[EMF Compare] ArrayIndexOutOfBoundsException in ResourceSimilarity#resourceURISimilarity() [message #499880] |
Tue, 24 November 2009 08:08  |
Originally posted by: mail.andreasscharf.com
I get an ArrayIndexOutOfBoundsException in
ResourceSimilarity#resourceURISimilartiy() line 146:
final String candidateName = candidate[candidate.length - 1];
Problem is the candidateArray is empty which results from the URI not
having any segments because it has the form #SOME_ELEMENT_ID which is
a relative ID.
Andreas
Re: [EMF Compare] ArrayIndexOutOfBoundsException in ResourceSimilarity#resourceURISimilarity() [message #499953 is a reply to message #499951] |
Tue, 24 November 2009 10:08   |
--------------080607020707010603010105
Andreas,
I'd also have thought that the URI would be fully resolved when reaching
this code, and have never seen (or reproduced for that matters) the NPE
you get. If you can share a small example with both the models you
compare and the action you use to compare, I'd like to try and reproduce
this; simply fixing the NPE wouldn't do the trick as I believe the same
assumptions are made at many places in my code.
Laurent Goubet
Obeo
Ed Merks wrote:
> Andreas,
> By the time that href is loaded, it's typically resolved against the URI
> of the containing resource. What URI do you use to load the resource
> itself?
> Andreas Scharf wrote:
>> Laurent,
>> the use case is a comparison of an UMLfile against a certain
>> (older/newer) revision. I have to mention that I'm not using the
>> CompareEditor which comes with EMF Compare but my own compare actions.
>> At some point in the XML there code like
>> <eClassifiers xmi:type="ecore:EClass"
>> xmi:id="SOME_ELEMENT_ID">
>> </eClassifiers>
>> <eClassifiers xmi:type="ecore:EClass"...>
>> <eSuperTypes href="#SOME_ELEMENT_ID"/>
>> </eClassifiers>
>> so the href points to an element relativ to the the elemen itself in
>> which case we only have a fragment and no segments.
>> If that isn't enough information I try to provide a small example since
>> I cannot share the original files.
>> Cheers,
>> Andreas
>> Laurent Goubet schrieb:
>>> Hi,
>>> Could you give me a little more information as to how you use the
>>> comparison? I can't see a way to get to this code with empty URIs
>>> containing only fragments.
>>> laurent Goubet
>>> Obeo
>>>> Hi,
>>>> not having any segments because it has the form #SOME_ELEMENT_ID
>>>> which is
>>>> a relative ID.
>>>> Cheers,
>>>> Andreas
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
org:<a href="http://www.obeo.fr">Obeo</a>
email;internet:laurent.goubet@obeo.fr
url:http://www.obeo.fr
version:2.1
end:vcard
--------------080607020707010603010105--
Re: [EMF Compare] ArrayIndexOutOfBoundsException in ResourceSimilarity#resourceURISimilarity() [message #500299 is a reply to message #499953] |
Wed, 25 November 2009 10:50   |
I tried to reproduce the mentioned problem but I wasn't able to. But to
answer Ed's question:
I use the the following lines to load the remote version:
------8<-----------------------------------
EObject remoteModel =
ModelUtils.load(getFileContentOperation.getContent(),
finalRemote.getName(), new ResourceSetImpl());
------->8----------------------------------
where getFileContentOperation is a
org.eclipse.team.svn.core.operation.remote.GetFileContentOpe ration
and
#getContent()
returns an InputStream.
I noticed that the SubversiveTeamHandler in emf compare set a special
URI converter during resource loading: RevisionedURIConverter.
But as I mentioned above: I couldn't reproduce it.
Andreas
> Andreas,
> Laurent Goubet
> Obeo
> Ed Merks wrote:
>> Andreas,
>> URI of the containing resource. What URI do you use to load the
>> resource itself?
>>> Laurent,
>>> </eClassifiers>
>>> </eClassifiers>
>>> Cheers,
>>> Andreas
>>>> Hi,
>>>> laurent Goubet
>>>> Obeo
>>>>> Hi,
>>>>> which is
>>>>> a relative ID.
>>>>> Cheers,
>>>>> Andreas
Re: [EMF Compare] ArrayIndexOutOfBoundsException in ResourceSimilarity#resourceURISimilarity() [message #500327 is a reply to message #500299] |
Wed, 25 November 2009 11:21  |
--------------090305040801010600060505
Andreas,
We use a custom URIConverter when loading SVN files so as to be able to
retrieve repository versions of models the currently loaded might depend
on. You'll notice though that we load the models the same way as you do
: SubversiveTeamHandler#loadResources() at line 90 for example sports code :
rightResource = ModelUtils.load(((ResourceElement)right).getContents(),
right.getName(), rightResourceSet).eResource();
I really can't figure out how you got that NPE in the first case :).
Laurent Goubet
Obeo
> and
> #getContent()
> Best regards,
> Andreas
>> Andreas,
>> reaching this code, and have never seen (or reproduced for that
>> matters) the NPE you get. If you can share a small example with both
>> the models you compare and the action you use to compare, I'd like to
>> try and reproduce this; simply fixing the NPE wouldn't do the trick as
>> I believe the same assumptions are made at many places in my code.
>> Laurent Goubet
>> Obeo
>> Ed Merks wrote:
>>> Andreas,
>>> resource itself?
>>>> Laurent,
>>>> </eClassifiers>
>>>> </eClassifiers>
>>>> Cheers,
>>>> Andreas
>>>>> Hi,
>>>>> laurent Goubet
>>>>> Obeo
>>>>>> Hi,
>>>>>> which is
>>>>>> a relative ID.
>>>>>> Cheers,
>>>>>> Andreas
begin:vcard
fn:Laurent Goubet
n:Goubet;Laurent
version:2.1
end:vcard
--------------090305040801010600060505--
FUDForum. Page generated in 0.04104 seconds
