Home » Eclipse Projects » Plugin Development Environment (PDE) » headless p2 director application
headless p2 director application [message #49920] Mon, 09 March 2009 14:09 Go to next message
I have a ant build script which needs to run the p2 director application
in headless environment. This is how I try to do it:
> <target name="p2-install-feature">
> <java classname="org.eclipse.equinox.launcher.Main" fork="true" failonerror="true">
> <arg value="-application" />
> <arg value="org.eclipse.equinox.p2.director.app.application" />
> <arg value="-metadataRepository" />
> <arg value="${p2.metadata.repo}" />
> <arg value="-artifactRepository" />
> <arg value="${p2.artifacts.repo}" />
> <arg value="-installIU" />
> <arg value="${p2.install.iu}" />
> <arg value="-version" />
> <arg value="${p2.feature.version}" />
> <arg value="-destination" />
> <arg value="${targetEclipse}" />
> <arg value="-profile" />
> <arg value="SDKProfile" />
> <arg value="-vmArgs" />
> <arg value="-Declipse.p2.data.area=${targetEclipse}/p2" />
> <classpath>
> <pathelement location=" ${hostEclipse}/eclipse/plugins/org.eclipse.equinox.launcher_ ${equinoxLauncherPluginVersion}.jar " />
> </classpath>
> </java>
> </target>
I previously used to run the director application using the "eclipse"
launcher, but that doesn't work to well when DISPLAY isn't set.
There are no visible problems when running the application, but
attempting to use the target application (${targetEclipse}) to run the
PDE build scripts fails complaining about missing plugins?
What could I be doing wrong?
/Jesper
Re: headless p2 director application [message #50110 is a reply to message #49920] Tue, 10 March 2009 15:28 Go to previous message
Jesper,
The -vmargs is an argument to the eclipse executable, it doesn't work
when launching java directly. Because you are using the <java> task,
you need to change it to be more like:
<jvmarg value="-Declipse.p2.data.area=${targetEclipse}/p2" />
-Andrew
>> <arg
>> <classpath>
>> <pathelement
>> </classpath>
>> </java>
>> </target>
> /Jesper
Re: headless p2 director application [message #593101 is a reply to message #49920] Tue, 10 March 2009 15:28 Go to previous message
Jesper,
-Andrew
>> <arg
>> <classpath>
>> <pathelement
>> </classpath>
>> </java>
>> </target>
> /Jesper
Previous Topic:Problem with pluginPath (headless build)
Next Topic:Headless Build and Debug Info
Current Time: Sat Oct 25 13:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.24505 seconds
