Widget is disposed (Fancy Design) [message #499962] |
Tue, 24 November 2009 10:22  |
Originally posted by: niels.lippke.airpas.com
I get the following stacktrace if I run the default-app with the fancy
design.
What I did after a "fresh" start is, I opened the ConfigurationDialog,
selected "Filter all leafs" and clicked on "Ok" afterwards.
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2658)
at org.eclipse.swt.SWT.error(SWT.java:2578)
at org.eclipse.swt.SWT.error(SWT.java:2549)
at org.eclipse.swt.widgets.Widget.error(Widget.java:892)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:828)
at org.eclipse.swt.widgets.Shell.close(Shell.java:692)
at
org.eclipse.rap.internal.design.example.stacks.Configuration Dialog.close(ConfigurationDialog.java:129)
at org.eclipse.jface.dialogs.PopupDialog$5.run(PopupDialog.java :645)
This time I made sure to have the latest sources from CVS. ;)
Br, Niels
Re: Widget is disposed (Fancy Design) [message #500147 is a reply to message #500025] |
Wed, 25 November 2009 03:25  |
Hi Holger,
It's gone. Thanks a lot!
Br, Niels
"Holger Staudacher" <hstaudacher@eclipsesource.com> schrieb im Newsbeitrag
news:heh6ha$f9e$2@build.eclipse.org...
>I fixed this today. Please make a update. Does the error still exists with
>you version?
> Regards Holger
> On 2009-11-24 16:22:20 +0100, "Niels Lippke" <niels.lippke@airpas.com>
> said:
>> Hi,
>> design.
>> at
>> Br, Niels
> http://eclipsesource.com
> http://twitter.com/eclipsesource
FUDForum. Page generated in 0.12719 seconds
