Cannot open PHP files after updating - Editor could not be initialized [message #500210] |
Wed, 25 November 2009 07:01  |
I cannot open PHP files any more after the latest update of PDT. When I attempt to open any PHP file, it says that it is "Unable to create editor ID org.eclipse.php.editor: Editor could not be initialized." and gives me this stack trace:
Eclipse: Version: 3.5.1 Build id: M20090917-0800
PHP Development Tools (PDT) Runtime Feature 2.2.0.v200911190058-7L7JF8NcJKhTTUhJK5Y
Dynamic Languages Toolkit - Core Frameworks 2.0.0.v20090917-1518-7L--EAAoOQBUSjFBcvjL
java.lang.NoSuchMethodError: org.eclipse.dltk.compiler.IElementRequestor.acceptMethodRefe rence([CIII)V
at org.eclipse.php.internal.core.compiler.PHPSourceElementReque stor.visit(PHPSourceElementRequestor.java:455)
at org.eclipse.php.internal.core.compiler.PHPSourceElementReque stor.visit(PHPSourceElementRequestor.java:652)
at org.eclipse.php.internal.core.compiler.ast.nodes.PHPCallExpr ession.traverse(PHPCallExpression.java:37)
at org.eclipse.php.internal.core.compiler.ast.nodes.UnaryOperat ion.traverse(UnaryOperation.java:51)
at org.eclipse.php.internal.core.compiler.ast.nodes.IfStatement .traverse(IfStatement.java:54)
at org.eclipse.dltk.ast.statements.Block.traverse(Block.java:43 )
at org.eclipse.dltk.ast.declarations.ModuleDeclaration.traverse (ModuleDeclaration.java:70)
at org.eclipse.dltk.core.AbstractSourceElementParser.parseSourc eModule(AbstractSourceElementParser.java:35)
at org.eclipse.php.internal.core.compiler.ast.parser.PHPSourceE lementParser.parseSourceModule(PHPSourceElementParser.java:2 8)
at org.eclipse.dltk.core.SourceParserUtil.parseSourceModule(Sou rceParserUtil.java:237)
at org.eclipse.dltk.internal.core.AbstractSourceModule.buildStr ucture(AbstractSourceModule.java:530)
at org.eclipse.dltk.internal.core.Openable.generateInfos(Openab le.java:185)
at org.eclipse.dltk.internal.core.ModelElement.openWhenClosed(M odelElement.java:182)
at org.eclipse.dltk.internal.core.BecomeWorkingCopyOperation.ex ecuteOperation(BecomeWorkingCopyOperation.java:45)
at org.eclipse.dltk.internal.core.ModelOperation.run(ModelOpera tion.java:698)
at org.eclipse.dltk.internal.core.ModelOperation.runOperation(M odelOperation.java:764)
at org.eclipse.dltk.internal.core.SourceModule.becomeWorkingCop y(SourceModule.java:68)
at org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.createFileInfo(SourceModuleDocumentProvider.java:1271)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
at org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.connect(SourceModuleDocumentProvider.java:1517)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4134)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:203)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1413)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:166)
at org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:1712)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(PHPStructuredEditor.java:2208)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
at org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2321)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( PHPStructuredEditor.java:1151)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.handleDeferredEvents(PartS tack.java:1224)
at org.eclipse.ui.internal.LayoutPart.deferUpdates(LayoutPart.j ava:400)
at org.eclipse.ui.internal.PartSashContainer.handleDeferredEven ts(PartSashContainer.java:1409)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1416)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1406)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1380)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1435)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:543)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 06)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:122 )
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:83)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:270)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:279)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:70 )
at org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:626)
at org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:206)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:21 99)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:327)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
I have no idea how to fix this, any help is appreciated.
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500955 is a reply to message #500938] |
Mon, 30 November 2009 08:17  |
Dave, you're right, sorry for the complaints and remarks. I have already installed the stable version, which works with no problems. My bad, I should have seen it coming, at least the "-dev" suffix should have warned me.
However, it might be a good idea to add a notice to the installation page, or at least show the 2.1 version at the top of the page. I came to the page via search engine results and hadn't therefore studied the main page properly. To be honest, I wouldn't pay attention even if I had, because it is too low and nothing labels the branches as "experimental" or "stable" apart from the release date.
FUDForum. Page generated in 0.06528 seconds
