Home » Eclipse Projects » Plugin Development Environment (PDE) » Adding product version number in exported product zip file
Adding product version number in exported product zip file [message #499153] Fri, 20 November 2009 02:48 Go to next message
I was wondering if it is possible to automaticllay add the version number of the product configuration to the exported zip file if you use PDE headless build, so that you get something like
$product-$version-win32.win32.x86.zip
I had a look at the documentation and googled the web but couldn't find a hint.
Maybe someone has an idea how to do the job.
Thanks in advance
Bjoern
[Updated on: Fri, 20 November 2009 02:50] by Moderator
Re: Adding product version number in exported product zip file [message #500030 is a reply to message #499153] Tue, 24 November 2009 13:13 Go to previous messageGo to next message
You won't be able to do this when exporting from the UI. To have that
level of control you will need to set up a headless build.
-Andrew
Bjoern Berg wrote:
> Hello,
> number of the product configuration to the exported zip file, so that
> a hint.
> Thanks in advance
> Bjoern
Re: Adding product version number in exported product zip file [message #500127 is a reply to message #500030] Wed, 25 November 2009 01:44 Go to previous messageGo to next message
Hi Andrew,
as I mentioned in my post, I use a headless build, but don't have a clue how to get the product version number into my zip files name.
Bjoern
Re: Adding product version number in exported product zip file [message #501001 is a reply to message #500127] Mon, 30 November 2009 11:17 Go to previous message
Originally posted by: cjcool.comcast.net
Hi Bjoern:
In my build.xml file, I create a variable to contain the name and version of
my product:
<property name="archivePrefix"
value="MyProduct-${buildVersion}-I${DSTAMP}"/>
When calling the productBuild.xml builder, I pass the archive name prefix in
as a command line argument:
<arg value="-DarchiveNamePrefix=${archivePrefix}"/>
And in my builder's build.properties file, I use the variable to set the
archiveNamePrefix property:
archiveNamePrefix=${archiveNamePrefix}
I am using Galileo.
Chris
"Bjoern Berg" <rollin.hand@gmx.de> wrote in message
news:heijns$mk6$1@build.eclipse.org...
> Hi Andrew,
> Bjoern
Re: Adding product version number in exported product zip file [message #603595 is a reply to message #500030] Wed, 25 November 2009 01:44 Go to previous message
Hi Andrew,
Bjoern
Re: Adding product version number in exported product zip file [message #603713 is a reply to message #603595] Mon, 30 November 2009 11:17 Go to previous message
Hi Bjoern:
my product:
I am using Galileo.
Chris
> Hi Andrew,
> Bjoern
Previous Topic:Galileo & plugin template examples
Next Topic:Target platform problem
Current Time: Sun Jul 27 07:26:45 EDT 2025
Powered by FUDForum. Page generated in 0.05157 seconds
