Home » Eclipse Projects » Rich Client Platform (RCP) » Editor problems with external files(Opening files which are outside the workspace create errors)
Editor problems with external files [message #498973] Thu, 19 November 2009 06:59 Go to next message
I am working on an editor where at the moment I use external files loaded through IDE.openEditorOnFileStore( page, fileStore ); as found in the FAQs.
When using my own DocumentProvider which extends FileDocumentProvider I get an error message instead of the editor.
This also happens if I test the xml example plugin which can be created when making a new plugin.
Just as a sidenote:
I tested both plugins also with the eclipse framework and both show the same results: opening via the OpenFile... menu I get an error. When I add the file to an project and then open the file it works just fine: I see the editor!
Any suggestions?
Andreas
Re: Editor problems with external files [message #498985 is a reply to message #498973] Thu, 19 November 2009 07:45 Go to previous messageGo to next message
Hi Andreas,
Can you provide a stack trace?
Wim Jongman
> Hi
> Just as a sidenote:
editor!
> Any suggestions?
> Regards
> Andreas
Re: Editor problems with external files [message #499001 is a reply to message #498973] Thu, 19 November 2009 08:38 Go to previous messageGo to next message
Andreas Winkler wrote:
> Hi
> in the FAQs.
The TextFileDocumentProvider which uses file buffers underneath is made
to support external files. If you decide not to use that class then you
have to re-implement all that functionality.
Dani
> Just as a sidenote:
> Any suggestions?
> Regards
> Andreas
Re: Editor problems with external files [message #499184 is a reply to message #499001] Fri, 20 November 2009 05:46 Go to previous messageGo to next message
I don't know how to get stack trace cause I don't get any error in the log. Just the word ERROR is displayed in the editorArea.
While debugging I found out that in StorageDocumentProvider.getEncoding the element is checked if it is instanceof IStorageEditorInput which it obviously isn't. And that's where createDocument can't set the document content and therefor returns null as the document.
super.createDocument( element )
is called in my DocumentProvider which extends FileDocumentProvider.
element is an Object of org.eclipse.ui.ide.FileStoreEditorInput
My Editor extends AbstractDecoratedTextEditor, but the same error occurs when extending TextEditor instead.
Andreas
[Updated on: Fri, 20 November 2009 05:47] by Moderator
Re: Editor problems with external files [message #499801 is a reply to message #499184] Tue, 24 November 2009 04:00 Go to previous message
> returns null as the document. super.createDocument( element ) happens
As said before your document provider is wrong.
Dani
> Regards
> Andreas
Previous Topic:RCP Jetty..absolute path for htmls
Next Topic:Cant create a product
Current Time: Thu Jul 24 23:09:52 EDT 2025
Powered by FUDForum. Page generated in 0.48122 seconds
