| [Acceleo]Collections of Collections on Queries [message #500602] |
Thu, 26 November 2009 21:44  |
Is it possible to use collections of collections as return of a query? i've tried the code below, but the type 'Sequence(Sequente(T))' is Invalid.
[query public packages2(input : MetaComponent) : Sequence(Sequence(T)) =
input.properties->iterate(item : Property; res : Sequence(Sequence(String)) = Sequence{Sequence{}} | res->append(
item.type.ancestors(Package)->iterate(pack : Package; retur : Sequence(String) = Sequence{} | retur->append(pack.name))
And what about the initialization of a collection of collection? i've tried 'Sequence{Sequence{}}', but i dont know if it is right.
thanks
[Updated on: Fri, 27 November 2009 08:58] by Moderator
| Re: Collections of Collections on Queries [message #500640 is a reply to message #500602] |
Fri, 27 November 2009 04:33   |
--------------020008040900020608000409
Hi Andre,
You can initialize sequences containing Sequence like you described here
: "Sequence{Sequence{'a', 'b'}, Sequence{'c'}}" is perfectly legal.
However, the current implementation of OCL will prevent you from using
Sequences typed with Sequences : "Sequence(Sequence(String))" is
illegal. That means you cannot define Acceleo queries returning such
sequences, and you cannot cast to them either "Sequence{Sequence{'a',
'b'}, Sequence{'c'}}.oclAsType(Sequence(Sequence(String)))" will fail in
compilation error.
Laurent Goubet
Obeo
Andre wrote:
> Hi
> thanks
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020008040900020608000409--
| Re: Collections of Collections on Queries [message #500794 is a reply to message #500789] |
Sat, 28 November 2009 14:53  |
Based on this problem and other tests, i've concluded that on queries like these, when a query calls another, the error message is always 'Invalid Operation Signature', even when there is another type of error subsequent on the query. So, the developer thinks that the problem is on the call to the other query, when it isn't.
FUDForum. Page generated in 0.03870 seconds
