comments below.
> http://rtsc.eclipse.org/docs-tip/RTSC%2BCCStudio_v4_QuickSta rt using a
> TMS320C28346 . I am have a fresh install of CCS Version: 4.0.2.01003
> Configuration Settings window does not auto populate dialogs. When I
> type some random text into RTSC Target, RTSC Platform drops down populates.
I suspect this is "normal" behavior; the wizard does not populate the
platform list until it knows the target and the target is currently
populated by a heuristic that looks at your earlier device selections.
It appears that the target selection heuristic for the C28xxx is failing
to find an appropriate target and, as a result, you see nothing auto
populated. Typing "random" text into the target selection will trigger
the wizard to select a platform that supports your target.
We'll look into this for the TMS320C28346 and BIOS 6 and recommend
appropriate targets and platforms.
> Problem 2: When I finish, and double click the common.cfg, code within
> the file shows in the text editor, but I receive the error listed at the
> populates in the RTSC Configuration Settings Window and I get a
> different error, also listed at the bottom.
This might be a consequence of the earlier error, but we'll need to dig
deeper into this.
> FIRST ERROR
> Quote:
>> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
>> Error
>> igThread.java:300)
> SECOND ERROR
> Error
> Quote:
>> Invalid module
>> (Reflect.java:177)
>> Utils.java:196)
>> (XDCUtils.java:464)
> Thanks for your help. I am newcomer to the DSP/Bios 6.0, an my knowledge
> of version 5.0 was very limited. ~Grant
FUDForum. Page generated in 0.04114 seconds
