Home » Archived » Buckminster » [hudson plugin] fails when performing #create.product
[hudson plugin] fails when performing #create.product [message #495889] Fri, 06 November 2009 09:22 Go to next message
I am getting this error message when the hudson job is about to perform the #create.product action:
No repository found at file:/C:/Documents%2520and%2520Settings/Default%2520User/.hu dson/jobs/.../site.p2/
It seems that the path/url provided to #create.product has a wrong encoding. #site.p2 succeeds.
Could you please confirm that #create.product works with the job's workspace path containing spaces?
Re: [hudson plugin] fails when performing #create.product [message #495923 is a reply to message #495889] Fri, 06 November 2009 11:00 Go to previous messageGo to next message
Hi Erdal,
please have a look at this:
https://hudson.dev.java.net/issues/show_bug.cgi?id=4537
and that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291405
The Problem is that buckminster passes perfectly fine encoded URIs to
the ant script, and the ant script to the p2 director application. The
director application however expects URIs that are not properly encoded
and encodes them no matter if the URI was valid, or not.
The result is the strange double encoded URI you're seeing in the error
message that is of course invalid.
Until the p2 bug is resolved you have two options here:
1. somehow decode the URI in your ant script before passing it to the
director
2. use a path without special characters
In general I would try to avoid paths with spaces on a build machine
because it's an extra source of error.
Johannes
Re: [hudson plugin] fails when performing #create.product [message #499613 is a reply to message #495923] Mon, 23 November 2009 09:38 Go to previous message
I had a similar problem.
If you install hudson in your home directory, which is C:\Documents and Settings\... on Windows there are Spaces. If you install hudson in C:\hudson everything should work.
You can install hudson in a different location by installing it as a windows service (need admin rights).
Previous Topic:[headless junit] cannot find xml test results file
Next Topic:Choosing the svnkit over javahl
Current Time: Thu Jul 31 12:57:30 EDT 2025
Powered by FUDForum. Page generated in 0.04580 seconds
