Home » Modeling » EMF » databinding missing IEMFSetProperty
databinding missing IEMFSetProperty [message #499151] Fri, 20 November 2009 02:28 Go to next message
Originally posted by: Thomas.Kowatsch.ruag.com
Hi.
Is there anything like an IEMFSetProperty? I was looking for it but
couldn't find anything.
I need this in order to bind a reference list to a checkbox table
viewer. This should be similar as in the
org.eclipse.jface.examples.databinding.snippets.Snippet018Ch eckboxTableViewerCheckedSelection
example.
Somewhere I have read this should be coming in 2.6. Any code snippets
yet that I could use?
Is there any other way how I could solve that, e.g. create a SetProperty
that wraps an IEMFListProperty?
Thanx in advance.
-- Thomas
Re: databinding missing IEMFSetProperty [message #499155 is a reply to message #499151] Fri, 20 November 2009 02:58 Go to previous messageGo to next message
1. Status quo:
We are not having IEMFSetProperty yet because EMF itself has no
Set-Implementations (though in EMF Lists by default act in a set-like
fashion only allowing one instance at a time).
2. Future:
I guess I wrote in my blog that we'll probably add IEMFSetProperty but I
had no time yet to work on it.
The question is which EMF-Feature do you want to bind to the
TableViewer-Selection (must likely an EMF-MultiValue-Feature == EList)?
I guess an implementation based upon the IEMFListProperty implementation
should be quite straight forward but as outlined above I've had no time
to explore/implement this.
So please file a feature request and if you manage to implement it a
patch is welcome, naturally :-)
3. Until then:
A dirty work around would be to bind create an WritableSet and
synchronize your EMF-List and the WritableSet. Dirty but would probably
work. Still if I where you I'd try to implement the IEMFSetProperty
based upon the information above.
Tom
Thomas Kowatsch schrieb:
> Hi.
> example.
> Thanx in advance.
> -- Thomas
Re: databinding missing IEMFSetProperty [message #499164 is a reply to message #499155] Fri, 20 November 2009 03:39 Go to previous messageGo to next message
Tom Schindl schrieb:
> 1. Status quo:
> 2. Future:
New Feature Request: https://bugs.eclipse.org/bugs/show_bug.cgi?id=295683
Bug 295683 - Need an IEMFSetProperty
> 3. Until then:
> Tom
>> Hi.
>> example.
>> Thanx in advance.
>> -- Thomas
Re: databinding missing IEMFSetProperty [message #499180 is a reply to message #499155] Fri, 20 November 2009 05:17 Go to previous messageGo to next message
Hi Tom.
> 1. Status quo:
> 2. Future:
Hmm I had a look into it and it does not seam to be so stright forward
as you mentioned (at least for me).
Most of the time this is just beacause of the lack of corresponding Set
classes. E.g. a SetProperty#values(IValueProperty) returns an
IMapProperty and not an ISetProperty! This makes it not being so
straight forward for me, as I am not so deep into databinding...
I would at least more information or some more hints to follow that.
> 3. Until then:
Could you explain that way a bit deeper, as I can't see anx WritableSet
implementation that I could use to synchronize...
> Tom
>> Hi.
>> example.
>> Thanx in advance.
>> -- Thomas
Re: databinding missing IEMFSetProperty [message #499206 is a reply to message #499180] Fri, 20 November 2009 07:34 Go to previous messageGo to next message
Hi Tom.
I think I understand the dirty hack now.
I attached below a code snippet for you to check if this is generally
correct.
I know it is a very dirty implementation at the moment and can be
enhanced. But I only wanted to be sure that this is the correct
direction I go.
Thanx in advance.
-- Thomas
final IObservableList targetList=
IEMFEditListProperty.observeDeatil(master);
final WritableSet orgSet= new WritableSet();
orgSet.addChangeListener(new IChangeListener() {
public void handleChange (ChangeEvent event) {
if (!internalChange) {
// mark an internal change
internalChange= true;
try {
targetList.clear();
targetList.addAll(Arrays.asList(viewer.getCheckedElements()) );
} finally {
internalChange= false;
targetList.addChangeListener(new IChangeListener() {
if (!_internalChange) {
_internalChange= true;
try {
orgSet.clear();
List<?> list= Arrays.asList(targetList.toArray());
orgSet.addAll(list);
} finally {
_internalChange= false;
ctx.bindSet(ViewersObservables.observeCheckedElements(this,
Organisation.class), orgSet);
Re: databinding missing IEMFSetProperty [message #499211 is a reply to message #499206] Fri, 20 November 2009 07:48 Go to previous messageGo to next message
Hi Thomas,
Yes - you are on the right track :-). Maybe I can spend some minutes
today in the afternoon to see if I can implement a IEMFSetProperty.
Tom
> Hi Tom.
> correct.
> direction I go.
> Thanx in advance.
> -- Thomas
> @Override
> try {
> targetList.clear();
> } finally {
> @Override
> try {
> orgSet.clear();
> } finally {
Re: databinding missing IEMFSetProperty [message #499228 is a reply to message #499211] Fri, 20 November 2009 08:34 Go to previous messageGo to next message
That would be absolutely perfect, Tom :-)
> Hi Thomas,
> Tom
>> Hi Tom.
>> correct.
>> direction I go.
>> Thanx in advance.
>> -- Thomas
>> @Override
>> try {
>> targetList.clear();
>> } finally {
>> @Override
>> try {
>> orgSet.clear();
>> } finally {
Re: databinding missing IEMFSetProperty [message #499297 is a reply to message #499228] Fri, 20 November 2009 12:08 Go to previous messageGo to next message
Have you looked at ListToSetAdapter?
Matthew
Re: databinding missing IEMFSetProperty [message #499298 is a reply to message #499297] Fri, 20 November 2009 12:12 Go to previous messageGo to next message
Cool, didn't know that existed :-( Anyways I'm 95% through to provide
IEMF(Edit)SetProperty.
Tom
> Matthew
Re: databinding missing IEMFSetProperty [message #500021 is a reply to message #499211] Tue, 24 November 2009 12:42 Go to previous messageGo to next message
Hi Tom.
I have seen and used your patch. Looks good ans seems to work.
Do you know when you can add the command execution stuff for the edit part?
Cheers.
-- Thomas
> Hi Thomas,
> Tom
>> Hi Tom.
>> correct.
>> direction I go.
>> Thanx in advance.
>> -- Thomas
>> @Override
>> try {
>> targetList.clear();
>> } finally {
>> @Override
>> try {
>> orgSet.clear();
>> } finally {
Re: databinding missing IEMFSetProperty [message #500072 is a reply to message #500021] Tue, 24 November 2009 15:22 Go to previous messageGo to next message
Hi Thomas,
I'll take a look at it tomorrow morning because I have a half day off.
Tom
> Hi Tom.
> Cheers.
> -- Thomas
>> Hi Thomas,
>> Tom
>>> Hi Tom.
>>> correct.
>>> direction I go.
>>> Thanx in advance.
>>> -- Thomas
>>> @Override
>>> try {
>>> targetList.clear();
>>> } finally {
>>> @Override
>>> try {
>>> orgSet.clear();
>>> } finally {
Re: databinding missing IEMFSetProperty [message #500169 is a reply to message #500072] Wed, 25 November 2009 03:59 Go to previous messageGo to next message
Hi Tom, great man... :-)
> Hi Thomas,
> Tom
>> Hi Tom.
>> Cheers.
>> -- Thomas
>>> Hi Thomas,
>>> Tom
>>>> Hi Tom.
>>>> correct.
>>>> direction I go.
>>>> Thanx in advance.
>>>> -- Thomas
>>>> @Override
>>>> try {
>>>> targetList.clear();
>>>> } finally {
>>>> @Override
>>>> try {
>>>> orgSet.clear();
>>>> } finally {
Re: databinding missing IEMFSetProperty [message #500177 is a reply to message #500169] Wed, 25 November 2009 04:26 Go to previous messageGo to next message
You're welcome.
The changes are in HEAD and hopefully show up in the next build. I love
the properties stuff - it's never been so easy to implement stuff like this.
Tom
>> Hi Thomas,
>> Tom
>>> Hi Tom.
>>> part?
>>> Cheers.
>>> -- Thomas
>>>> Hi Thomas,
>>>> Tom
>>>>> Hi Tom.
>>>>> correct.
>>>>> direction I go.
>>>>> Thanx in advance.
>>>>> -- Thomas
>>>>> @Override
>>>>> try {
>>>>> targetList.clear();
>>>>> } finally {
>>>>> @Override
>>>>> try {
>>>>> orgSet.clear();
>>>>> } finally {
Re: databinding missing IEMFSetProperty [message #500226 is a reply to message #500177] Wed, 25 November 2009 07:55 Go to previous messageGo to next message
Hi Tom.
Updated from head and it works fine.
Thank you very much.
Only one thing: you forgot a System.err.println() in
EMFEditSetProperty#doSetSet()...
Cheers.
--Thomas
> You're welcome.
> Tom
>>> Hi Thomas,
>>> Tom
>>>> Hi Tom.
>>>> part?
>>>> Cheers.
>>>> -- Thomas
>>>>> Hi Thomas,
>>>>> Tom
>>>>>> Hi Tom.
>>>>>> correct.
>>>>>> direction I go.
>>>>>> Thanx in advance.
>>>>>> -- Thomas
>>>>>> @Override
>>>>>> try {
>>>>>> targetList.clear();
>>>>>> } finally {
>>>>>> @Override
>>>>>> try {
>>>>>> orgSet.clear();
>>>>>> } finally {
Re: databinding missing IEMFSetProperty [message #500240 is a reply to message #500226] Wed, 25 November 2009 08:20 Go to previous message
Ups will fix it ASAP - thanks.
Tom
> Hi Tom.
> Cheers.
> --Thomas
>> You're welcome.
>> this.
>> Tom
>>>> Hi Thomas,
>>>> Tom
>>>>> Hi Tom.
>>>>> part?
>>>>> Cheers.
>>>>> -- Thomas
>>>>>> Hi Thomas,
>>>>>> Tom
>>>>>>> Hi Tom.
>>>>>>> generally
>>>>>>> correct.
>>>>>>> direction I go.
>>>>>>> Thanx in advance.
>>>>>>> -- Thomas
>>>>>>> @Override
>>>>>>> try {
>>>>>>> targetList.clear();
>>>>>>> } finally {
>>>>>>> @Override
>>>>>>> try {
>>>>>>> orgSet.clear();
>>>>>>> } finally {
Previous Topic:Model instance transformation
Next Topic:[CDO] how to get released db connectors
Current Time: Wed Jul 23 16:16:14 EDT 2025
Powered by FUDForum. Page generated in 0.06614 seconds
