how to replace a TableViewer in a wizard page [message #500594] |
Thu, 26 November 2009 17:26  |
Originally posted by: yoduderoo.netscape.net
I have a wizard page containing a table viewer which displays tabular
data depending on how the user entered a given field. The user can
clear the field, enter something else and a new table is displayed. The
headings and number of columns is different depending on that input.
I am having a hard time figuring out how to do this. I create a
composite to contain the TableViewer. Should I dispose that and somehow
clear it before redrawing? Do I recreate a new tableviewer each time and
then call the composite's layout() method?
I keep trying various approaches but am getting nowhere.
thanks, y
Re: how to replace a TableViewer in a wizard page [message #500611 is a reply to message #500594] |
Fri, 27 November 2009 01:52  |
Yodude wrote:
[This question does not belong into this group, because jface is
no part of SWT]
Usually it is not necessary to dispose the table widget. Instead one of
the more extreme solutions is to dispose all table columns and to
recreate them. You probably need to perform a new call of layout()
after that. I also suggest to wrap the complete "reconfiguration"
inside a block of
table.setRedraw(false);
try {
... // restructure table viewer
} finally {
table.setRedraw(true);
to reduce visual flickering during that process.
I would only suggest to dispose the complete page control, if the
complete *page content* would undergo drastic structural changes.
HTH & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.16980 seconds
