Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EEF generated classes do not compile
EEF generated classes do not compile [message #500537] Thu, 26 November 2009 09:48 Go to next message
Hello there,
I have installed the latest nightly build of EEF to try it out.
Some of the generated EditionComponent classes do not compile
here is the faulty generated code :
///////////////////////////////////// start of code
* Initialize the semantic model listener for live editing mode
* @return the semantic model listener
private AdapterImpl initializeSemanticAdapter() {
return new EContentAdapter() {
* {@inheritDoc}
* @see org.eclipse.emf.common.notify.impl.AdapterImpl#notifyChanged (org.eclipse.emf.common.notify.Notification)
public void notifyChanged(Notification msg) {
if (basePart == null)
BackgroundColorPropertiesEditionComponent.this.dispose();
else {
if (PropertiesPackage.eINSTANCE.getBackgroundColor_Value().equa ls(msg.getFeature()) && basePart != null){
if (msg.getNewValue() != null)//////////////////////////// comment from SeB : here is the faulty code !!!
//FIXME invalid case in liveUpdater(), Case : model = Attribute(1) : value - view = Text
else
basePart.setValue("");
///////////////////////////////////// end of code
Can you tell me what is going wrong ?
Than you.
SeB.
PS : here is the my ecore metamodel.
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="css"
nsURI="http://www.nds.com/skinning/Css" nsPrefix="css">
<eClassifiers xsi:type="ecore:EClass" name="Model">
<eStructuralFeatures xsi:type="ecore:EReference" name="cssBlocks" upperBound="-1"
eType="#//CssBlocks" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="comments" upperBound="-1"
eType="#//Comments" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CssBlocks">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="selector" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="properties" upperBound="-1"
eType="#//properties/Property" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Comments">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="beforeComments" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="testSampleUrlList" upperBound="-1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="afterComments" upperBound="-1"
</eClassifiers>
<eSubpackages name="properties" nsURI="http://www.nds.com/skinning/Css/properties"
nsPrefix="properties">
<eClassifiers xsi:type="ecore:EClass" name="Property" abstract="true"/>
<eClassifiers xsi:type="ecore:EClass" name="Color" eSuperTypes="#//properties/Property">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" lowerBound="1"
eType="#//datatypes/RgbColor"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BackgroundColor" eSuperTypes="#//properties/Property">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AnyOther" eSuperTypes="#//properties/Property">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="FontFamily" eSuperTypes="#//properties/Property">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="fontList" upperBound="-1"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BackgroundImage" eSuperTypes="#//properties/Property">
eType="#//datatypes/Uri"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Visibility" eSuperTypes="#//properties/Property">
eType="#//datatypes/VISIBILITY"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="FontSize" eSuperTypes="#//properties/Property">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="size" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BackgroundRepeat" eSuperTypes="#//properties/Property">
eType="#//datatypes/BACKGROUND_REPEAT"/>
</eClassifiers>
</eSubpackages>
<eSubpackages name="datatypes" nsURI="http://www.nds.com/skinning/Css/datatypes"
nsPrefix="datatypes">
<eClassifiers xsi:type="ecore:EDataType" name="RgbColor" instanceClassName="org.eclipse.swt.graphics.RGB"/>
<eClassifiers xsi:type="ecore:EDataType" name="Uri" instanceClassName="java.net.URI"/>
<eClassifiers xsi:type="ecore:EEnum" name="VISIBILITY">
<eLiterals name="VISIBLE" literal="visible"/>
<eLiterals name="HIDDEN" value="1" literal="hidden"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="BACKGROUND_REPEAT">
<eLiterals name="REPEAT" literal="repeat"/>
<eLiterals name="REPEAT_X" value="1" literal="repeat-x"/>
<eLiterals name="REPEAT_Y" value="2" literal="repeat-y"/>
<eLiterals name="NO_REPEAT" value="3" literal="no-repeat"/>
</eClassifiers>
</eSubpackages>
</ecore:EPackage>
Re: EEF generated classes do not compile [message #500627 is a reply to message #500537] Fri, 27 November 2009 03:54 Go to previous messageGo to next message
--------------070204010602040007090400
Hi Seb,
It looks like your EEF component models contains some mapping that are
not yet supported by the generation.
typically, you are trying to map the colorbackground feature with a text
widget. What is the EType used by this feature ?
seb.fr a écrit :
> Hello there,
> * * @return the semantic model listener
> * {@inheritDoc}
> * * @see
> else {
> if
> code !!!
> value - view = Text
> else
> Than you.
> SeB.
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> lowerBound="1"
> upperBound="-1"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> </eClassifiers>
> </eSubpackages>
> </eClassifiers>
> </eClassifiers>
> </eSubpackages>
> </ecore:EPackage>
name="stephane_bouchet.vcf"
filename="stephane_bouchet.vcf"
YmVnaW46dmNhcmQNCmZuO3F1b3RlZC1wcmludGFibGU6U3Q9QzM9QTlwaGFu ZSBCb3VjaGV0
DQpuO3F1b3RlZC1wcmludGFibGU6Qm91Y2hldDtTdD1DMz1BOXBoYW5lDQpv cmc6T2Jlbw0K
YWRyO3F1b3RlZC1wcmludGFibGU6Ozs7UmV6PUMzPUE5Ozs0NDQwMDtGcmFu Y2UNCmVtYWls
O2ludGVybmV0OnN0ZXBoYW5lLmJvdWNoZXRAb2Jlby5mcg0KeC1tb3ppbGxh LWh0bWw6RkFM
U0UNCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------070204010602040007090400--
Re: EEF generated classes do not compile [message #500630 is a reply to message #500627] Fri, 27 November 2009 04:04 Go to previous messageGo to next message
--------------010809070708090700020201
Hi again,
Sorry i just looked to your metamodel and here is the problem :
lowerBound="1"
you are trying to map a custom edatatype ( rgbcolor ) with a text. this
is not supported now by EEF.
you can avoid this generated part by replacing your element editor
"background_value" with a "custom element editor". EEF will generates
empty code that needs to be filled by you to handle th mapping manually.
cheers,
Stéphane Bouchet a écrit :
> Hi Seb,
> Cheers,
> seb.fr a écrit :
>> Hello there,
>> * {@inheritDoc}
>> * * @see
>> else {
>> if
>> faulty code !!!
>> value - view = Text
>> else
>> Than you.
>> SeB.
>>backgrou
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> upperBound="-1"
>> </eClassifiers>
>> lowerBound="1"
>> upperBound="-1"
>> </eClassifiers>
>> </eClassifiers>
>> abstract="true"/>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> lowerBound="1"
>> </eClassifiers>
>> upperBound="-1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> </eSubpackages>
>> </eClassifiers>
>> </eClassifiers>
>> </eSubpackages>
>> </ecore:EPackage>
--------------010809070708090700020201--
Re: EEF generated classes do not compile [message #500905 is a reply to message #500630] Mon, 30 November 2009 04:20 Go to previous messageGo to next message
Hi Stéphane,
if this is a matter of data type conversion I would suggest EEF uses the default EMF conversion behaviour.
EMF creates data conversion methods for each Data type when the genmodel is used for generation.
There are 2 methods
createMyDataFromString()
and
convertMyDataToString()
found in the factory implementation class that serves this purpose in EMF genererated code (look at Data Type section in http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/references/overview/EMF.html).
So I would suggest that EEF use the
org.eclipse.emf.ecore.util.EcoreUtil.createFromString(EDataType eDataType,java.lang.String literal)
org.eclipse.emf.ecore.util.EcoreUtil.convertToString(EDataType eDataType, java.lang.Object value)
for converting the Data to and from text.
This would allow for default EEF generation without any error.
SeB.
[quote title=Stephane Bouchet wrote on Fri, 27 November 2009 04:04]This is a multi-part message in MIME format.
Hi again,
lowerBound="1"
cheers,
[Updated on: Mon, 30 November 2009 04:21] by Moderator
Re: EEF generated classes do not compile [message #500948 is a reply to message #500905] Mon, 30 November 2009 07:31 Go to previous message
--------------060804070303070404040600
hi Seb,
This is indeed what we are actually doing :)
In the next integration version of EEF, you would be able to do so.
seb.fr a
Re: EEF generated classes do not compile [message #621622 is a reply to message #500627] Fri, 27 November 2009 04:04 Go to previous message
Hi again,
lowerBound="1"
cheers,
> Hi Seb,
> Cheers,
> seb.fr a écrit :
>> Hello there,
>> * {@inheritDoc}
>> * * @see
>> else {
>> if
>> faulty code !!!
>> value - view = Text
>> else
>> Than you.
>> SeB.
>>backgrou
>> upperBound="-1"
>> upperBound="-1"
>> </eClassifiers>
>> lowerBound="1"
>> upperBound="-1"
>> </eClassifiers>
>> </eClassifiers>
>> abstract="true"/>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> lowerBound="1"
>> </eClassifiers>
>> upperBound="-1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> lowerBound="1"
>> </eClassifiers>
>> </eSubpackages>
>> </eClassifiers>
>> </eClassifiers>
>> </eSubpackages>
>> </ecore:EPackage>
Re: EEF generated classes do not compile [message #621860 is a reply to message #500630] Mon, 30 November 2009 04:20 Go to previous message
Originally posted by: sgandon.nds.com
Hi Stéphane,
EMF creates data conversion methods when the genmodel is used for generation.
There are 2 methods
and
org.eclipse.emf.ecore.util.EcoreUtil.createFromString(EDataT ype eDataType,java.lang.String literal)
org.eclipse.emf.ecore.util.EcoreUtil.convertToString(EDataTy pe eDataType, java.lang.Object value)
SeB.
Hi again,
lowerBound="1"
cheers,
Re: EEF generated classes do not compile [message #621867 is a reply to message #500905] Mon, 30 November 2009 07:31 Go to previous message
hi Seb,
seb.fr a
Previous Topic:Forward Cross References
Next Topic:EMF: Generated classes - Copyright details
Current Time: Fri Jul 25 11:06:16 EDT 2025
Powered by FUDForum. Page generated in 0.74411 seconds
