Home » Archived » BIRT » previous/next group - referring to row by position
previous/next group - referring to row by position [message #499064] Thu, 19 November 2009 11:57 Go to next message
Even after searching these forums for 2 hours I can't see any way to have next/previous links that can iterate through groups in a table
Background:
I've got a table with a grouping on a column in a flat data source (CSV). In the grouping header I have a graph for that group.
I only display one group in the report by having a filter set up which only displays the group that matches a parameter ("filteredGroup").
What I'd like to do:
I'd like a previous and next link that allows the user to see graphs for the previous/next group.
Firstly, I'm not sure how to get the group index (row.__rowNum doesn't seem to work for group headers.)
Secondly, once I have the index of the visible group, I'm not sure how to refer to the previous row. In fact, I can't even see how to get all values in a column (e.g. all values contained in row["key"])
e.g. if the groups are A, B, C, D and B is shown (because the report had parameter http://www/report.rptdesign?filteredGroup=B) then the prev link would have http://www/report?filteredGroup=A and the next link would have http://www/report?filteredGroup=C.
So, any ideas out there for what I want?
[Updated on: Thu, 19 November 2009 12:23] by Moderator
Re: previous/next group - referring to row by position [message #499086 is a reply to message #499064] Thu, 19 November 2009 13:30 Go to previous messageGo to next message
Ash
Not sure if this is what you want but look at the beforeFactory of the
attached example and the hyperlink on the prev/next labels.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[prev=null;
next=null;
var myJsArray = [];
myJsArray[0]=10101;
myJsArray[1]=10102;
myJsArray[2]=10104;
var currIndex =0;
for( ii=0; ii< myJsArray.length; ii++ ){
if( params["filterOrder"].value == myJsArray[ii] ){
currIndex=ii;
break;
if( currIndex == (myJsArray.length-1) ){
next = myJsArray[0];
prev = myJsArray[currIndex-1];
}else if( currIndex == 0 ){
next = myJsArray[1];
prev = myJsArray[myJsArray.length-1];
}else{
next = myJsArray[currIndex+1];
]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<parameters>
<scalar-parameter name="filterOrder" id="9">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="distinct">true</property>
<simple-property-list name="defaultValue">
<value type="constant">10101</value>
</simple-property-list>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">filterOrder</property>
<property name="nativeName"></property>
<property name="dataType">integer</property>
<property name="nativeDataType">4</property>
<property name="position">1</property>
<expression name="defaultValue"
type="javascript">10101</expression>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails
where ordernumber = ?]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
<style name="table-header" id="44">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="45">
</style>
<style name="table-detail" id="46">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="47">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="48">
</style>
<style name="special-header" id="49">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="50">
</style>
<style name="crosstab-header" id="51">
</style>
<style name="mydata" id="52">
<property name="color">orange</property>
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="54">
<column id="55"/>
<column id="56"/>
<row id="57">
<cell id="58">
<label id="60">
<method name="onCreate"><![CDATA[this.text =
prev;]]></method>
<text-property name="text">prev</text-property>
<structure name="action">
<property
name="linkType">drill-through</property>
<property
name="reportName">prevnext.rptdesign</property>
<property name="targetWindow">_self</property>
<property
name="targetFileType">report-design</property>
<list-property name="paramBindings">
<structure>
<property
<expression
name="expression">prev;</expression>
</structure>
</list-property>
</structure>
</label>
</cell>
<cell id="59">
<label id="61">
next;]]></method>
<text-property name="text">next</text-property>
<property
<property
<property
<structure>
<property
<expression
name="expression">next;</expression>
</structure>
</list-property>
</structure>
</label>
</cell>
</row>
</grid>
<table id="10">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<column id="43"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<data id="24">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="31">
<data id="32">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="33">
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
<cell id="38"/>
</row>
</footer>
</table>
</body>
</report>
Ash wrote:
> I can't see how to have next/previous links that can iterate through
> groups in a table
> Background:
> Firstly, I'm not sure how to get the group index (row.__rowNum) doesn't
> Once I have the index of the visible group, I'm not sure how to refer to
> the previous row. Unlike JavaScript arrays the dataSetRow[] and row[]
> "arrays" don;t seem to accept indexes e.g. row[2], which is what I need
> to set the previous/next links.
Re: previous/next group - referring to row by position [message #499198 is a reply to message #499086] Fri, 20 November 2009 06:37 Go to previous messageGo to next message
Your code is fine if only I could load all the values of row[params["filterGroup"].value] into a JavaScript array, but I don't know how to.
I don't know the values to pre-populate the array as you have.
e.g. if only this would work:
myJsArray = [];
for (k in row[params["filterGroup"].value]) {
  myJsArray.push(k);
if( row[params["filterOrder"].value] == myJsArray[ii] ){
currIndex=ii;
break;
// ... rest of your code follows
[Updated on: Fri, 20 November 2009 06:38] by Moderator
Re: previous/next group - referring to row by position [message #499275 is a reply to message #499198] Fri, 20 November 2009 11:20 Go to previous messageGo to next message
Ash,
You can make it dynamic by using a hidden table. Take a look at the
modified dynamic example.
Jason
id="1">
<parameters>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
id="7">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
<model:DesignValues
<design:attributes>
</oda-data-set>
<oda-data-set
name="ordernumber" id="62">
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select distinct
ordernumber
from orderdetails
order by ordernumber asc]]></xml-property>
<model:DesignValues
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="63">
<property name="dataSet">ordernumber</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr"
type="javascript">true</expression>
</structure>
</list-property>
<structure>
<text-property
<expression
</structure>
</list-property>
<method name="onPrepare"><![CDATA[prev=null;
next=null;
myJsArray = [];
curcount=0;]]></method>
<column id="72"/>
<header>
<row id="73">
<cell id="74">
<label id="75">
<text-property name="text">This table is
hidden but is used to load js array-- look at the onPrepare for tabel
and oncreate on detail and footer row</text-property>
</label>
</cell>
</row>
<row id="64">
<cell id="65">
<label id="66">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="67">
<method name="onCreate"><![CDATA[var currord =
this.getRowData().getColumnValue("ORDERNUMBER");
myJsArray[curcount] = currord;
curcount++;
]]></method>
<cell id="68">
<data id="69">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="70">
var currIndex =0;
currIndex=ii;
break;
}else{
}]]></method>
<cell id="71"/>
</row>
</footer>
</table>
<grid id="54">
<column id="55"/>
<column id="56"/>
<row id="57">
<cell id="58">
<label id="60">
prev;]]></method>
<property
<property
name="reportName">dynamicprevnext.rptdesign</property>
<property
<structure>
<property
<expression
</structure>
</list-property>
</structure>
</label>
</cell>
<cell id="59">
<label id="61">
next;]]></method>
<property
<property
<property
<structure>
<property
<expression
</structure>
</list-property>
</structure>
</label>
</cell>
</row>
</grid>
<table id="10">
<structure>
<text-property
<expression
</structure>
<structure>
<text-property
<expression
</structure>
<structure>
<text-property
<expression
</structure>
<structure>
<text-property
<expression
</structure>
<structure>
<text-property
<expression
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<column id="43"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<data id="24">
<property
</data>
</cell>
<cell id="25">
<data id="26">
<property
</data>
</cell>
<cell id="27">
<data id="28">
<property
</data>
</cell>
<cell id="29">
<data id="30">
<property
</data>
</cell>
<cell id="31">
<data id="32">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="33">
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
<cell id="38"/>
</row>
</footer>
</table>
</body>
</report>
> know how to.
> <code>
> myJsArray = [];
> myJsArray.push(k);
> currIndex=ii;
> break;
> </code>
Re: previous/next group - referring to row by position [message #499654 is a reply to message #499275] Mon, 23 November 2009 10:45 Go to previous message
Thanks a lot, hidden tables works!
Why does BIRT require such hackery? Hidden tables just to enumerate values across a column, global vars just to keep track of the current row number (for grouped rows).
Surely the API should be beefed up a bit to make it easier to do this sort of stuff?
all the best
Ash
Previous Topic:Trimmed Leading Space Characters
Next Topic:Executing Query with a '%' character
Current Time: Mon Jul 21 02:35:33 EDT 2025
Powered by FUDForum. Page generated in 0.09205 seconds
