Eclipselink is spending an hour releasing write locks [message #499452] |
Sun, 22 November 2009 12:45  |
I am working on a large application that is, for the most part, working quite well in production. However one of our clients have reported a process that is taking 2 hours to complete. For this process I would expect that half of that time, 1 hour, would be reasonable and one quarter of it, 30 minutes, would be optimal. We are dealing with a lot of data and processing. After profiling the process I found that it is taking 60 minutes to clear write locks.
Specifically it is spending the 60 minutes in WriteLockManager.releaseAllAcquiredLocks at the end of the for loop on the the line that reads locks.remove(). A little more digging I found that there are about 1.5 million write locks to be removed at this point. The rest of the application is not running into this so I am looking at something different about this process or the mappings that it uses. The number of objects being changed is not unique though. Any ideas about why so many write locks are being acquired?
We are running this on a very fast box (16 Xeon cores with 128MB ram) running RHES running against Oracle 10G also on a fast box. We are running EclipseLink 1.1.3 on Java 1.6.0_4.
I have been able to make the symptom go away with a small change to Eclipselink. I removed the locks.remove() line from WriteLockManager.releaseAllAcquiredLocks and put mergeManager.getAcquiredLocks().clear() outside of the loop. The performance problem here is that we are calling ArrayList.iterator.remove() at the beginning of a list which in turn calls arraycopy to shift the contents of the arraylist over one element down. It is far more efficient to empty the whole list after we are done iterating over it to perform the cleanup on the individual locks. As I mentioned above my application was spending 60 minutes removing individual elements from the list. After this change releaseAllAcquiredLocks is practically instant.
Thank you,
David
[Updated on: Sun, 22 November 2009 13:12] by Moderator
Re: Eclipselink is spending an hour releasing write locks [message #499676 is a reply to message #499452] |
Mon, 23 November 2009 11:51   |
This issue and your patch seems valid, please log a bug and attach your patch.
However, in general committing 1.5 million objects in a single EntityManager transaction may not be a good idea.
Normally when dealing with a large set of objects, it is best to split the load into batches. Ideally for each batch (1,000-10,000 objects) create a new EntityManager and transaction. If you need them all to be the same transaction, you can use flush() then clear() after each batch.
Also, if you are mass inserting these objects, it would be best to disable the cache, as it does not help inserts and does add a small (normally) overhead. This can be done setting "eclipselink.cache.shared.default"="false" in your persistence.xml or properties. Also try enabling batch writing, and ensure you are using sequence pre-allocation.
FUDForum. Page generated in 0.32128 seconds
