Home » Modeling » MoDisco » Re: Java Ecore metamodel and M2T Template
Re: Java Ecore metamodel and M2T Template [message #499036] |
Thu, 19 November 2009 10:42  |
Jan,
Sorry for late reply, I was abroad.
I've added MoDisco newsgroup to the discussion. Maybe they are interested.
> Krzysztof,
> I more or less dived into the same "adventure" as you and the others in
> this thread. I have the four solutions on my investigation agenda which
> were mentioned already, the EMF example, JEM, MoDisc and oAW aka
> Xtext/Xtend/Xpand
> JEM seems to be outdated and out of the game from the beginning. I've
> started with the EMF example and MoDisc by now. The first one does not
> support serialization but seems to be fine for my purpose already since
> I do only need structure information for time being.
For know I am using MoDisco J2SE5 metamodel/discoverer with small
changes (I have removed ATL dependencies, as I don't use J2SE5 -> KDM ->
UML, nor ATL).
MoDisco have a bit newer (and as they claim better) model/discoverer
http://wiki.eclipse.org/MoDisco/Java , thus I will probably move to it
one day. The metamodel is not much different, so it should be easy.
> However, serialization will be quickly become an issue. You mentioned
> that you did wrote some templates and I'm not quite sure for which of
> the technologies you actually did that and (more important) whether you
> could imagine to share your results with us ;-)
I have working but incomplete templates in Eclipse M2T Xpand for
generating Java code from J2SE5 metamodel. They are not "production
quality". As I said before they do not handle comments, generics and
some basic constructs are missing. It is possible that they have some
errors, as they was not tested much. Nevertheless they works for me ;)
I can share them, preferably as open source contribution.
But, AFAIK MoDisco plans to develop some kind of serialization for Java
model. I am not sure will it be Java or Acceleo based serialization though.
> I'm also wondering whether there is any attempt to further develop the
> EMF example and add serialization. The project seems to be still alive
> at least (see comments from Marcelo in another thread at
> http://www.eclipse.org/forums/index.php?t=msg&goto=41414 8&S=bc1ad57bb4e7b26aa4a584e876ec7c7e)
I don't know that, you can ask on EMF forum.
Krzysztof Kowalczyk
Re: Java Ecore metamodel and M2T Template [message #499187 is a reply to message #499036] |
Fri, 20 November 2009 05:51   |
Hi Krzysztof,
Krzysztof Kowalczyk a écrit :
> Jan,
>> Krzysztof,
>> in this thread. I have the four solutions on my investigation agenda
>> which were mentioned already, the EMF example, JEM, MoDisc and oAW aka
>> Xtext/Xtend/Xpand
>> since I do only need structure information for time being.
> UML, nor ATL).
Thanks for your interest in MoDisco.
Please, don't hesitate to provide your feedback on this new Java
metamodel implementation (and corresponding discoverer) ;-)
>> you could imagine to share your results with us ;-)
I would be great to have a standard serialization available for the Java
metamodel.
This is something we could discuss and your contribution could be
potentially made available via MoDisco at some point...
Hugo
> Regards,
> Krzysztof Kowalczyk
Hugo Bruneliere - R&D Engineer
AtlanMod research team (INRIA & EMN) - Room B206
Ecole des Mines de Nantes
4, rue Alfred Kastler
44307 Nantes Cedex 3 - France
Office: +33 (0)2 51 85 82 21
EMail: hugo.bruneliere@inria.fr
Re: Java Ecore metamodel and M2T Template [message #499561 is a reply to message #499203] |
Mon, 23 November 2009 06:17  |
Hi Krzysztof,
> Jan Mauersberger:
>> I use the same meta model and also do not require KDM etc. However, I
>> wasn't aware the that the Java meta model is newer - I assumed the
>> other way around ;-)
> There are 3 models right know - JavaAST (the oldest one), J2SE5 and
> Java. The third one is recommended AFAIK.
You're right! These three metamodels correspond to the several
iterations that have been made in order to reach a fully satisfying
version, the Java metamodel being this final version.
> Hugo Bruneliere,
> It seems that MoDisco is devoted to ATL / Acceleo and my work is in
> Xpand / Xtend. Does it matter ?
It is true that our current works mainly use ATL as a M2M technology and
Acceleo as a M2T one.
However, MoDisco is not dependent from these technologies: it is
designed so that any kind of M2M or M2T technology may be used within a
given reverse-engineering process.
According to this, several drivers for such different technologies have
already been committed to the project.
Of course, we are open to potential contributors of other drivers for
other technologies ;-)
Hugo
> Regards,
> Krzysztof Kowalczyk
Re: Java Ecore metamodel and M2T Template [message #573761 is a reply to message #499036] |
Hi Krzysztof,
> Jan,
>> Krzysztof,
>> Xtext/Xtend/Xpand
> UML, nor ATL).
metamodel.
Hugo
> Regards,
> Krzysztof Kowalczyk
Re: Java Ecore metamodel and M2T Template [message #573777 is a reply to message #499036] |
Fri, 20 November 2009 06:22  |
Krzysztof,
thanks for the reply and pointing out the modisco newsgroup.
> UML, nor ATL).
wasn't aware the that the Java meta model is newer - I assumed the other
way around ;-)
I do support that idea and according to Hugo's reply they are interested
in standard Java serialization too.
Best regards
Jan
Re: Java Ecore metamodel and M2T Template [message #573785 is a reply to message #499197] |
Fri, 20 November 2009 07:21  |
Jan Mauersberger:
> way around ;-)
Hugo Bruneliere,
Krzysztof Kowalczyk
Re: Java Ecore metamodel and M2T Template [message #573796 is a reply to message #499036] |
Mon, 23 November 2009 06:07  |
Hi Krzysztof,
I will complete Hugo's answer :
Yes, the 'Java' metamodel is now the recommended one ('JavaAST' et 'J2SE5' will become 'deprecated').
We are currently working on a serialization for 'Java' models, which will be released for the end of the year.
This serialization will cover all the aspects of the Java language.
Nevertheless, the generations rules that you already wrote for 'J2SE5' are welcome. It could be made available via MoDisco for 'J2SE5' models, whatever the technology used (Acceleo, Xpand... ), and even if all aspects of the Java language are not managed.
Best regards.
Fabien GIQUEL
R&D Engineer
mailto:fgiquel@mia-software.com
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
Re: Java Ecore metamodel and M2T Template [message #573808 is a reply to message #499203] |
Hi Krzysztof,
> Jan Mauersberger:
> Hugo Bruneliere,
Hugo
> Regards,
> Krzysztof Kowalczyk
Current Time: Wed Jul 23 20:36:40 EDT 2025
Powered by FUDForum. Page generated in 0.26864 seconds
