Home » Archived » Buckminster » Getting subprojects into workspace (Do I need to use generators?)
Getting subprojects into workspace (Do I need to use generators?) [message #500067] |
Tue, 24 November 2009 15:11  |
I have a legacy project that was broken up into 4 sub-projects. Normally, I
check out the project outside of eclipse and import the 4 subprojects into
my workspace. I then import the rest of my components. All are osgi bundles.
I have been trying to replicate this action via a cquery/mspec in
Buckminster with no success. I can use an mspec to bring the main project
down to the filesystem. However, I am having trouble when other components
that depend on the 4 subcomponents try to resolve dependencies.
For example
/A/.project
/A/B/.project
/A/C/.project
/A/D/.project
/A/E/.project
/F which depends on B,C,D,E
Is this a situation where a "generator via cspecx" in Project A would be
used? How do I get A to advertize that it offers B,C,D and E?
Corey
Re: Getting subprojects into workspace (Do I need to use generators?) [message #500242 is a reply to message #500067] |
Wed, 25 November 2009 08:28   |
Since the four parts are projects, and separately adressable (have a
name, a version, and can be accessed) you do not have to use generators
(which are typically used when the named thing does not exist anywhere
until some other component have performed an action). The question here
is if your components B-E are free-standing or if you need all of them
if you need one.
The first step is to make sure that your RMAP contains rules that makes
it possible to find all your components A-E. Try it by editing your
RMAP, and then validate by running a CQUERY for each of the components.
If your components are free standing, then you should be able to state
dependencies on them, and have the transitive closure materialized.
If they are not freestanding, then generators could be used. You then
need to include the component A in your configuration (i.e. depend on
it). The component A would then need to contain declarations that it
generates the other components.
First question: are your components B-E independent/free-standing?
- henrik
> For example
> /A/.project
> /A/B/.project
> /A/C/.project
> /A/D/.project
> /A/E/.project
> Corey
Re: Getting subprojects into workspace (Do I need to use generators?) [message #500291 is a reply to message #500242] |
Wed, 25 November 2009 10:28  |
The components are free standing. However component A needs to be
excluded from the workspace (which is why I have been using a file
system materializer in an MSPEC). Component A is an artifact from an
earlier RCP that needs to be present above B-E for legacy purposes.
However, component A's presence in the workspace is not desired. If
there was a way for Component A to let the resolution process know that
it needs to wait until Componet A is brought down to look for B,C,D, and
E and then look at the file system, that would work.
Even though, I am not generating anything. I thought that using a
generator would get me the deferred resolution for which I am looking.
Corey
Henrik Lindberg wrote:
> if you need one.
> - henrik
>> Normally, I
>> into
>> bundles.
>> project
>> components
>> For example
>> /A/.project
>> /A/B/.project
>> /A/C/.project
>> /A/D/.project
>> /A/E/.project
>> Thanks,
>> Corey
Current Time: Sun Aug 31 08:55:08 EDT 2025
Powered by FUDForum. Page generated in 0.04629 seconds
