Home » Language IDEs » PHP Development Tools (PDT) » Cannot open PHP files after updating - Editor could not be initialized(With PDT 2.2.0.v200911190058 Eclipse gives me an "Unable to create editor ID org.eclipse.php.editor: Editor could not be initialized." error when I try to open any PHP file)
Cannot open PHP files after updating - Editor could not be initialized [message #500210] Wed, 25 November 2009 07:01 Go to next message
I cannot open PHP files any more after the latest update of PDT. When I attempt to open any PHP file, it says that it is "Unable to create editor ID org.eclipse.php.editor: Editor could not be initialized." and gives me this stack trace:
Eclipse: Version: 3.5.1 Build id: M20090917-0800
PHP Development Tools (PDT) Runtime Feature 2.2.0.v200911190058-7L7JF8NcJKhTTUhJK5Y
Dynamic Languages Toolkit - Core Frameworks 2.0.0.v20090917-1518-7L--EAAoOQBUSjFBcvjL
java.lang.NoSuchMethodError: org.eclipse.dltk.compiler.IElementRequestor.acceptMethodRefe rence([CIII)V
at org.eclipse.php.internal.core.compiler.PHPSourceElementReque stor.visit(PHPSourceElementRequestor.java:455)
at org.eclipse.php.internal.core.compiler.PHPSourceElementReque stor.visit(PHPSourceElementRequestor.java:652)
at org.eclipse.php.internal.core.compiler.ast.nodes.PHPCallExpr ession.traverse(PHPCallExpression.java:37)
at org.eclipse.php.internal.core.compiler.ast.nodes.UnaryOperat ion.traverse(UnaryOperation.java:51)
at org.eclipse.php.internal.core.compiler.ast.nodes.IfStatement .traverse(IfStatement.java:54)
at org.eclipse.dltk.ast.statements.Block.traverse(Block.java:43 )
at org.eclipse.dltk.ast.declarations.ModuleDeclaration.traverse (ModuleDeclaration.java:70)
at org.eclipse.dltk.core.AbstractSourceElementParser.parseSourc eModule(AbstractSourceElementParser.java:35)
at org.eclipse.php.internal.core.compiler.ast.parser.PHPSourceE lementParser.parseSourceModule(PHPSourceElementParser.java:2 8)
at org.eclipse.dltk.core.SourceParserUtil.parseSourceModule(Sou rceParserUtil.java:237)
at org.eclipse.dltk.internal.core.AbstractSourceModule.buildStr ucture(AbstractSourceModule.java:530)
at org.eclipse.dltk.internal.core.Openable.generateInfos(Openab le.java:185)
at org.eclipse.dltk.internal.core.ModelElement.openWhenClosed(M odelElement.java:182)
at org.eclipse.dltk.internal.core.BecomeWorkingCopyOperation.ex ecuteOperation(BecomeWorkingCopyOperation.java:45)
at org.eclipse.dltk.internal.core.ModelOperation.run(ModelOpera tion.java:698)
at org.eclipse.dltk.internal.core.ModelOperation.runOperation(M odelOperation.java:764)
at org.eclipse.dltk.internal.core.SourceModule.becomeWorkingCop y(SourceModule.java:68)
at org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.createFileInfo(SourceModuleDocumentProvider.java:1271)
at org.eclipse.ui.editors.text.TextFileDocumentProvider.connect (TextFileDocumentProvider.java:478)
at org.eclipse.dltk.internal.ui.editor.SourceModuleDocumentProv ider.connect(SourceModuleDocumentProvider.java:1517)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(Abst ractTextEditor.java:4134)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(Status TextEditor.java:203)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetI nput(AbstractDecoratedTextEditor.java:1413)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor .java:166)
at org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:1712)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(PHPStructuredEditor.java:2208)
at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:3115)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
at org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:759)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:756)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2579)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3133)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3160)
at org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2321)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( PHPStructuredEditor.java:1151)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:644)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.handleDeferredEvents(PartS tack.java:1224)
at org.eclipse.ui.internal.LayoutPart.deferUpdates(LayoutPart.j ava:400)
at org.eclipse.ui.internal.PartSashContainer.handleDeferredEven ts(PartSashContainer.java:1409)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1416)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1406)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1380)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1435)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:543)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 06)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:122 )
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:83)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:270)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:279)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:70 )
at org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:626)
at org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:206)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:21 99)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:327)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
I have no idea how to fix this, any help is appreciated.
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500317 is a reply to message #500210] Wed, 25 November 2009 11:10 Go to previous messageGo to next message
can anyone help, we are stuck here?
10xs
icon13.gif  Re: Cannot open PHP files after updating - Editor could not be initialized [message #500758 is a reply to message #500210] Sat, 28 November 2009 04:32 Go to previous messageGo to next message
Can I provide some more info? Am I the only one stuck with this issue? Is it a bug in Eclipse/PDT or is it something I screwed up? It pretty much renders my Eclipse unusable... I guess I'll have to try NetBeans Confused , then a paid solution like MyEclipse, Zend Studio or something like that Sad
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500776 is a reply to message #500317] Sat, 28 November 2009 10:54 Go to previous messageGo to next message
I have exactly the same problem, and i don't know how to solve it.. I uninstalled the PDT 2.2, but i still have the PHP perspective, and when i'm trying to open a .php file in editor, i got that error..
What we can do? Sad
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500803 is a reply to message #500210] Sat, 28 November 2009 17:13 Go to previous messageGo to next message
Hey, same Problem here.
Try to install Eclipse + PDT today and get the same error, when I try to open a php file.
Last week at work everything works fine. Sad
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500819 is a reply to message #500210] Sun, 29 November 2009 05:12 Go to previous messageGo to next message
probably it's a bug.. can anyone confirm this? So many errors with this Eclipse and it's plugins..
icon4.gif  Re: Cannot open PHP files after updating - Editor could not be initialized [message #500820 is a reply to message #500210] Sun, 29 November 2009 05:32 Go to previous messageGo to next message
I think it is already filed as a critical bug under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295865
which may be a duplicate of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=295871
I guess we just have to wait an hope it will be resolved soon. I'm just surprised and bewildered by the fact that they can release such a broken update, which pretty much makes an up-to-date Eclipse unusable for PHP developers Sad I would understand if it were some other type of file, but *.php? Come on, has any testing been done at all?
It casts a bad light on open source projects in general. Imagine a company which uses it as a primary development tool, they can close the business and go on vacation in the most critical time of the year :-/
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500822 is a reply to message #500210] Sun, 29 November 2009 05:55 Go to previous messageGo to next message
Now it's our job to vote for the bug so that it could be fixed soon Wink It only has 2 votes so far, so don't be shy and vote like you've never voted before! Very Happy
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500887 is a reply to message #500210] Mon, 30 November 2009 01:07 Go to previous messageGo to next message
I have the same problem, it seems I have to wait...
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500906 is a reply to message #500210] Mon, 30 November 2009 04:20 Go to previous messageGo to next message
After manually installing the lates nightly build (for me it was 200911230913) everything worked fine again. (Could not downgrade, so I decided to take the risk)
greatest improvement for me was, that autocompletion now inserts argument variables automatically (like java does)
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500912 is a reply to message #500906] Mon, 30 November 2009 04:40 Go to previous messageGo to next message
That's great news, Christian, hope the fix will be released into the updates soon Cool Installing the nightly build just doesn't seem the right way to go, since I'm not the proper "risk taker" Wink I could not downgrade either, that was another strange thing about this bug... Forward, comrades, not a step back! Very Happy
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500916 is a reply to message #500210] Mon, 30 November 2009 05:11 Go to previous messageGo to next message
Another solution is to uninstall PDT 2.2 and install the 2.1 version, which is included in Galileo update site. (http://download.eclipse.org/releases/galileo). After that, everything worked fine. This may be the proper way if you want a stable environment and it renders my previous complaints useless and out of the picture. However, there was no notice that the 2.2 was an experimental development branch...
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500938 is a reply to message #500916] Mon, 30 November 2009 06:42 Go to previous messageGo to next message
Originally posted by: dkel50.hotremovemail.com
If you look at the main PDT page, you should see that PDT 2.2 is
scheduled for final release in June 2010, so all 2.2 builds at this
point are test builds for people who want to try the latest development
version and to provide valuable feedback on the progress of the release,
but be aware that things may get broken during this period so they
aren't recommended as your main development environment.
Dave Kelsey
Re: Cannot open PHP files after updating - Editor could not be initialized [message #500955 is a reply to message #500938] Mon, 30 November 2009 08:17 Go to previous message
Dave, you're right, sorry for the complaints and remarks. I have already installed the stable version, which works with no problems. My bad, I should have seen it coming, at least the "-dev" suffix should have warned me.
However, it might be a good idea to add a notice to the installation page, or at least show the 2.1 version at the top of the page. I came to the page via search engine results and hadn't therefore studied the main page properly. To be honest, I wouldn't pay attention even if I had, because it is too low and nothing labels the branches as "experimental" or "stable" apart from the release date.
Previous Topic:PHPTaskValidator does not work for folders
Next Topic:Is there a feature or plug-in for PDT to send files via FTP to a remote server?
Current Time: Sun Jul 20 23:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.23672 seconds
