Home » Archived » M2M (model-to-model transformation) » [ATL] Calling Java within an ATL transformation(Generate values for target element attributes with java within an ATL transformation)
icon5.gif  [ATL] Calling Java within an ATL transformation [message #500507] Thu, 26 November 2009 08:14
Hi!
The goal is to define a ATL model transformation between models based on meta model MMS into a models based on meta model MMT.
The problem is, that in MMT there is an target clas for which there is a source type in MMS. But the target class also have an attribute ("identifier" ... containing an UUID) for which there is no source in MMS.
So, I need to generate the value for the "identifier" at transformation time. Is there a way to do this?
E.g. calling JAVA code for UUID generation...?
Thanks in advance, Helko
Previous Topic:[QVTO] Can QVTO handle ecore models with extended metadata?
Next Topic:[QVTO] What's the canonical way to set inherited attributes/references in a inheritance hierarchy
Current Time: Mon Jul 21 06:12:40 EDT 2025
Powered by FUDForum. Page generated in 0.04055 seconds
